Results 1 to 8 of 8
Thread: IR Thermometer for roasting - emissivity of coffee beans?
    Aug 2010
    158
    I've been using an IR Thermometer for roasting for a while, as suggested by several people on this forum. It gives reasonable repeatability for a cheap gadget, no more than 2-3C difference on repeat sampling. The main issue is accuracy - first crack starts at 220C and second crack at >240C depending on the bean, which clearly doesn't correspond with the usual parameters. The IR thermometer is one of those where the emissivity can be set, it comes pre-set to 0.95, so I suspect this is the issue. I can't find a reference for the emissivity of coffee beans anywhere though. The emissivity for wood is 0.7 - which seems to be as close as I can get. Any suggestions?
    Mar 2004
    Internet
    16,845
    Blog Entries
    1
    My suggestion would be to use the CS USB Datalogger with probe CoffeeSnobs - BeanBay
    The IR non-contact method just won't work as well as a contact one with logging and live graphing using our free software.
    Not much help to your actual question though.
    Aug 2010
    158
    Thanks Andy, I explored the thermocouple/datalogger option a while ago and general consensus was it wouldn't work with the "brikkie's mixer" style of roaster I've built. The other issue would be the Mac compatibility - I'd have to run a microsoft parallel on the Mac.
    Senior Member Vinitasse's Avatar
    Aug 2010
    Mornington Peninsula VIC
    1,251
    Quote Originally Posted by habahabanero View Post
    You might want to try Roast Logger. It's also free to download and use and is multi-platform compatible... including Apple OS-X w/64 bit processors. You can easily find it via Google
    Senior Member speleomike's Avatar
    Nov 2005
    935
    Hi
    Are you measuring through glass? That will effect your result depending on what how your IR measurement unit works (IR diode or bolometer etc) and what wavelength (short or long) is being used. I'd suggest manually calibrating your device by using a thermocouple in the bean mass sorta like this:
    Code:
    your IR detector looks
    at pan trough glass
    ----------- glass plate
            /------------------thermocouple in pan
    \______/_/ pan
     heat
    Mike
    Aug 2010
    158
    Hi Mike, I'd thought of calibrating the IR thermometer in a similar way, but the drum is a rotating billycan over an open gas burner. It has its benefits. The drum is open to allow for direct visualisation of the beans, which makes the IR thermometer useful. Due to the extreme heat spilling past the drum getting a thermocouple into the beans is unlikely without frying it - I've tried and got my hand singed in the process. There is also the issue of a constant torrent of beans hitting the probe.
    The roaster was built on the cheap, and gives me excellent bang for my buck. I posted some pics in a previous thread, http://coffeesnobs.com.au/roasters/3...y-roaster.html when I initially explored the thermocouple option. I've no doubt that I could overcome the challenges of installing a thermocouple with some industrial, fire retardant insulation around an angle poise type arrangement to keep it in position, but it will be an inelegant and costly solution, and I'd rather stick with the IR Thermometer and save the money to eventually buy a Strega.
    Oct 2011
    1,376
    Re: IR Thermometer for roasting - emissivity of coffee beans?
    I wonder if the open flame might affect the reading?
    Petroleum production facilities use IR flame detection, and one of the drawbacks is false triggers from things such as sunlight reflecting off pipework...
    Different kettle of fish, but who knows?
    I also wonder if the emissivity might differ as the beans roast?
    Failing that, perhaps you could calibrate it in someone else's roaster who has a thermocouple?
    In any case, repeatability is ultimately probably more important than accuracy.
    Nov 2005
    935
    Behmor Coffee Roaster
    Hi habahabanero
    Having seen the link to your roaster I can see why you are using IR. Neat roaster, very innovative. What Mr Jack says is spot on - just roast at a temp that gives good results and use the IR temp to make that reproducible. Doesn't matter if the reading is not too accurate. I'd Good luck saving for a Stega :-) wow.
    Mike
  1. Coffee beans only tan in colour after roasting
    By Elizabeth in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 26th February 2013, 11:29 AM
  2. Suggestion for coffee snobs re selling a thermometer
    By Mazdan in forum Milk Froth and Bubbles
    Last Post: 21st October 2010, 08:51 AM
  3. Re-roasting Beans
    By ChrisMug in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 2nd June 2009, 03:42 PM
  4. Roasting Different Beans
    By Secksy in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 22nd October 2007, 12:14 AM
  5. re-roasting beans
    By Sullo in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 19th August 2007, 09:39 PM
