Results 1 to 10 of 10
Like Tree5Likes
  • 2 Post By gonzo89
  • 1 Post By Alexpid
  • 2 Post By artman
Thread: E61 Group Seal too tight
    Feb 2016
    37
    Hi guys
    I have an Expobar Minore IV and the group head is too tight. I have a 8mm seal and it won't allow the portafilter handle to be put in and tightened straight at 90 degrees. Instead it only tightens to around 45-50 degrees which is annoying because it gets in the way of the steam wand. So i have to wait for the shot to finish and remove the portafilter before i can steam the milk, which defeats the purpose of having a dual boiler machine and it also takes longer to make a coffee...
    Does anybody know of a 7.5mm E61 Grouphead Seal available? Or is there any other way of getting the portafilter to tighten further (without forcing it too much)
    Apr 2008
    Victoria, Australia
    2,095
    When fitting a new group seal, it shouldn't be expected for the group handle to come to the 12 o'clock.....
    Have you fitted a rubber or silicone seal? The silicone seals available in BeanBay might have a little more 'give' than
    the hard rubber seals. There are other non Expobar seals that have different dimensions, to the 73 x 57 x 8 mm
    Expobar genuine, which come in different thicknesses... 7.5 mm /6 mm but I couldn't tell you if they would give a 100% seal.
    Feb 2016
    37
    Ive had the machine 6 months and still nowhere near 90 degrees/12 o'clock
    I'm still on the original genuine expobar seal, i might try a silicone seal and see if it helps.
    Otherwise, a 7.5mm might do the trick if i can find one...
    Senior Member artman's Avatar
    Jun 2006
    2,409
    yeah try silicone seal, they also dont bake on and are easy to remove.
    you could try sanding down a smidge if you cant find one thinner?
    cheers
    Jan 2016
    South Australia
    26
    I've had the same issue with my ECM. But they seem to squish down over a few months... Maybe one "hour" (if the handle is an hour hand in a clock) a month or so. Then they gradually get worn out and the handle can turn a good couple of hours past 12. I have always wondered if there was a 7mm seal. Next time maybe I'll look for a silicone seal too
    16,766
    Quote Originally Posted by BenjaminG View Post
    Don't need to look too far, try here for example...
    CoffeeSnobs - BeanBay - Cafelat Coffee Accessories
    Senior Member Alexpid's Avatar
    Mar 2016
    Denmark
    110
    Are the silicone seals any good compared to the standard rubber ones?
    Senior Member gonzo89's Avatar
    Nov 2012
    Brisbane
    296
    I've been using the cafelat silicone seal on my R58 since I bought it and I wouldn't go back. Seals well and has more give. Never had any trouble removing it and they do last longer than I expected.
    artman and Dimal like this.
    Mar 2016
    Denmark
    110
    Ok. Nice to know. I'll soon be upgrading my izzo alex then! Thx
    gonzo89 likes this.
    Jun 2006
    2,409
    Behmor Coffee Roaster
    Get the 8mm seal for the Alex. The 8.5 works ok but handle locks in short of the standard 6pm.
    The red also goes faster!!
    Dimal and Alexpid like this.
