Results 1 to 20 of 20
Like Tree8Likes
  • 1 Post By Soules75
  • 2 Post By Soules75
  • 2 Post By DesigningByCoffee
  • 1 Post By Jackster
Thread: First Corretto Roast! Looking for feedback
    May 2019
    10
    Hello! I just built a Corretto roaster and roasted some Ethiopia Guji Alaka beans from Happy Mug. I am using a thermocouple to monitor temperature and hit first crack around 8-9 minutes in. Unfortunately, right in the middle of first crack my bread machine paddle stopped turning. I tried to fiddle with it but couldn't get it to start again, so I dumped the beans because I was worried they'd burn with no paddle movement.
    I was going for a light city roast, and although I probably pulled them a bit early, I think they look pretty good. I really enjoy SW roasting coffee, and my beans look very similar in color to theirs, so I'm hopeful that they'll taste good, but also am prepared for the worst!
    I think there is a French bread program on my bread machine that has a much longer dough cycle, so I am going to try that next time. Also, I believe it overheated, so I should also probably try to locate and remove the temperature sensor.
    It's a Toastmaster TBR15 if anyone happens to have any experience with that machine. Anyways, here are some pics. What suggestions or feedback do you folks have? Thanks!
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,950
    Welcome to Coffee Snobs Soules
    Try to modify the bread maker to run continuously (disable the element) will make life a lot simpler, 8/9 mins to first crack seems fast to me, you must have had the heat cranked up pretty high, I usually hit FC at around 14 mins @ about 200C.
    May 2019
    10
    Yea, I hit first crack a bit early perhaps, depending on who you ask. I've seen several people online recommend that FC at 8-10 minutes timing. For my next roast I'll probably shoot for a longer overall roast time.
    I'm going to brew the coffee up tomorrow morning and see how it tastes. I still have 1/2 lb of beans left to roast. For a natural processed Ethiopian, what profile would you recommend? Thanks!
    16,986
    Time to 1st-Crack depends a lot on the batch weight.
    If roasting quite small batches, say ≤400g you would expect 1st Crack to occur from 10-12 minutes or less, so maybe the 8-9 mintes isn't out of the ballpark.
    Agree with Yelta though, would pay to modify your BM (or have a qualified person do it for you) such that you are in a position to stretch roasts out to 20+ minutes for larger batches.
    May 2019
    10
    I roasted roughly half a lb of beans, which is about 230 grams, so perhaps the shorter overall roast time won't be such a bad thing? I just didn't want to ruin the entire bag if I messed up. Roasting half gives me a chance to try again later without ordering another bag. Anyway, I'm going to brew it up in a bit here this morning and try it. I'll report back later.
    Dimal likes this.
    May 2019
    10
    Ok so I tried the coffee this morning and, to my pleasant surprise, it was some of the best I've ever had! There was no smokey burned flavor. It was really juicy and tasted like strawberries and blueberries! I would say it is on par with my favorites from SW and Counter Culture, which I wasn't expecting...especially from my first attempt! Very pleased with the results. Hopefully I can replicate this again, or even improve upon it.
    Dimal and DaveD like this.
    16,986
    Way to go Soules75...
    Sounds like you're nailing the profile for those beans so I wouldn't recommend trying to change anything just now. The proof of the pudding, as they say, is being able to repeat the results you enjoyed previously, so if you can do that a couple or more times, then it would be reasonable to try something different and see how that reflects in the results in the cup.
    Good job though mate...
    May 2019
    10
    Good point. Why change anything if I'm enjoying it so damn much?
    I removed the heating element from the bread machine. Unscrewed it and disconnected the two wires. Will this prevent the overheating error or is there a sensor somewhere I also need to disconnect?
    Jun 2009
    Moonta SA.
    6,950
    Time to start experimenting Soules, by their very nature all Coretto systems are different, what works with one may not be ideal for another.
    Put some time and effort into understanding the process, lots of info available on this forum, use the search feature.
    Also good video's about Coretto roasting on YouTube.
    Here's a good thread to start with.
    https://coffeesnobs.com.au/roasters/...estions-2.html
    16,986
    Quote Originally Posted by Soules75 View Post
    Can you give us some photos of the internals?
    Will help us to assist you with any mod's that might be possible...
    Aug 2008
    Millthorpe NSW
    2,039
    As Mal mentioned, some photos will help. If you BM is anything like a Breville, there may be a little screwed in metal plate/tab in the side of the internal metal skin, which sometimes has two white wires attached? I believe this is the sensor which will trip out the unit if it gets too hot. On my first machine, I unscrewed this, taped it up and tucked it away near the front of the machine under the touch pad to keep it cooler, which helped even with standard dough cycles (in later versions of roaster this has been removed altogether).
