Results 1 to 31 of 31
Like Tree2Likes
  • 1 Post By DesigningByCoffee
Thread: S.O / Blend Roast Sampling Techniques?
    Aug 2008
    Millthorpe NSW
    2,038
    Hi fellow thirsters for knowledge (and coffee :-)
    I've been playing around for about 2 years with the corretto roasting caper, and have finally reached the place where I have a 'generic' roast profile that allows me to get every roast to a standard that is pretty good in the cup. Whether S.O. or blend, they seems aromatic, smooth, sweet and flavoursome. Sometimes I'll go a little darker (+2°) sometimes lighter (-2°) but always based on this baseline profile (ramping to 12-13mins first crack, 17-18mins just on second crack).
    However, seeing the huge range of different 'profiles' people use for different beans 'to get the most out of them', I'm wondering if anyone is willing to share some basics on their technique for deciding what will get the most out of a bean? Why go to a 9min roast for a MTE bean?
    Is sampling as apparently simple (as I saw once on youtube) as using the one roast profile and sampling beans before, during then after second crack and trying them all for each SO bean?
    Or do some roasters have a southern/african/central base profile that they then do above?
    How do you know if you're not getting the best out of a bean, when it tastes good - but maybe could be better? I've learnt with practice that fiddling about too much with a good profile seems to go pear shaped - but don't know for sure I had a laugh!
    What do you do?
    Cheers Matt
    Aug 2008
    Millthorpe NSW
    2,038
    Sorry
    Maybe that was a bit long winded & confusing!
    Here's the scenario. You pick up a bag of Mudgee Monsoon Malabar or Bathurst Bourbon AAA that you've never roasted before…
    What's your process of 'testing' the best roasting technique for that particular bean? Do you have a standard go-to system?
    Also - why did I had a laugh change to "I had a laugh" in the above post! Big brother is watching!
    Dec 2010
    Toowoomba QLD
    417
    Hi Matt,
    Not long winded and confusing, just deserving of a good answer - great discussion topic I think! I'll try and get round to posting a reply today.
    Pete
    Feb 2012
    Central Coast NSW
    682
    I have only been on the corretto for a year or so now. I cant really answer your more specific questions.
    I have thought more recently about going down the temperature measurement route with the products available in BeanBay.
    However after much trial and error I have got a standard method down pat, using my senses, time and partial / removable covering, aka small plain steel pizza tray.
    My heat gun stays at a set height. It only has high and low setting, I only ever use the low setting, unless on the odd occasion I feel I need to get a bit more heat into the roast briefly.
    I keep the amount of greens the same at 500g.
    So with a new bean I will hit it with my standard method and watch closely how it behaves. If it was a bit finicky, I will take some notes so I can remember for next time. I then add to that what the end result tastes like and from there I know where I can make slight adjustments in my roasting process the tweak it.
    I generally do 2 or 3 roasts of a SO before I think about blending it. If I really like it as SO I usually don't blend it, just play with its roasting profile and how early I pull it before SC. I like to try and finish a bit earlier before SC to see the difference. However this usually ends up better for Aeropress or Cold brew.
    I am pretty happy with where I am at and I find it easy to get repeatable results or make small tweaks as needed, which are time and temp adjustment is made by how much / how long covered for.
    Like you, every bean seems to turn out pretty dam good on my standard go to method, even if I know that something could have gone a bit better. Adjustments can always be made in the brewing process as well. If I am happy with how the roast goes the first time, next time I happily go sit down and read the paper on the ramp to FC.
    My standard method is.
    30 secs preheat - extend this to 60 - 90 in colder weather.
    Beans go in with no cover for 4 mins. - if I want a longer ramp time to FC I will lengthen this.
    Cover goes on with a small gap for heat gun nozzle, until nearing the end of FC, - adjusting the opening slightly results in a less intense heat to FC, this is an interesting variable. If a bean ends up with some slight tipping, I can significantly reduce or eliminate it next time by opening it up a bit.
    After FC has wound down cover comes off for 1 minute then goes back on. - some beans need longer, some shorter to reach just prior to or very first snaps of SC in as close to 5 mins as I can get it. I like this 5 mins to be from rolling FC.
    Overall I generally don't deviate to much from my set method, the results are usually pretty good to fantastic / excellent. Where you would have to hunt around and pay a pretty price to find something better from a cafe.
