Results 1 to 7 of 7
Thread: Roasting robusta in a blend
    Senior Member brokenvase's Avatar
    Aug 2012
    Chapel Hill, QLD
    273
    Do you all roast say 10-15% of robusta in your blends? If so, do you blend them green and roast together with your other beans? I read somewhere that robusta roast profile is slightly different. But I can't really just roast 60g of beans in my corretto. So I've just been tossing them in with my other arabicas anyway. To experiment... I mostly do medium roasts... Rarely to CS9-10..
    Or are my assumptions and use of the robustas wrong?
    Jul 2011
    73
    Yes. All my blends are all in pre-roast blend. Couldn't be bothered trying to individually profile and roast separately up to 5 different beans. Besides, as you noted, it's not really practical.
    Amanda
    Coffee Nut fg1972's Avatar
    Jan 2012
    452
    I've been doing mine separate to get each different bean exactly how I like it.
    I'm roasting once a week and to make it practical, I'll roast 2 or 3 times the required quantity of Robusta and use it over 2 or 3 weeks.
    I find Robusta tastes better after it has aged at least 1 week so this method allows me to always have 1 -3 week old Robusta to use in my weekly blend.
    Dec 2010
    Atlanta, GA USA
    54
    Quote Originally Posted by fg1972 View Post
    I also roast my component beans separately, then blend afterwards. I freeze the remaining roasted coffee for use in subsequent blends.
    You may be using your robusta too soon. Based on what I have read, robusta benefits from several months of aging:
    My 6-Month-Old Robusta - Coffees; Home-Barista.com
    I recently purchased some "high quality" robusta, which I have roasted, but not yet tasted. I put "Do not use until April 1, 2013" on my aging robusta. Nice for April Fool's Day surprise.
    Dec 2011
    PRL
    2,635
    I roast the robustas 1-2 weeks ahead of the blend that I intend to put them in . The rest of the beans in the blend are roasted together. The robusta definitely needs a little extra resting time (but I sure as heck aint freezing it). Any left over robusta beans I add on an ad hoc basis (in small quantities) to whatever I'm drinking.....to see what works.
    Jan 2012
    452
    Am currently roasting weekly and begin consuming the coffee after it has rested 1-2 weeks.
    Robusta is roasted every 3 or 4 weeks as the required weekly quantity is too small to do weekly.
    I've been roasting all my origins separately for a few months with fairly good results.
    I want to now try roasting the Robusta weekly keeping it consistent with the other beans.
    Since roasting one week's worth of Robusta in the Behmor is not practical and am thinking of roasting the Robusta with one of the other origins.
    In addition to the Robusta, my inventory consists of the following beans;
    Java Banyuwangi
    India Elephant Hills
    Ethiopian Gambella Sundried
    The question is which of the three above would better suited to roast with a small quantity of Robusta?
    Dec 2010
    Atlanta, GA USA
    54
    Behmor Coffee Roaster
    I used some Robusta last month, but it is very strong compared to my other coffees. I limit it to less than 5% of the total blend - otherwise you will overwhelm the flavor of the other coffee.
    Based on my experience, I do not pre-blend beans before roasting. Different green coffee beans roast faster than others, so you may over-roasted (or under-roasted) beans as a result. If you actually time the roasts of the separate beans and they are similar, then blending may not be a problem.
    I tried pre-blending three coffees for some Red Sea blend: Yirgacheffe, Sidamo and Yemen Mocha. Normally I would roast each of these (separately) to about 2:30 after the start of 1st crack. I could tell a difference when I roasted these beans together - I preferred the separate roasts.
  1. Robusta blend.
    By Yelta in forum Blending Room
    Last Post: 8th April 2013, 06:57 AM
  2. do you blend before or after roasting
    By joe_tynan in forum Blending Room
    Last Post: 4th December 2009, 06:47 PM
  3. Wood fire roasting + Robusta
    By flynnaus in forum General Coffee Related...
    Last Post: 16th August 2009, 08:03 PM
  4. Roasting robusta beans - comments solicited
    By Felix in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 29th November 2007, 10:54 PM
