Results 1 to 13 of 13
Like Tree4Likes
  • 1 Post By herzog
  • 1 Post By artman
  • 1 Post By speleomike
  • 1 Post By greenman
Thread: Anyone ever seen this before
    Mar 2007
    56
    Happy new year and how good is it to be able to get great coffee from coffeesnobs.
    Just got to show you the state of my coffee lately,
    I have been buying and roasting green beans from here for years but i have never produced this before
    Look at the crema,Mexico el Triunfo Arabigo, roasted to around 8 with breadmaker and heat gun.
    Tastes great puck looks ok and this also happened with last roast Costa Rica Miel SHB.
    That was even better perhaps the best coffee i have ever bought.
    The only clue i have for this strange looking pour is my rocky grinder is now set to just above zero,12 years with the same grinder,well cleaned but burrs must be worn away, new burrs on the way.
    Anyway the coffee is fine, but i think its worth a look, has anyone ever seen this before because all my other shots for last 12 years were nothing like this.
    Dec 2009
    SYD
    590
    Holy smokes, that looks like toothpaste coming out.
    Iíve never seen espresso come out like that before. Is it possible you left some cleaning powder in the portafilter or the group?
    How long were the beans rested after roasting?
    Dimal likes this.
    Mar 2007
    56
    Hahah , no its not cleaning powder, the beans are around 4 days old and its 2 different roasts now, actually i hope it is a grinder issue cause its looking pretty weird, tastes is really really good though.
    I buy a decent coffee in sydney if ever im there ,so i have something to compare.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,122
    Interesting! the crema looks to be a column of foam.
    Have to say I've never pulled a shot straight out of the PF without a spout in place, is this your normal Modus operandi?
    Is it possible there is a small air leak in the system that's introducing air into the water flow, looks to be very large air bubbles in the stream.
    Oct 2009
    Geelong
    1,133
    Hahaha that's awesome! Like cheese whiz!
    I'd say it's a combination of potentially too fresh coffee, and the high pressure of squeezing that out of the small exit.
    Jun 2018
    614
    Quote Originally Posted by simonsk8r View Post
    It's got nothing to do with the orifice on the portafilter, the pressure drop across an 8mm orifice 10mm in length at that flow rate is about 0.1 Pa which is around 1 / 1000000 of a bar.
    FWIW I run both my machines without spouts and without problems.
    Mar 2007
    56
    Yelta,i took the spout off because i always pour a double shot into one cup/glass no other reason. I also wonder about an air leak as this phenom has only just started a few weeks ago, i put it down to the beans,Costa Rica Miel SHB. Icant grind any finer until new burrs arrive i'm hoping that is the cause. When i raise the lever coffee pours out just from boiler pressure and i don't need hardly any force on the lever...hardly any at all. Crema is solid and thick but lots of air...gonna get more Costa Rica Miel SHB beans though they are incredible.
    cheers
    Oct 2009
    Geelong
    1,133
    Quote Originally Posted by Lyrebird View Post
    Ah fair enough, should have prefaced with "just a guess"
    Senior Member artman's Avatar
    Jun 2006
    2,450
    Mr Whippy does coffee!
    That looks bizzare.
    Certainly looks like it is aerated. Next time do a quick vid, will give a better picture.
    simonsk8r likes this.
    Apr 2008
    96
    Quote Originally Posted by brianleon View Post
    I can't explain your fizzy pour, but I replaced the burrs on My Rocky after 13 years, went from 65 seconds for 18g of beans to 32 seconds. Also went from needing "the finest setting where the burrs weren't completely jammed together" (still too coarse) to about five divisions back from just touching.
    Then my Niche Zero arrived and I've pretty much forgotten all about the Rocky. 23 seconds for 18g, super quiet and super consistent with almost no grounds retention.
    Senior Member speleomike's Avatar
    Nov 2005
    948
    Hi
    One can find this phenomena via a Google search. Here is one link displaying it.
    This link suggests its the air that was above the puck being forced out. One normally does not see it as its inside the PF.
    And one person suggested "Extreme amounts of foam from a lever in my experience are air being forced through the puck, so likely the cylinder wasn't filled to it's ideal level."
    https://www.home-barista.com/levers/...ma-t34836.html
    And there are some links in there on bleeding.
    Certainly the video in that link above does show the same phenomenon.
    Mike
    Dimal likes this.
    Mar 2007
    56
    Thanks spelomike i am onto it now. If i get rid of any excess air and replace it with water i will get a true double shot(i assume) i always thought the shots were a little shy so i will measure em.
    May 2007
    Perth, Western Australia
    3,164
    Behmor Coffee Roaster
    One comes to mind from years ago, a Monsoon Malabar espresso roast run through the machine soon after roasting--but not to the extent of that pic!!