    I will also mention that all my taste testing is usually in the form of straight espresso heading toward ristretto range. However I do usually enjoy a piccolo once I am happy.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,885
    Quote Originally Posted by DesigningByCoffee View Post
    What do you do?
    Cheers Matt
    Been roasting with a Coretto for about 3 years Matt and my profiles are quite similar to yours.
    I find all beans respond pretty well to this profile, sometimes, but not often, minor temp tweaking takes place.
    My weekly roast is 725 grams of green.
    Start at room temp, heat gun set at between 500 and 550c, depending on time of year.
    Take it to FC from the starting temp approx 14 mins then drop temp by approx 50c.
    Depending how dark I want the roast I usually stop it after approx 19 to 20 mins @ between 225 to 230c.
    I buy at least 2kg of any one variety and go for a full batch 725g for the first roast and roast all new varieties as described above making adjustments on subsequent batches.
    "How do you know if you're not getting the best out of a bean" guess this doesn't really have a definitive answer, however I am, and those that partake of my brew are more than impressed.
    FWIW here are a couple of pics of my setup, not pretty but very affective.
    Aug 2008
    Millthorpe NSW
    2,038
    Thanks all
    Sounds like we all have a fairly similar approach both in roasting techniques and the 'tweak the last few degrees at the end' system which seems to work pretty well for espresso across the board.
    I guess I'm intrigued to know whether all the occasional comments about certain beans (hard african bean so get the oxy out - lots of heat early - gently gently at the end etc etc) actually come from very different profiles giving very different results.
    I've played with lots of variation of three basic profiles:
    1) lots of heat at start - then let it taper off ie no heat ongoing heat increase
    2) start gentle, gentle ramp as you go (my most successful technique)
    3) really slow for a fair while, then ramp hard
    All of these can be 'shaped' to give identical times & CS colour rating - but give very different results in the cup. My everyday profile works well - brilliantly for pre-blend Mocha Java roasts. But some other blends or SOs it doesn't seem to stand out as much.
    Is this profile - or just beans I don't rate? I just wonder if some beans respond better to any of the others profile? I don't play too much any more as I'm afraid of poor results - but if you don't experiment, you might also miss stunning results! Ohh the conundrum!
    Jun 2007
    Kiama NSW Australia
    59
    Hello People,
    Thanks Matt for starting this thread and to those who have replied so far, very interesting.
    It sounds to me like these approaches are all driven by experience with each particular process and the feedback given by the bean and the resulting brew. Almost an art to get nailed down but then repeatable one's it's nailed. Knowing nothing about roasting and given, with little doubt, that the end product for you all is indeed pretty good, I can't help thinking that "following your nose and adjust as you see fit" achieves good results. Is this a reasonable description?
    If so, I'm left wondering about Matt's questions:
    Is there one and how to I know I've found it?
    Sounds like Matt has tried varying what he is doing but can't improve on his own "best".
    Great questions Matt, and something I can imagine myself wondering. Hard to find in isolation though, but there may be a way to find out.
    Assuming though that you haven't all become waaay tooo accustomed to how your own coffee tastes, which would be hard with the coffee shops everywhere, for reference purposes, to keep you all on the same coffee wavelength. An interesting experiment would be for you roasters to start with a particular agreed upon bean, roast them to suit yourselves, and then pass them between yourselves just to see how they compare and whether they are similar.
    Seems like this is something friends who roast would be doing all the time but it would be interesting between half a dozen or so experienced roasters who all roast in isolation using the "follow your nose and adjust according" approach.
    So, do experienced home roasters, given time with a particular bean all end up roasting that bean in a very similar way so it produces the same sort of flavours in the cup, given that it's pulled the same? Or is it just way to complex and variable a process so that six roasters will inevitably hone in on six distinct excellent, and repeatable, ways to roast the same beans?
    Cheers!
    Rob
    Aug 2008
    Millthorpe NSW
    2,038
    Hi Rob
    Great feedback - thanks!
    It's interesting, I have actually done some roast swapping recently with Sando for that very purpose. It was a really interesting process.
    We swapped both greens & browns (we had pretty different collections!) then roasted & returned half. We both have very similar roasters - but achieved very different results in the cup due, mainly due to the fan speed used. But well worth the experience!
