Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Andy
Thread: Roasting software to use on Mac
    Oct 2016
    Central Coast NSW
    381
    Hi everyone
    There was a similar thread recently about using a heatsnob on a Mac but my question is more about what software is able to be used on a Mac in case Iíve missed something. Ideally the software would be:
    ē Designed to be use on Mac ie I donít have to install software to run PC based program such as parallels.
    ē Easy to us the roasting software. I donít want to have to be calibrating settings. Download and roast if possible.
    ē cheap or no ongoing costs
    ē ideally a heatsnob able to be used as thermocouple.
    Any suggestions on software to use?
    Any experience with Typica?
    Maybe a question for Andy but is RoastMonitor ever going be comparable with Mac?
    Martin
    PMM
    PMM is offline
    Oct 2012
    Perth
    6
    Hi Martin i'm also a mac user and have used RoastLogger successfully but using the Victor 86B Digital Multimeter purchased from CoffeeSnobs. Victor 86B was used before Heatsnob so I'm not sure if it will work. The program is free and as with CoffeeSnobs own software very good. I no longer use it as I've bought a Behmor but do itch sometimes to be able to control the roast as I used to with the Coretto.
    Paul
    Coffee Nut fg1972's Avatar
    Jan 2012
    462
    Hi Martin,
    Artisan is another one that works on Mac
    Fiorello
    Mar 2004
    Internet
    17,222
    Quote Originally Posted by Mb21 View Post
    Nup.
    With old PC's and notebooks free (or close to) there is no need to ever rewrite and then support the software on a mac.
    The PC notebook in the Snobbery has done many thousands of roasts using 2 heatsnobs and it was a freebie as the battery had died and it was too expensive for the previous user to replace it.
    HeatSnob will run on old windows software too (XP, Win7 etc).
    DesigningByCoffee likes this.
    Senior Member woodhouse's Avatar
    Dec 2016
    391
    Artisan and a Yocto thermocouple is the way to go on a Mac if you want to run natively. Or you can muck around with VirtualBox to install a Windows machine on your Mac desktop, which is what I did. Though I’d probably go the former if I had my time again.
    Oct 2016
    Central Coast NSW
    381
    Thanks everyone for the replies. The hunt Ian one for an older cheap laptop failing that the trusty Mac will be moved to roasting station in garage.
    Sep 2015
    Nhulunbuy
    71
    Also use Roastlogger on my Mac that is set up on my roaster, it plays nicely and works well. For me nothing would make me own a windoze box, so i had to find something that worked on OSX.
    Apr 2009
    10
    Behmor Coffee Roaster
    I’ve used Artisan on my MacBook using a Phidget data bridge. It can take a bit of time to configure the software how you want but it works well.
