Results 1 to 6 of 6
Thread: Popper internals safe to handle after removal of plastic?
    Member Aleanbean's Avatar
    Dec 2012
    Maroochydore, Queensland, Australia
    35
    I'm fairly sure it should be fine (after cool down) but don't really want to find out the hard way.
    Appreciate any help!
    Dec 2010
    Toowoomba QLD
    417
    Hi Aleanbean,
    I would strongly recommend you get someone to look at it that knows what they are doing. There is very rarely a second chance with main electricity and "fairly sure" is not ok.
    Having said that, if you do find the said someone, its pretty straight-forward to make sure its safe.
    Pete
    Sep 2011
    Canberra
    145
    As long as it isn't plugged in at the time, there typically aren't any large capacitors maintaining potentially dangerous levels of charge in a popper.
    Dec 2010
    Toowoomba QLD
    417
    Agreed taco, but there are heater coils at 240 VAC close to metal casings that can get disturbed on dis-assembly, so ensuring that the earthing is ok is essential.
    Pete
    Dec 2012
    35
    I've been zapped twice before (once by accident and another time from having mains on when doing electrical work). It's not fun!
    Dec 2012
    Balgownie
    23
    Behmor Coffee Roaster
    I got a massive kick when testing the unit I built ,and I have been working as a sparky for a few years now , play carefully
  1. Rocket Porta Filter Handle Removal
    By fg1972 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd April 2017, 06:35 AM
  2. This is why plastic inserts in your handle are bad...
    By nwood in forum Brewing Equipment (non-machine specific)
    Last Post: 19th April 2013, 09:04 PM
  3. 6910 Group handle Plastic Insert
    By Moray in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th March 2010, 08:00 PM
  4. Replies: 11
    Last Post: 20th May 2009, 08:20 AM
