Results 1 to 6 of 6
Thread: Roasting the Yemen
    Jul 2011
    63
    Roasting the Yemen
    Put some Yemen in the Corretto this evening. Applied a little more heat than usual, First crack was rather subdued (10mins) - didnt really roll much. Second crack 5 minutes later, a bit more of a roll and a little bit of smoke - pulled at CS9. On inspection an uneven roast with a number of very light beans. Is this normal ops for the Yemen: does it roast uneven?
    On a separate note two stones the size of small beans, concrete in colour, were spotted while cooling.
    Mar 2004
    Internet
    16,844
    Blog Entries
    1
    Dry process, very uneven, very ugly, very yum!
    Works well at CS10 too, more of the big cocoa comes through
    Only 2 stones? Check again, you missed one
    Jul 2011
    63
    Thanks Andy,
    I chickened out and pulled it when it started to smoke a bit, guess rather a bit under done than over. What do I do with the runt beans - take em out or leave them in? Your preference?
    Senior Groupie LindaD's Avatar
    Bacchus Marsh, Victoria, Australia
    450
    Quote Originally Posted by paulvin View Post
    Thanks Andy,
    Hi Paul!
    Don't let the smoke put you off. This is normal for when it goes into the start of SC.
    Andy is right. About CS 9-10 is perfect for these, and leave them sit for at least 7-10 days. (if you can wait that long! )
    Runt beans. Most of what makes up Yemen is sort of runt looking. Leave them in. I have never removed any of them.
    Just a bit of advice BEFORE you actually cook them. Screen for stones/concrete. Some are real hard to spot even after roasting.
    -Linda
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    943
    I also roast mine to CS 10 and yes I have found several stones and yes I have missed some. They don't affect the taste
    Jul 2011
    63
    Behmor Coffee Roaster
    I must respectfully disagree. Stones affect the taste terribly. They destroy burrs putting grinders out of action. Grinding beans with a hammer while awaiting replacement burrs tastes terrible.
    On a separate note: The yemen is incredible.
  1. Advise on roasting Yemen beans please.
    By NakiChap in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 30th September 2012, 09:48 AM
  2. Tips for roasting Yemen Mocha Sanaani?
    By webby in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 13th May 2012, 12:08 PM
  3. Help roasting Yemen Bani Ismail
    By SamR in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 19th November 2008, 12:06 PM
  4. Roasting Yemen in Genecafe
    By scott_ramage in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 5th October 2007, 10:39 PM