    Matt
    Aug 2008
    Millthorpe NSW
    2,038
    Hi all
    Development - here is a case in point…
    I've developed a great profile for my preferred pre-blended Mocha Java variations. This roast was particularly good! (see profile 1)
    But I've been running all the SO base beans through just to try and separate their individual flavour characteristics using my same basic profile. Recently, I've done this with the Indian Elephant Hills…
    Almost identical profile, same drop point (225°) - but as a doppio this is as sour as all get out! (very third wave :-)
    So, my initial idea is to extend the drop temp to roast a little darker (say 227°) which has worked really well in the past with Mexican beans. This would take this bean into second crack - rather than just on/before.
    But - the key question for this thread - are there any other profile tweaks you could consider try to get the best out of this SO bean?
    Hmmmmmm… what would you do?
    Matt
    16,862
    G'day Matt...
    Your No.2 technique is where I will always start with an unknown bean. Depending on whether it is a hard/soft variety, I will tailor the profile to suit but generally, harder beans will get slightly more heat than softer ones. The main thing though, is to do this with smallish batches until the end result is where you like it most and that's the one I thereafter stick with. Doesn't need to be made too complex a routine, so long as you have a plan and record all of your results (which I know you do)...
    P.S.
    Each batch profile should taste pretty darn good in the cup on it's own, no good trying to blend batches where one is sour and the other is too deep, for example. It's probably just my palate but I always seem to focus right in on a defect when it's there, and then that just does it for where that blend is concerned - In the bin it goes...
    Aug 2008
    Millthorpe NSW
    2,038
    Hi Mal
    Long time no see! Great to see you back :-)
    I think I see where you're going. So does this mean that you tend to do faster, harder roasts for harder beans (say Mexicans?) by using a similar technique to normal just with slightly higher temps across the board? This is the kind of stuff I'm wondering.
    With my profile & technique now I can basically achieve a very similar shaped roast profile but compress or lengthen it (basically squashing or expanding the graph) by lifting or lowering the temp inputs. So if I had a harder bean, increase all my inputs by 10°, which would give a higher temp input but would compress the profile & shorten the overall roast by 1-2 mins? The softer beans - stretch it out?
    I guess though there's the difference between sour and acidic? A lightly roasted central might be too bright for espresso on its own (you might roast it darker as a SO), but could add some nice contrast to cut through a deep roasted Ethiopian? I had an amazing pre-blended roast of 60/40 Yirg & Mex - looked like dark & milk choc peanuts! But tasted soooooo good… :-)
    Lots of food for thought - appreciate your input!
    Matt
    Dec 2010
    Toowoomba QLD
    417
    Hi Mat,
    Nice questions as usual. I had a look and a think and always get confused because I roast with a modded popper and have total roast times of around 14 mins at most, so comparing and thinking about your roasts is difficult for me, but I'll take a shot.
    I wouldn't have expected such a different result when roasting the components separately, but what other beans were in the blend? Were they all sour when roasted on their own??
    I have played around with the drying phase and don't notice much (or any) difference at all, provided I stay below 150C until things are evenly yellow and get to that point in around 4 - 5 mins and keep the RoR positive, then things go ok. I'm pretty sure you can hit them hard at start and not worry because the moisture content is so high. I've heard something about an "expansion wave" that can happen if you dry too fast, but haven't found much detail about that.
    So sorry, can't really offer and advice from my limited experience, but ...
    I struggle with how long it takes to try this stuff out properly. What I mean is, assume I've got a profile that works ok but produces nothing special. So I try an adjustment (longer after 1st, longer through 1st, quicker to 1st, whatever) and then cup the two (original and adjusted). Might be able to pick a subtle difference, might even go to a triangle test to make sure. But then try it as espresso drinks (which is what I drink), with only one grinder is difficult, but doable. Say I think the new profile is a bit sour but there's a nice fruity flavor underneath I haven't got before, I think perhaps if a pull a shot a bit hotter I might get something great. So I up the temp by first crack and try again, or perhaps if I down the dose and fine the grind the increase in sweetness will overpower the sourness but I'll get that fruit as well .... and on we go. To get a definitive result for a roast designed for espresso drinks takes a long time.
    Anyway, rambling a bit, might try and get more specific in another post.
    Pete
    Aug 2008
    Millthorpe NSW
    2,038
    Hi Pete
    Hmmm that's interesting!
    I certainly haven't even played with brews temps! My E61 seems to limit that on-the-fly adj anyway :-)
    I suppose one of the great advantages of the popper is the smaller batch sizes, allowing the chance to run small batches quickly - my minimum corretto roast is 350g, which is a weeks worth - so a long time to drink a bad batch!
