Results 1 to 13 of 13
Like Tree7Likes
  • 1 Post By Alexpid
  • 1 Post By MrFreddofrog
  • 1 Post By artman
  • 2 Post By artman
  • 1 Post By Alexpid
Thread: First day with the Behmor 1600+ ... some advice please!
    Sep 2016
    Melbourne (Bayside)
    32
    Really hoping some Behmor 'old hands' can set me straight on a couple of issues as I start on my roasting journey.
    OK, so I have roasted a couple of 100g batches and they seem quite a good result, although the 2nd roast when I hit the C button, it came up with an error... all I could really do was to cool the beans.
    Do I hit the c button at the first sound of the first of the beans having its first crack, or do I wait until I hear lots of first cracking, then hit C, or what?
    I have noticed, now that I have brought the machine indoors (after having roasted twice on my deck) that the machine has quite an audible hum when powered up (but the machine in stand by/non-operational mode... is this commonplace?
    Lastly, is it really that important that no extension lead is used in conjunction with the 1600+? As the power cord is impossibly short, I can't get it to reach a power outlet if I want to roast underneath my exhaust fan.
    Thanks to all for your input in anticipation.
    Senior Member Alexpid's Avatar
    Mar 2016
    Denmark
    110
    Hi!
    All error codes are listed in the manual, so have look there.
    I press the c button at the first sounds of first crack. Still you have to really need to attend your roast to hit the cool button if the roast hits second crack.
    The humming is probably the transformer powering up, no worries there.
    Extension cord is mostly a problem in the US, where power supply is very dodgy... I bought a really thick cord, that can handle the power and there is no problem with roast times at all. Just get a good quality thick cord.
    Last thing I would advise: try 227 grams batches - 100 grams are tricky to control.
    Happy roasting!
    Kettles likes this.
    Aug 2015
    Perth WA
    461
    Quote Originally Posted by Kettles View Post
    I've often wondered about that too.
    I've tried using extension cords to reduce heat when roasting with a popper. I like to think it works but probably more of a placebo affect. There are however many people here that say extending makes no appreciable difference.
    Personally I think ambient temp will make more of a difference to Behmor roasting times than a short extension will.
    Kettles likes this.
    Senior Member artman's Avatar
    Jun 2006
    2,456
    Mine does the humming thing too.
    Was the error you forgetting to hit start at the "yes I'm still here looking after the roast" function? I set a timer as its too easy to miss unless you are watching the screen. I forget off hand what code that one is but as above they are all listed in the docs.
    I measured the voltage while using a power cord at the roaster at full power and there was no voltage drop compared to the source. This was with a heavy duty cord. The issue is mainly for lower voltage where any additional resistance amplifies the issue. If you use a decent cord that is 5m or so long I doubt the voltage drop would be significant to affect things. That's just my thoughts of course!
    Kettles likes this.
    Sep 2016
    Melbourne (Bayside)
    32
    Guys, thanks so much. Gonna do me a 227gram batch now (is that because it equates to 200gram weight after roasting or summfink??!!)
    Sep 2016
    Melbourne (Bayside)
    32
    Error was that, most probably, 'cos the thing was outdoors and the visual display is very hard to see outdoors.
    Jun 2006
    2,456
    Yeah that's why I always now just set a countdown timer to alarm when the start needs to be pressed. Haven't missed one since.
    b430m and Kettles like this.
    Mar 2016
    Denmark
    110
    Actually it relates to Behmor being american, and they still use pounds over there. So the behmor is built to do 1/4, 1/2 or 1 pound. This equals 113, 227 and 454 grams. The metric panel says 100, 200 and 400 grams, but I stick to the pounds. This works for me and my voltage.
    Kettles likes this.
    Aug 2015
    Perth WA
    461
    Same here. One day I'll hack the panel and install a speaker alarm but until then, 13:30 for a 400gm roast.
    Kettles likes this.
    Jun 2006
    2,456
    Would be great mod if you do, but the panel is all electronic ICs, Beyond my abilities. Thought of a simple timer running from start but the time changes depending on weight etc. hopefully his will be an addition to future panel iterations.
    Jan 2014
    Discovery Bay, HK
    269
    Quote Originally Posted by MrFreddofrog View Post
    If you can update a modified firmware, better to do away with the Nanny. IIRC, It is an EU safety compliance requirement that many users can do without. P4 manual not hot enough? Make it 80% or some power level you need when you enter post first crack development stage.
    Aug 2015
    Perth WA
    461
    I've been playing around with 555 IC timers recently and have discovered they are triggered by a DROP in voltage.
    So in theory, it could be connected to the LCD panel and when there is a drop in voltage, (eg flashes off/on in alarm mode) it could be used to power a speaker. That way it is totally independent of weight settings etc and will simply serve as an audible reinforcement to the LCD flashing.
    I'd love to look into it but currently don't have the time.
    Jun 2006
    2,456
    Behmor Coffee Roaster
    That would be an awesome solution.
