Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By Javaphile
Thread: behmor roaster
    Aug 2007
    39
    behmor roaster
    l just brought a new behmor from cs and can't get it to work it would not select voltage on start up and then err 7 came up . The barrel doesn't rotate either l did exactly what the instructions said am l missing something thanks in adv.
    Dec 2004
    Earth!
    15,570
    Your first stop should be Behmor tech support: Behmor Tech Support – Behmor
    Java "Support!" phile
    Rolf and nathanharley like this.
    Toys! I must have new toys!!!
    Member nathanharley's Avatar
    May 2015
    Perth
    68
    I had the same problem Greenbe, my advice is to contact Andy directly via the "Contact Us" link also, he was a great help.
    FWIW my problem was just a loose connector under the right hand side panel, on the board where the drum motor connects, no doubt it came loose during transport. Fixed it no problem, roasted over 20kgs since!
    nate
    Dec 2004
    Earth!
    15,570
    Behmor Coffee Roaster
    Quote Originally Posted by nathanharley View Post
    No, first contact Behmor Tech Support. Then if it's needed they'll pass you on to Andy along with any information he needs to resolve the issue.
    Java "First things first!" phile