    Quote Originally Posted by Pete39 View Post
    Hi Mat,
    I pre-blend all my roasts, due to the batch size constraints (a four bean blend would take 2 hours to roast and last for a month!) so it is hard to separate the flavours for each. But in this case, you go in with the understanding that some beans will be darker roasted and some lighter in the blend - which might not be ideal for each as a SO but can work brilliantly together when it is in the zone. So my fav at the moment is the Mocha Java++ (MJ predominately + MMG + Central) which gives a great MJ with some MMG sweetness + light central zing. And if it works… :-)
    But I might start playing with some more SO roasts using these ideas - then I might see what I've been missing! Or at least get a better understanding of the origins…
    Matt
    Dec 2010
    Toowoomba QLD
    417
    The only reason I mentioned brew temps is because I've been trying a new profile - a bit longer up to 1st, and shorter after (just after 1st finishes). I know this sounds too light for espresso, but had some at a local here and was really surprised - nice and sweet, no hint of sourness but interesting fruity flavors. Thought at first I'd had a win, but then couldn't pull a decent shot - all too sour. Almost gave up, then tried up first crack brewing temp and things improved heaps. So I guess now it makes sense to persevere.
    So much to learn hey?
    Pete
    Aug 2008
    Millthorpe NSW
    2,038
    Too true :-)
    I've been finding that I prefer most roasts to end just before/on second crack after a longer, gentler roast (18-19mins) which then requires a finer grind, even dripping pour rather than the true 'mouse tail'. But tastes amazing!
    If I go darker (into second crack) I have to really speed up the pour to stop bitterness. I guess thats the great thing about roasting - you can not only roast to taste, but also to the sweet zone of your machine!
    Aug 2008
    Millthorpe NSW
    2,038
    Here we go - case in point!
    Just done a roast - 350g El Sal Aida. I would think that is quite a hard bean - so I've done a 'faster' ramp roast - all in the name of science! Next week I'll do the same bean - and go back to the 'normal' profile.
    Let you know how I get on :-)
    Matt
    Dec 2010
    Toowoomba QLD
    417
    Hope its amazing!!
    Pete
    Apr 2008
    Victoria, Australia
    2,095
    Pete
    Hi Pete,
    Not an 'expansion' but 'evaporation wave'. This simply describes the movement of free moisture out
    of the bean. The free moisture is driven out in a 'wave', from the inside to the outside of the bean.
    It happens if the drying phase is fast or slow. For well roasted beans tho' we're looking for evenness,
    evenness in the initial absorption of heat, the drying phase, the roasting.
    Nothing important in itself, just a term.
    I understand your difficulty in trying to get the ideal roast. For me it happened by only changing one thing at a time.
    First it was achieving a good, balanced coffee from the roast. Then it was establishing the brew temp it worked best at.
    So now, for my blends, they are all pulled at the same temp (93°C), if any changes
    need to be made they happen in the roast and/or blend ratios.
    Single origins are a slightly different matter, what works for one doesn't necessarily work for another but the same process applies.
    14 minutes is a bit fast for anything I do, tho' I know some beans work best on a quicker roast.
    If I'm roasting to the 'scouts' of 2nd crack then 16-17 mins works best with 1st crack happening @ 12-13 mins from load.
    cheers.
    Dec 2010
    Toowoomba QLD
    417
    Hi Chokkidog,
    My bad, dunno why I wrote 'expansion' - meant to link to your post with the term but forgot - apologies.
    Thanks for outlining your process. I nearly always brew at 93, which is why I mentioned the temp option above, I vary rarely change it.
    Re the roast times, I'm assuming you're not using an air roaster? If I go to 12 min for 1st crack on my modded popper, things will be flat (any other modded-popper roasters out there care to comment on this - would be really interested).
    I guess what I was trying to say above was, it would be great to learn how a "cupped" espresso roast compares with the espresso it would produce. (I assume this is what the pros can do?) Then I could roast one day, cup the next (ie, not pulled as an espresso, but cupped in the trad sense) and adjust the roast depending on the results. At the moment, I roast, wait around 5 days and then pull a few shots to see if it dials in to something really nice, check how it ages over the next few days, and then make any changes to the roast I think might improve things. So it takes a long time to zero-in on a good roast for a particular bean/blend.
