Page 2 of 2 FirstFirst 12
Results 51 to 61 of 61
Like Tree9Likes
Thread: HeatSnob chat
  1. #51
    Jun 2012
    Melbourne, Vic, Aust.
    1,033
    Quote Originally Posted by simonsk8r View Post
    P2 was my go to when I had only the original Behmor panel. But with that setting it sort of arbitrarily drops the power at a specific time in the roast, when you may not necessarily want it to!
    After adding that comment to the previous post it struck me that was the case. As you mention, it's a huge improvement on having power reduced when you least want it.
    The ability to intervene is a great feature but I suppose needs to be used with a degree caution. Playing around with P5 as I was, reminded me how quickly things can change at the end of the roast. Luckily I was hovering with eyes, ears and nostrils at full alert. I've made note of it for next time. I was monitoring temp with the "B" button while utilising P4,P3 & P2 manual to control the temp. Might just try going straight to P3 at First Crack next time. That's what I get for taking a few months off from roasting.
    Seriously considering the HeatSnob option for better monitoring when experimenting.
    BTW just noticed this Facelift on the Behmor site-
    simonsk8r likes this.
  2. #52
    Mar 2004
    Internet
    16,688
    Blog Entries
    1
    Moved these posts here from the HeatSnob Temperature Data Logger Thermocouple and Roast Monitor USB software thread to keep the other thread useful.
    Chat away.
    Javaphile and CafeLotta like this.
  3. #53
    Senior Member artman's Avatar
    Jun 2006
    2,397
    You can also easily monitor bean temp if thatís what you want to play with, through the spindle using the bead thermocouple. I did a post on it here ages ago. Works well and no permanent holes (except the spindle).
    Andy, Dimal and CafeLotta like this.
  4. #54
    Jun 2012
    1,033
    Interesting option for roast temp measurement. Thought I'd include the link for this here to make it easier to find for anyone else interested in your mod. Refer to post #24 in the thread - https://coffeesnobs.com.au/roasters/...tml#post578429
    CS member "jonjon" has also come up with another version of a bean temp probe - https://coffeesnobs.com.au/home-roas...ean-probe.html
    Great bit of innovation guys.
  5. #55
    Oct 2016
    Central Coast NSW
    363
    Quote Originally Posted by Andy View Post
    Your graph looks fine, typically if there is a problem you will get large 100 degree spikes where it lost signal but yours look good.
    There was something ugly at the 6 minute mark but it recovered okay.
    I doubt the Behmor is the problem as it's chassis is grounded well but even so, the electrical noise from the 240v relays switching on and off could give some transient errors. Because they are 10 seconds apart I doubt they are a real problem and more likely to be sensitivity of the probe not the HeatSnob.
    I would try your other 25mm probe and see if it goes away.
    Thanks Andy, your reply helped.
    the ugly part at 6 minute in the RoR was my mobile being too close to the equipment I think, tried it on a few other roasts and seems to be the cause.
    the issues with the second temp reading (air temp in roaster) when gets to 135-140 degrees seemed to be a dud probe. Surprising as the probe was brand new (brought as a spare 6-9months ago) but the Heatsnob unit is secondhand. I swapped my working Heatsnob and the second hand Heatsnob around and same issue with the 25mm probe. Swapped the probe for a bead thermocouple and reads find now. In fact Iím surprised in the reduction in air temp when the fan kicks in at 5minute mark (200gm setting) into the roast
    martin
  6. #56
    Oct 2009
    Geelong
    1,061
    I did not know the mobile phone being too close to the Behmor would affect the graph/computer... ! I've always had mine near it while roasting but never had any strange spikes like that.... unless every single profile I've had has been a dud (it's possible!)
  7. #57
    Oct 2016
    Central Coast NSW
    363
    Wasn’t a constant issue but seemed to happy more if was watching a video for instance, can’t remember if mobile data or wifi changed the efffect thought
  8. #58
    16,698
    More likely if you were sending data rather than receiving it, might cause an issue...
    I was experiencing quite a bit of noise with an old faithful t/c that I had been using for many years.
    Decided to replace it with one of Andy's shielded units, and the noise? Just disappeared.
    EMR noise can be a bugger to eliminate completely though, especially if you have a significant length of the t/c cable exposed and unshielded. I imagine though that you are using one of the CS shielded units, if you bought it from Andy...
  9. #59
    Jun 2018
    470
    Couldn't see this anywhere re Roast Monitor:
    Are the outputs from the "heat" and "air" sliders sent to a coms port and if so in what format? EG can I access them to externally control the heat source for a roaster?
  10. #60
    Mar 2004
    Internet
    16,688
    Blog Entries
    1
    Sliders are there just to annotate the graph.
    Lyrebird likes this.
  11. #61
    Jun 2018
    470
    Behmor Coffee Roaster
    OK thanks.
