Results 1 to 18 of 18
Like Tree7Likes
  • 1 Post By Mb21
  • 1 Post By Mb21
  • 1 Post By jonjon
  • 1 Post By jonjon
  • 1 Post By simonsk8r
  • 2 Post By artman
Thread: Heatsnob and Behmor location
    Oct 2016
    Central Coast NSW
    381
    Hi all
    Im keen to try using a heatsnob to get better consistency and hoping ill learn more about roasting and what the beans are doing if install then probe into the bean mass. I know it's not the easiest mod to do to a Behmor (get probe into bean mass) but i have the people to help drill the spindle so makes it possible.
    Question for roasting and Behmor knowledge trust, will i see a benefit of getting the probe in the bean mass or is it just a 'warm and fuzzy' to measure the bean temp vs air temp?
    If Bean temp measuring is really going over the top with no real benefit over air temp is the best place to position the probe on a behmor in the top left corner of behmor wall as per Andy's instructions?
    Happy to be directed to a post and this one deleted if i'm blind and cant see the info elsewhere.
    Martin
    NJD likes this.
    Senior Member artman's Avatar
    Jun 2006
    2,459
    I think if you are going to measure temp , might as well measure the BT as itís more meaningful.
    And itís quite easy to do, I posted my wiper mod here if you do a search.
    Is it required? Not really, you can do yummy roasts in a simple way. But if you like to tinker and monitor stuff itís great fun!
    Oct 2016
    Central Coast NSW
    381
    Thanks Artman it’s was your post/thread that made we want to look at doing this so thank you
    are you still using the bead thermocouple or using at Stainless steel probe type now?
    Artman’s mid is in this thread in case helps other, post 24 onwards.
    http://coffeesnobs.com.au/roasters/4...tml#post578429
    bigdaddy likes this.
    Jun 2006
    2,459
    Still using the bead probe. The insulation has melted a bit (not sure if that is from normal use or a minor chaff fire one time) but still works fine. The bead probe is cheap to replace regardless.
    If you are going to go to the trouble to monitor temps you might as well monitor bean temp. And the mod is fully reversible with no permanent damage (hole in spindle aside).
    17,415
    And repairable using a MAPP or TF-UltraGas torch if you have one...
    Jun 2006
    2,459
    You mean repairing the bead of the actual probe?
    The bead seems to be coping fine, its the insulation that is wearing. But even with that being worn it is still functioning well, tough little bugger!
    17,415
    Just the bead mate...
    If they get a real pounding, one of the conductors will often break just behind the bead.
    Or, if the core insulation breaks down, it's often simpler to just cut the t/c cable behind the failure point and then create a new bead...
    Would take all of 5 minutes.
    Jun 2006
    2,459
    cool, I didnt realise the bead is just a "simple" weld of the two wires.
    fancy welding gear would be nice for all sorts of things, welding up nice bits for the car etc! (and the necessary skill too of course!)
    17,415
    No fancy welding gear needed...
    If you have access to a MAPP torch or similar, that's all that is required...
    Jun 2006
    2,459
    I only have a stick welder. Just had a quick google, small MAPP torches are quite cheap.
    Jan 2016
    22
    Hey Martin did you end up doing the bean mass probe in your Behmor? I'm contemplating the same issue - have ordered a heatsnob for my new Behmor but then did some more reading and I'm questioning if the ET is worth it compared to BMT? I'm still learning the ropes, but keen to understand what's going on more each roast - I may be new, but I know about myself that I'm more of a precision-gear-and-always-pondering-the-what-if's kinda enthusiast.
    If you did it, or tried both, how did you find it?
    Jon
    Dimal likes this.
    Jun 2006
    2,459
    I would just measure the BT, it would be more meaningful than exhaust temp. Its easy and reversible.
    Jan 2016
    22
    Thanks Artman. When I was saying ET I thought it meant Environmental Temp but it seems I was muddling my terms.. I was meaning bean mass probe vs drilling where Andy suggests in the HeatSnob thread to get an ambient temp of the air just above the drum.
    I guess I see the value of the bean mass temp, but it's more mucking around drilling/pilfering steel from my wiper blades/bending and experimenting for fit, etc - although I do really appreciate you sharing your method as a guide. I imagine it makes things slightly more fiddly to get the drum in and out as well?
    Dimal likes this.
    Oct 2009
    Geelong
    1,179
    Hey @artman, did you ever have any issues on your profile graph when the fan kicks in and it massively dips in the graph? Not all the time I don't think, but just today I did one roast, then the next had this dip...
    To me that suggests that the probe may have been in a slightly different spot in the second roast and caught the fan blast.. same heat was applied so that must be it...
    Do you find any position best for the probe? More smack bam in the centre or slightly off to the left?
    Edit: added the photos below, second one has that strange "dip" even though I'm attempting to replicate the same profile
    Oct 2009
    Geelong
    1,179
    Quote Originally Posted by jonjon View Post
    Hey jonjon, I've done the mod and it's great. I keep the probe/blade in the drum all the time, only need to unplug it if I want to take the drum elsewhere. Maybe initially fiddly but easy once you get used to the setup. But up to you which works for you.
    jonjon likes this.
    Jun 2006
    2,459
    YEah as above, not really fiddly at all, I leave probe in the drum, just need to swivel it when opening the drum lid so it doesnt snag the mesh if it is orientated in the wrong spot. overall it is a smooth/easy operation.
    I guess it depends on your level of "mcgyvering" and telerance to tinkering. For me it was to measure something I was measuring on the corretto (BT) and i enjoy tinkering! the side probe inside air temp would be slightly easier to execute.
    re the dip, yes I see it, I didnt think of it as the probe being in a position to catch the cooler airflow, I think it is BT temp drop temporarily as the roaster has more volume of air with the same heat input = slight temp drop. I will have to have a look at all my profiles, but prety sure i always get a dip at 7m30s when the fan kick in, although from memory its worst when the roast load is hefty and/or if its bloody cold. I also roast on manual so perhaps the one time the roaster used slightly different power at that moment?
    I know the BT bead probe is very sensitive at picking up temp, as is the roaster to ambient air. Eg on a cold night when i open the garage door during a roast the rush of cold air causes a dip in the BT temp.
    My probe is also well and truly bashed around now and the insulation has melted in a few spots, really must swap it over to a new bead one of these days - the old battered one is still going ok.
    simonsk8r and jonjon like this.
    Oct 2009
    Geelong
    1,179
    Ah right thanks for that, encouraging that it's normal haha. Yeh it was a fairly warmish day yesterday when I roasted, unless a gust of wind came at that exact moment for all my subsequent roasts which had that dip hehe.
    I think I understand what you mean about the volume of air etc.
    It's weird that it doesn't happen every time. And most roasts I'm roasting manually on P5 until later. But if it's really not an issue at all I'll just ignore it when it happens.
    I may to reconsider roasting on less windier days though, didn't realise it would have a dramatic effect seeing as though the roaster is fairly enclosed hehe.
    Thanks heaps for that
    Jan 2016
    22
    Behmor Coffee Roaster
    SO I took the plunge and modified my Behmor drum to install a BT probe. More details here. Good news is that it works!