    Pete
    Apr 2008
    Victoria, Australia
    2,095
    Hi Pete,
    I'm roasting with a drum roaster so my comments do need to be put in context re other types, especially air.
    My experience with cupping has been an eye opener for me.
    I've done a bit of it with some bean importers from Melbourne and have done a cup roasting workshop with one of them.
    All cupping (there), for bean character, suitability for filter or espresso, is done with the same level of roast
    i.e. a cupping roast, pulled 30 secs after the end of 1st crack.
    Cupping darker roasts was done but mainly to identify roasting faults and not to determine the shot characteristics.
    To determine the shot quality and characteristics I have always waited for 5 days and then tried the coffee,
    as espresso shots, over the following 5 days.
    I have cupped my own espresso roasts but only to determine faults like baking.
    I am doing a formal cupping session soon with one of my clients, I'll be deliberately baking a roast.
    I could post the profile for that if you're interested.
    Dec 2010
    Toowoomba QLD
    417
    Thanks for the info - much appreciated. The baked roast profile would be great to see.
    Pete
    16,862
    Hi Mal
    I still check in from time to time mate... Just keep a lower profile these days.
    It's more about maintaining a specific profile rather than speeding up or slowing down the rate, as such. Over time I've discovered that softer beans need slightly less heat input in order to arrive at desired profile, as compared to harder, higher grown varieties which don't appear to be as sensitive. Your profiles look pretty good by the way, not too fast by Corretto standards. There's some very good info on this particular subject from the Willem Boot website here... Have always found the info here to be very enlightening.
    More or less mate, within reason of course. The Willem Boot article above goes into this side of things in good detail.
    Indeed there is but I wasn't referring to acidity as such, more in reference to beans that have been roasted incorrectly that leads to genuine sourness in the cup.
    Appreciate your input!
    Just hope it proves to be of assistance every now and again...
    Feb 2012
    Central Coast NSW
    682
    Quote Originally Posted by Steve82 View Post
    What a difference almost 2 months makes. New variable HG, temp / roast monitor software and a tile to mostly cover the pan.
    I have reduced my batch size down to 300g, I find it much much easier to control and get more repeatable results. Oh yeah and I have to roast more often which is not a bad thing.
    Have been playing around a lot with different parts of the roast. My temps are consistant but seem to be 10 to 15deg lower than many other setups.
    Drying phase for me finishes around 140 - 145deg, after that browning starts (maillard zone) up to first crack 180 to 185deg. I find playing around with the maillard zone has a big impact on end results, shorter time / hotter = more kick in the acidity/fruity department, too long and I start to get more woody notes heading into baked taste. I generally aim for 4 - 5 mins after the start of RFC to get to the very first signs of SC which is where I usually finish up for espresso, its great being able to keep tight control over this delicate stage.
    The following screen shot is a good example of what I aim for now as a " basic standard " roast. Seems to produce a well balanced shot, which is what I am after. Then there is the factor of the machine I am generally using which is BES900 and that has so many parameters that can be adjusted to get the best out of the coffee anyway.
    Loving this thread by the way, lots of great input from some experienced roasters.
    Being able to control my process to the nth degree from green bean to cup has opened up a whole new world of variables to try, great fun trying all the different SO on BeanBay.
  24. #24
    Aug 2008
    Millthorpe NSW
    2,038
    Fair enough - nothing new under the sun & all that! Always appreciate forward to your input though :-)
    This was a really interesting article! It certainly resonated with me, and gave me some good info as to why the Indo/Eth roasts I've been doing have worked so well, as his description for how to roast medium beans is kind of what I have randomly stumbled onto in my input/profile.
    But the hard bean roasting description was interesting, and my exp with mexican/guat and recently ind ele hills (interestingly - is this a SHG bean?) seems to reflect this. The gentler profile I've been using leaves these beans underdone - so the question is whether I maintain my current basic profile but extend the roast into rolling second crack, just making them darker (which is what I've done in the past), or give them the berries early on (high temp right from the start rather than a gentle ramp), slow over rolling first crack then ramp again leading up to second crack like he suggests.
    This second option would seem in theory to cook the beans better inside, while not giving any 'dark roast' drawbacks like burnt/bitterness flavours creeping in at the end into rolling second crack.
    Will certainly be experimenting with this. I'm starting to roast for a few friends now - so will have more opportunity to experiment with post roast blending which will allow some more tweaking.
