Results 1 to 5 of 5
Thread: Behmor: 120V vs. 220-240V
    Nov 2016
    3
    I am on the left coast of the USA and new to these forums. I have a Behmor 1600+ and our electricity is 120V.
    Reading here and there, I am getting a sense that the Behmor operates a little differently with a higher voltage. For example in this post, the forum owner writes:
    Quote Originally Posted by Andy
    I should also say...
    be careful what (and more importantly, where) you read. Our friends in America use a different roaster, different voltage and what works here won't work the same there. In the USA on a 120v roaster the temperature drop when you hit [P2] (25%) is too much, they would need to press [P3] at the same point to get a similar roast.
    And in that same thread or elsewhere I read references to scorching and tipping, which (so far as I know) the 120V version of the Behmor is incapable of. However, reading various "recipes" for roasting suggest that the roast times are about the same as what I am getting here. So, are your 220-240V Behmors running hotter than my 120V machine?
    Aug 2015
    Perth WA
    461
    Not sure but unless the thermal cut off temp is different which I doubt, I'd hazard a guess both have the same maximum capability. A 240v might reach this temp quicker though.
    Nov 2016
    3
    Quote Originally Posted by MrFreddofrog View Post
    I'm sorry for being unclear. I was not asking if 220-240V machines are capable of a higher maximum temperature, but rather if they were capable of achieving a higher rate of (temperature) increase during the roast, a.k.a. RoR. Apparently so.
    Aug 2015
    Perth WA
    461
    At 100% manual control (P5), a 300gm batch of Indian Elephant Hills at ambient temp 15C, and 70% humidity, average ROR from charge to FC was ~ 20 C/min, ie it took ~10mins to reach 200C.
    Mar 2004
    Internet
    17,208
    Behmor Coffee Roaster
    Quote Originally Posted by busyroad94 View Post
    Pretty sure the quote you found in your first post answered the question but yes, the 240v (220-240v) roaster is a very different beast to use, the owner of the company is often surprised when he is in Australia that the same profile used here will result in a much darker roast given the all the other variables are the same.
    Ergo my P2/P3 example in your first post.
    So enjoy the home roasting resources here at CoffeeSnobs but don't try and follow them to the letter or you will induce insanity.
