Results 1 to 18 of 18
Thread: First roast
    Jun 2012
    30
    First roast
    A package of green beans arrived from Coffee Snobs this morning. I was going to wait until the weekend but... well, Im sure I dont need to explain.
    This is my first coffee roast. Admittedly, the results may not be any good at all, but it was fun, much easier than I expected and less smoke than I expected.
    I bought a Whirley Pop from Peters of Kensington a few days ago, heated it up on the gas stove top, put 250 grams of Indian Monsoon Malabar in and started stirring. Clearly I overdid the first batch. Tried again a short while later and removed the beans as soon as the second crack started. I used a couple of colanders to cool the beans as quickly as I could.
    Any advice on storing (hopefully its not dont bother storing that lot) would be great to have. And any advice on how to improve my next roast would be very, very welcome.
    Jeremy
    (BTW. How do I get one of those roasting cards?)
    Dec 2011
    46
    Re: First roast
    Ideally you should be storing the beans in a sealed bag with a CO2 valve...so for example, the type of bag you might buy already roasted beans in (if it is resealable). Otherwise, you can buy they from from Coffeesnobs quite cheaply. You can add a CS member card to your next order for free as well.
    Something to keep in mind- Ive observed from my own experiences that the roast level affects the relationship between grind level, flow rate and extraction. Therefore IMO there is not too much to gain from using improperly roasted beans to say adjust your grind or practise dosing. So thats perhaps a mistake I was making when I ruined some batches and tried to use those beans to improve my technique.
    Anywho your second batch looks much better than your first, and ultimately it comes down to what YOU like when you finally drink those beans. Itll take a while to get your roasting technique sorted, some will get burned and others will be under-roasted, but make sure you stick with it :)
    Jun 2012
    30
    Re: First roast
    Thanks Papagoose
    I purchased a few sealed bags with a CO2 valve along with the beans. But I seem to recall reading somewhere to leave the beans in an open jar for the first 12-24 hours after roasting.
    Your second para. Does that mean that neither batch is worth keeping? I put a small scoop of that second batch next to a scoop of professionally-roasted beans and the colour and consistency seem very similar.* (The beans are actually much more uniform than they look in the photo).
    Jeremy
    Dec 2004
    Earth!
    15,663
    Re: First roast
    Quote Originally Posted by 715A42695E42765E3B0 link=1339739095/2#2 date=1339741710
    Bag and seal the beans when they reach a couple degrees above ambient when youre cooling them.
    Java "Bagging it" phile
    Senior Member David8's Avatar
    Oct 2011
    Annerley, QLD
    559
    Re: First roast
    Quote Originally Posted by 507B63487F63577F1A0 link=1339739095/0#0 date=1339739095
    There should be an option in BeanBay to add one to your order. I would give you a link, but the free one disappears once you redeem it. But it should be on this page - http://beanbay.coffeesnobs.com.au/ViewCategory.aspx/OtherStuff.
    Edit: Ahha! I found it - http://beanbay.coffeesnobs.com.au/ViewProduct.aspx/111-cs-membership-cards
    Just click "Add to Order"! Its free!! WOO
    Quote Originally Posted by 507B63487F63577F1A0 link=1339739095/2#2 date=1339741710
    Thanks Papagoose
    Try the batch on the right, they look alright. The batch on the left may be too charred though.
    David
    Oct 2006
    504
    Re: First roast
    the ones on the left look like theyre a little bit over, could be your camera showing them darker than they are though, the second roast is certainly the better of the 2 but a bit inconsistent
    250 grams sounds like a lot of beans to be putting in a popper, id try 150 grams - when I was popper roasting I found my best results were with 120 - 150 grams, I needed to agitate the beans a bit to get them moving then the popper did the rest for me
    Apr 2012
    497
    Re: First roast
    Quote Originally Posted by 6F776D706C6B667D70761F0 link=1339739095/5#5 date=1339843046
    I believe Whirley Pop is a stovetop popcorn maker (shallow pan with a hand cranked agitator) not an air popper :)
    Jun 2012
    30
    Re: First roast - getting closer but still need a lot of help
    Thanks folks, all very much appreciated. The Whirley Pop is a stove top popcorn saucepan, very lightweight but seems to do the job. I roasted two more batches of 250 grams yesterday. Brazil Pullped Natural on the right (pulled at 2nd crack) and Peru Ceja de Selva on the left (pulled just before 2nd crack).
    My main difficulty was controlling the temperature. I followed the instructions on the Sweet Maria site and heated the Whirley Pop to around 200 before dropping the beans in. The temp then starts to go down quite rapidly to below 150. On the Peru (which I roasted after the Brazil) I compensated by moving the Whirley to a bigger flame, but this may have been the wrong thing to do and I pulled the beans out before 2nd crack for fear of burning them.