    Thanks Mal
    Matt
  25. #25
    Aug 2008
    Millthorpe NSW
    2,038
    Hi Steve
    That's a great profile - well done!
    It is certainly a process of fine-tuning and a good adj HG, DMM, cover and insulation really helps in getting the most out of each batch IMHO. The smaller batches help too - I normally do 350g - but as I'm going to do some more roasting I'l have to see whether I go to larger batches and what impact that makes. I have heard you can do 700g - but haven't tried it yet!
    But keep playing - and posting your successes / failures - we can all learn from each other!
    Cheers Matt
    Steve82 likes this.
  26. #26
    Aug 2008
    Millthorpe NSW
    2,038
    Matt
    Just an update. Into this bag over the last day or so, as a doppio through a naked PF & triple basket it is lovely. Fairly light body, not a heap of mouthfeel, but smooth and full of character. Hint of caramel & peanut butter. No sourness or bitterness (so right in the drop zone I reckon :-) As a FW - pretty mild.
    Lovely bean! And good roast - but if I get a chance will do another batch with a different profile to compare…
  27. #27
    Aug 2008
    Millthorpe NSW
    2,038
    Done another batch of the El Sal this week which I'll break into shortly - right on my profile line taken a little bit higher in temp but just on second crack.
    Cupping notes TK :-)
    Just an aside - the first batch has gone a bit sour - but could be brew temps with not enough machine warm up and a slightly faster pour - will try again tomorrow :-)
  28. #28
    Aug 2008
    Millthorpe NSW
    2,038
    Well, can start to make some judgements. Todays doppio, from a slow roasted El Sal batch, has lost all the 'sourness' of previous roasts, while maintaining plenty of bright, sharp acidity that centrals are often known for.
    Just and overview to wrap up. The idea was to take one SO bean, use a fast ramp to first crack, 'baseline' ramp to first crack and then slow ramp to first crack, all finishing with the same ramp to second crack and same drop point temp. Taste the difference. Point to note - my baseline profile is the one that seems to work best for my mocha/java blends (indo + eth).
    Here are the three profiles to compare:
    Fast ramp:
    Baseline:
    Slow ramp:
    Conclusion
    These El Sal (and probably other central) beans like a slower than usual ramp to first crack. This exercise just points out really that for each SO bean, a system of slow/baseline then faster roasts will allow you to clearly see the difference in different roast profile for various beans - if you can be bothered drinking the same SO beans for a month with varying degrees of success!
    Anyway, I've found the process quite interesting. My question is - has anyone else discovered any general 'rules of thumb' for roasting various origins they'd like to share?
    Cheers Matt
    BTW - that last profile looks a bit odd when you compare to the others - I had to change my RM prefs to fit some longer roast time, so it is now displaying 25mins rather than 22mins… but it uses the same template…
    Steve82 likes this.
  29. #29
    Aug 2008
    Millthorpe NSW
    2,038
    Update: that last El Sal batch was brilliant in milk. Too acidic for my tastes as an SO espresso, but I could possibly temper that with some roasting deeper into second crack. But certainly can see now how roasting different origins separately then blending would allow for real fine tuning & perfecting…
  30. #30
    Feb 2012
    Central Coast NSW
    682
    Since insulating my pan, I have tried 500, 450 , 400, 350g batches and have noticed a lot less or no difference in the end result. The 350g batch of greens is a great size, easier to control and repeat.
    I have been doing several SO roasts at a time and experimenting with different blends, sometimes just at the grinder and loving that fine tuning aspect of it.
    Really started to develop a preference for post blending, definitely results in more defined layers in 2 or 3 bean espresso blend for my tastes.
  31. #31
    Aug 2008
    Millthorpe NSW
    2,038
    Behmor Coffee Roaster
    Absolutely
    350g has been my staple size for a few years, but I'm recently having good success with 700g too, with a fair adjustment in technique.
    The biggest issue for me with post-roast blending has been not roasting enough to warrant it - but now I'm starting to 'supply' a few more opportunities are opening up…
  1. same blend, different roast profile.
    By Caftek in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 29th May 2013, 10:03 AM
  2. Help me Blend? big roast day...
    By sorrentina in forum Blending Room
    Last Post: 26th October 2010, 04:18 PM
  3. Blend prior roast or after roast that is the question?
    By Crisp_image in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st June 2009, 08:34 PM
  4. how to roast an italian blend
    By brianleon in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th July 2007, 08:22 PM
