Results 1 to 3 of 3
Thread: Roast monitor software - different data logger
    Feb 2009
    17
    Morning all,
    I have an Omega data logger that I would like to run with the roast monitor software. Does anyone know what line I need to change so it is recognised as it still looks for the old data logger.
    Thanks in advance,
    Senior Member insomnispresso's Avatar
    Dec 2011
    136
    Unless someone chimes in that its possible, I don't think the CS roast logger is compatible with Omega DMMs?
    I base this on the fact that the Victor 86B DMMs that most people here use has this horrible closed "HDI API" implementation for the USB reading (it sends a hex string with the value of the actual... I'm going to say "liquid crystal display blocks" to the laptop which is then decoded, yuck!) and I don't think other DMMs do this. Hence why the CS logger is seemingly the only one that supports the Victor DMMs. But the question is if the CS logger has a driver forthr Omega and I think it doesn't...
    In any case you can use Artisan as an alternative, pretty sure that supports Omega.
    Feb 2009
    17
    Behmor Coffee Roaster
    It does and I am using it now but having to re-learn after initially using the victor (is that who makes the little yellow units?) up until now.
    Will watch for any responses while continuing with the artisan.....
  1. USB Temperature Data Logger - RML (Roast Monitor Language)
    By Andy in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 24th January 2019, 01:16 PM
  2. CS USB Temperature Data Logger - mac compatible software?
    By joe_tynan in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 17th June 2009, 03:30 PM