    The other thing which can help is to wrap your pan in fire blanket ($10 from bunnings) to insulate this from the working machine. This also has the added advantage of then requiring far less heat input from your gun to get a good profile … reducing the risk of scorching
    Below is link to my gallery of mods over the years – might get some ideas
    Cheers Matt
    https://coffeesnobs.com.au/members/d...-roasting.html
    Dimal and Jackster like this.
    Nov 2017
    Maddington, Perth. Wa
    991
    Aah! Bunnings fire blanket.... Just the thing, I have wrapped the outer skin in that heat proof foam with the shiny backing.
    I will check out your thread Matt
    DesigningByCoffee likes this.
    May 2019
    10
    I just roasted my second batch, and this time I used the French bread setting, which has an 18 min dough cycle, which is perfect. The bread machine did not overheat and everything went really smoothly.
    I went a bit slower this time and managed to hit FC around 9-10 minutes. I let FC finish and let them roast for another minute or so before dumping them. They look great and after about an hour now, they smell incredible, just like the first batch. Hopefully they taste every bit as good too.
    I think I am going to order more beans in bulk soon so I can experiment with different origins. I'll be on the lookout for some Kenyan beans (one of my favs) and maybe a Colombia, El Salvador, Costa Rica, etc.
    Looking at Happy Mug, Sweet Maria's, and Bodhi Leaf. Can anyone speak to which of these is best overall?
    Dimal and greenman like this.
    Dec 2004
    Earth!
    15,781
    There is a wide variety of green bean sellers available to you, some even with-in driving distance. What kind of quantity, quality, and pricing are you looking at?
    Java "It all depends" phile
    Toys! I must have new toys!!!
    May 2019
    10
    I've had roasted beans from Happy Mug, SW Roasting, Ruby, Counter Culture, Red Bird, etc. if that gives you an idea. Of those, I liked Counter Culture, Ruby, and SW best, but they were all great except for maybe Red Bird, who roasts too dark for my liking.
    I am very pleased with the green Ethiopia Guji beans I've been roasting and also happy with the price. I've just seen a lot of buzz online around Sweet Maria's and Bodhi Leaf and am curious how they compare (quality, variety, etc.) to Happy Mug. I believe Sweet Maria's is a little more expensive than Happy Mug, but if the quality is better, I'm not opposed to paying more.
    Dec 2004
    Earth!
    15,781
    Have a look at these folks. Take an afternoon drive up nord and check the beans out in person before buying. You'd likely even be able to taste some roasted as well. Plus you get to talk direct with the business owners and get all your questions about the beans answered in a single in-person session with the beans right in front of you. If nothing else it would be a nice drive in the woods with some learning about coffee beans and roasting along the way.
    If you want to spend hundreds/thousands on full bags of high end coffee(s) one of the best sources is just a short run across the border for you to the Twin Cities.
    Java "Not an advertisement" phile
    May 2019
    10
    OK, question for you guys. I got some Costa Rica La Minita beans from Happy Mug and roasted them up. I noticed when I brew them in the French press the grounds sink right to the bottom and never float to the top. I've never seen this before. I've read that this could be indicative of stale coffee, but I just roasted it a couple days ago, so I can't imagine that's the case. Is this a characteristic of certain coffees or processing methods? It tastes fine so far. Not amazing, but still a solid cup of coffee.
    May 2019
    10
    Brewed some Ethiopia Koke beans yesterday afternoon and just brewed them in the French press now. Again, the grounds didn't float to the top much. The cup was pretty good, but a little bitter. Guessing they need another day or two to de-gas more. I roasted them pretty light, dumping after first crack. Hoping the bitterness gets replaced with more of the juicy berry flavor.
    May 2019
    10
    The first batch I roasted is still the best tasting, and I think it is because I preheated the bread pan during the initial intermittent spin cycle, then dumped in the beans. I hit first crack around 8-9 minutes and dumped them shortly after. Since then I haven't bothered preheating the bread pan, and have aimed for a more slow and gradual climb to first crack, hitting around 10-11 minutes and then roasting for another 30-60 after. The results aren't as impressive. So I think I am going to try preheating again next time and shoot for that 8-9 min FC.
    By the way, how does one go about hooking a laptop up to log profiles? Is special equipment required?
    Dec 2004
    Earth!
    15,781
    Behmor Coffee Roaster
    Have a look here: https://coffeesnobs.com.au/home-roas...-software.html
    Java "Fun stuff!" phile