    Very keen to get one of the FZ-RR 700 next, but feel like I need to make a bit more progress with the Whirley first.
    Cheers, and thanks for helping a newb.
    Jeremy
    Edited to reduce picture file size out of consideration of our bandwidth challenged users. Please keep images to ~100kb in size.
    Jun 2012
    30
    Re: First roast
    Photo of the Whirley Pop and friends.
    caffeinated lemoo's Avatar
    Oct 2011
    Perth, WA
    330
    Re: First roast
    congrats on the first roast jay!
    just curious what the bean agitation on the whirleypop is like?
    im not sure if its the camera lighting affecting it but it seems like some beans were charred in a few spots?
    Jun 2012
    30
    Re: First roast
    Thanks Lemoo
    Ill take that option and blame the camera and lighting!
    The beans look a bit more uniform than the photo indicates, but there are definitely inconsistencies and Im still pondering how to get an even roast.
    The inside of the Whirley has two thin(ish) wire arms that stir the beans. Obviously they were designed to shift popcorn around, not coffee beans. I have some doubts about how effective they are if I just stir by rotating the handle and have tried to counter that by lifting the pan off the stove every minute or so and giving it a careful shake - the careful bit is because the whole thing seems a bit flimsy and Im worried about the lid coming off and creating instant kitchen chaos and an ensuing ban on any further roasting. Any advice would be gratefully received.
    Jeremy
    Oct 2011
    Perth, WA
    330
    Re: First roast
    oh wow yes
    id say 2 thin wire arms would not be agitating the beans enough to provide a nice even roast.
    looks like some modification to help agitation of the beans would be a good step to take. perhaps making some sort of paddle attachments?
    Jun 2012
    30
    Re: First roast
    Quote Originally Posted by 5A535B5959360 link=1339739095/11#11 date=1339909004
    ... perhaps making some sort of paddle attachments?
    Calling all CSs. Any suggestions?
    Jeremy
    Oct 2006
    504
    Re: First roast
    you might want to check out the couple of threads on correto and KKTO roasting systems
    I think in one of the KKTO threads there is some discussion on bean agitation, paddles and so on which might be helpful in modifying your whirly
    Mar 2012
    95
    Re: First roast
    Considering your lovely looking coffee hardware in the background, my suggestion would be making the leap to a Coretto system.
    You can find a suitable bread maker for ~$20 from gumtree or op-shop, and the ozito heat gun is ~$30 new at bunnings. That is all you really need, and something to fix the heat gun to. You would then get good, consistent, even roasts, and you can do up to 500g at a time. Then you can concentrate on the actual roast rather than the physical action of keeping it stirred, that whirly looks like hard work on the wrists after 20 mins.
    Jun 2012
    30
    Re: First roast
    Thanks Phrosty and Kite (and for the kind words about the toys in the background)
    I have a hunch that my birthday and an FZ-RR-700 may be coinciding so Ill probably look at a temp fix for the Whirley for the next month and a bit. It definitely needs a better stirring mechanism and Ill see what paddle ideas are floating around. But my main concern with the Whirley is how light it is. When playing with fire, I prefer something with a bit more weight and stability.
    Im definitely going to read up a bit more on the Correto and KKTO.
    Cheers and thanks for the advice.
    Jeremy
    May 2012
    8
    Re: First roast
    Hey JayRayMe, it looks like weve started roasting with the exact same equipment at around the same time. Ive done 3 roasts on the whirly pop, the first 2 roasts I did blind without a thermometer.....both were bad. I ended up buying a thermometer off ebay and drilling a hole in the lid of the whirly pop....works a treat.
    My last batch is by far my best.
    An even roast is possible in the whirlypop. I agitate quite quickly alternating directions every 30 seconds approx. Im not sure why by alternating directions is the key to an even roast Im told.
    Ill try upload my last batch for comparison. Its good fun.
    Jun 2012
    30
    Re: First roast
    Behmor Coffee Roaster
    Quote Originally Posted by 416660737B757A667365736B61120 link=1339739095/16#16 date=1340089999
    Thanks Straight. Your speeded-up-reverse-Whirley could be just the move that Ive been missing. Ill give it a go before trying any modifications to the pan.
    I have yet to try making coffee with any of the three batches Ive roasted - I was giving it five days post-roast, and an extra few days for the Indian Monsoon Malabar.
    How have yours turned out?
    Jeremy
  1. Replies: 81
    Last Post: 6th September 2013, 10:36 AM
  2. Cafe Startup Question: Self-Roast or Outsource Roast?
    By mirx in forum General Coffee Related...
    Last Post: 30th May 2011, 01:14 PM
  3. size of roast effects on  Gene Cafe roast tim
    By herbie in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st April 2007, 10:30 PM
  4. single roast...3/4 roast...double roast
    By lucinda in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 5th January 2007, 04:47 PM
