Results 1 to 22 of 22
Like Tree6Likes
  • 1 Post By LeroyC
  • 2 Post By LeroyC
  • 1 Post By DesigningByCoffee
  • 1 Post By LeroyC
Thread: Help - underdeveloped roasts
    Jun 2016
    64
    Hi Guys,
    I've done a couple of dozen roasts with my Behmor and have generally been pretty happy - although I always felt my resultant espressos were a little on the sour side (I don't have a particularly refined palate at this stage - although I am working on it - drank supermarket pre-ground coffee for years without complaining :-)
    I recently bought an Atago refractometer and it's been quite revelatory. I am under-extracting in a big way (12 - 15%). I have fiddled with dose, yield and time - but mainly have tried going for a finer grind to increase TDS and extraction. This has improved things but not as much as I would like.
    To cut a long story a little shorter, I then thought that maybe it was the beans. I bought a bag of commercial roasted beans from a nearby roaster and they are giving better extractions and results in the cup. Definitely less sour. Results for the Atago suggest extraction closer to the desired zone ~ 17 - 19%.
    I usually roast about 300g in the Behmor. Put it on P5 manual until about 30 seconds after first crack (~ 9 mins), then P2 manual and increase drum speed. Normally turning off (~ 11 mins) just before or at second crack. Then rapidly cool.
    I reckon I'm at about CS 8 in terms of colour. The pro-roasted beans look CS 11-12.
    My question is, is going darker a simple way to ensure better development? Or is there something else I should be doing?
    Thanks,
    Paul
    Aug 2008
    Millthorpe NSW
    2,047
    Hi Paul
    If they’re sour, they are most likely underdeveloped.
    I’d try first taking them a little darker (which is giving extra development time post first crack). Maybe go 1min post first crack before P2? Or P2 at the same time but take them into second crack a little longer? You might be surprised how much further you can go without creating bitterness…
    Then try stretching out the time to your current CS8 roast depth (also giving extra development, but not increasing caramelisation). Maybe adding few extra beans in the Behmor? Or maybe it’s less - I think it is counter intuitive on the Behmor! I’ll let a Behmor user chip in on the impact of load weight
    Cheers Matt
    Aug 2007
    279
    What espresso machine are you using? Could your water temperature be a little low? Low temp = sour
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,348
    We need more info to help you properly. What beans are you roasting and are you taking this approach every time? That's a hot roast profile you're using (which is often necessary in the Behmore), but it might be part of the problem.
    If you're using C American's try roasting 250g on mostly P1 auto, after a decent preheat of 2.5-3min (aim for a B temp reading of at least 75 before you load). This will provide decent heat at the start, but stretch the drying phase a little. The fan will drop the ET when it kicks in so a couple of minutes after this happens go to P5 manual, then high drum speed about 30-60sec before first crack. P2 & C at first crack as usual then slow the drum again before the end of rolling first crack. Hold on for a good 60sec after the end of rolling first crack then cool.
    If you're using softer beans you can do something similar but start on P2 auto. Not sure how much this helps, but worth a try.
    DesigningByCoffee likes this.
    Jun 2016
    64
    Thanks Guys.
    Quote Originally Posted by saeco_user View Post
    Profitec 700. I have it set at 94ºC (I realise that may not be happening at the brewhead)
    Costa Rican Tarrazu and Peruvian Ceja de Selva - bought from CS. I haven't been blending - generally I'll alternate 300g of either of these.
    Yes, I'm pretty much using the same approach each time. I'm not preheating - so maybe that might help.
    Sep 2013
    2,348
    Quote Originally Posted by pgseye View Post
    Thanks Guys.
    Ok, the Costa Rican is about as hard a bean as you can get and the Peru should be reasonably forgiving to roast as well. I'd say there's two possibilities:
    1. The roasts are fine, but for the level that you've roasted them to 94deg is too hot. I've heard 91-92deg is better for 'lighter' roasts when making espresso. Can't confirm this myself as I've never had a PIDed machine.
    2. The roasts are a touch underdeveloped. I've had some great results with Tarrazu beans and actually just finished another enjoyable bag the other day. Here's a pic of my notes from a batch I did a month ago. If you can decipher them you're welcome to try to replicate the result. If you need help understanding them just ask.
    Dimal and oliverm like this.
    Jun 2016
    64
    Awesome - great notes. Thanks Leroy.
    Jan 2014
    Discovery Bay, HK
    269
    You can try increasing drum speed when afterburner kicks. P2 manual is a bit too low, try P3 or even P4. Not sure what you meant by "rapidly cool" but external cooling might help.
    Sep 2013
    2,348
    No P2 manual at first crack is what Andy and Joe recommend on the 230v machines. P3 at first crack is better on the 110v version apparently. I always hit P2 and C at first crack and have found it works a treat. I also whip the beans out about a minute into the cooling cycle and cool them with a fan.
    Jan 2014
    Discovery Bay, HK
    269
    25% heat at first crack till end of roast will probably stall my roast and end up underdeveloped. We all know the Behmor is very sensitive to voltage so I suppose it will vary from setup to setup even it is the same 220v-240v model.
    Senior Member artman's Avatar
    Jun 2006
    2,456
    I have noticed with a bean temp probe that hitting P2 at first crack usually causes a stall in rate of rise. This is with 450-500g roasts, so with a smaller batch would probably be ok.
    You could use P3 as suggested by others.
    Sep 2013
    2,348
    Quote Originally Posted by JojoS View Post
    Are you using the 230v model? I thought you were using the 110v. Is it you that has done the SSR mod?
    Sep 2013
    2,348
    That's good to know. To be clear Andy and Joe recommend P2 at first crack on a 200g batch so P3 probably is better for batches of >300g. I'll have to remember that as I try to do more large roasts. P2 seems to work well for 250g batches.
    Senior Member Alexpid's Avatar
    Mar 2016
    Denmark
    110
    The last roast I did on my behmor, I combined the two. I did p1 manual with double drum speed until 1.crack. Then p2 until 1:00 min left where I pushed p3 to prevent stalling the roast
    Jan 2014
    Discovery Bay, HK
    269
    Yes I am using a 220-240v model running at 220v here in Hong Kong with an SSVR mod. I should have pointed out that OP's charge weight is 300 grams and that is why I suggested to use P3 manual instead of P2.
    Aug 2007
    279
    I read somewhere once that a simple check with underextracted espresso was to taste / test the same roast as a drip coffee.
    If this also underextracts than the problem is likely to be with underdeveloped roasts and not some other problem.
    I'll look up and try to find the source.
    Sep 2013
    2,348
    Yeah I got ya now. I'm very much in 250g batch mode so it's good to know that as I try more bigger batches I should probably use P3 at first crack. I really must get that BT probe set up so I've got better feedback on roast progression.
    Sep 2013
    2,348
    That would make sense I guess.
    Anyone know whether 94deg is too hot for espresso with lighter roasts?
    Aug 2008
    Millthorpe NSW
    2,047
    A hotter brew temp / finer grind / slower pour can help to tame a lighter roast…
    Dimal likes this.
    Sep 2013
    2,348
    Quote Originally Posted by DesigningByCoffee View Post
    Looks like Paul has tried the finer grind approach so maybe his roasts are underdeveloped then.
    Dimal likes this.
    Aug 2008
    Millthorpe NSW
    2,047
    Reckon so too
    LeroyC likes this.
    Jun 2016
    64
    Behmor Coffee Roaster
    Reckon so too
    Thanks Everyone,
    Yes, it's sounding like that.
    I reckon I'll try the P3 at first crack tweak and see how that goes.
