Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Andy
Thread: Advice on roasting Jamaican Blue in Behmor
    Sep 2009
    67
    Anyone got any tips on doing this before I accidently burn $96/kg of beans to a crisp?
    Nov 2011
    120
    Re: Advice on roasting Jamaican Blue in Behmor
    I would suggest that you be very familiar with the Behmor before placing JBM init. I am assuming that you have at least 20 to 30 roasts under your belt? I am nudging over 60 roasts and if it were me I would be watching it like a hawk!
    Good luck but I would be doing a small roast of say 250g and 1IbP4C setting. Will be interested to see how this pans out :)
    Dec 2010
    Atlanta, GA USA
    54
    I have been roasting JBM for 2 years in the Behmor. I have had best results with lower size roasts and roasting at P3 (1 pound setting). I now roast 240g batches, but did 285g last year.
    Here are my recent notes:
    "First outliers of first crack at 4:00
    Rolling first crack at 3:40
    Set timer for 10 seconds - when timer goes off, open door fully
    Set timer for 30 seconds - when timer goes off, close door
    Set timer for :25 with door closed, then open door for 15 seconds
    Then do it again ...
    Then press cool to start cycle
    After 1 minute, press OFF, remove beans to external bean cooler
    Then restart Behmor by pressing Cool
    Wait 3 DAYS for roasted beans to mature"
    Mar 2004
    Internet
    16,845
    Blog Entries
    1
    Nice detailed reply rgrosz78, the only gotcha is that you are using a 115v roaster and the 240v one does work a little differently. Could be a good guideline though.
    The JBM is expensive but once you get over that they are very easy to roast and you should get a good result first time.
    If it was me...
    200g - 1/2 pound / P2 / Start
    Keep a close eye on it towards the end of the roast and hit cool 45-60 seconds odd after 1st crack, it should coast into the edge of second crack
    A 200g roast is "only" $20 of beans, not too spooky a risk if you look at that way.
    bpovazan likes this.
    Dec 2010
    Atlanta, GA USA
    54
    Quote Originally Posted by 59767C61180 link=1340553302/3#3 date=1340587586
    Nice detailed reply rgrosz78, the only gotcha is that you are using a 115v roaster and the 240v one does work a little differently.* Could be a good guideline though.
    Right, Andy! My 115v Behmor roasts very slowly - over 200 roasts and 2 years old.
    Jul 2007
    539
    I stuffed up most of my roasts of it. Only had 1kg so could only do 4 x 250gm roasts (this is in a baby roaster, not Behmor though). My best roast was the lightest batch, so my advice would be to not take it too dark, stopping before or just on first snaps of 2nd crack.
    Mar 2011
    7
    I couldnt find much advice on a behmor roast for this coffee when i did it a few weeks ago, the one thing i could find suggested a p5 1 pound D with 350g batch, the method also suggested winding the time down to 20mins before starting the roast then adding the time back as needed. (unsure what purpose this served)
    Roasted without a hitch, pulled at first signs of 2nd crack.
    Tastes phenomenal, one of the best Ive had in quite a while.
    Right up there with Bani Ismail which is my all time favourite.
    Will try Andys P2 method next time for sure. :D
    Dec 2010
    Atlanta, GA USA
    54
    Behmor Coffee Roaster
    Quote Originally Posted by 7659534E370 link=1340553302/3#3 date=1340587586
    The JBM is expensive but once you get over that they are very easy to roast and you should get a good result first time.*
    If it was me...
    When I started roasting JBM in the Behmor, I asked several experienced roasters. They all said this is coffee needs a slower ramp to first crack than most other coffees.
    In particular, those roasters said NOT to use P1 - since that has the fastest ramp to 1st crack of the various Behmor programs. There is very little difference between P1 and P2 - they both ramp very quickly to 1st crack.
    So I am still recommending P3 for this bean. I also tried P4 and P5, but those were a bit TOO slow.
  1. Jamaican Blue Mountain
    By meander in forum Cup Tasting Room
    Last Post: 15th March 2010, 11:38 PM
  2. Kona & Jamaican Blue
    By afton in forum General Coffee Related...
    Last Post: 21st July 2008, 06:53 PM
  3. [m]: Where can I buy some Jamaican Blue Mountain?
    By TC in forum General Coffee Related...
    Last Post: 1st July 2008, 05:43 PM
