Results 1 to 12 of 12
Like Tree14Likes
  • 3 Post By Yelta
  • 2 Post By 338
  • 2 Post By Dimal
  • 1 Post By magnafunk
  • 1 Post By DaveD
  • 1 Post By Lyrebird
  • 4 Post By Lyrebird
Thread: Coretto killed my heatgun
    Jun 2018
    465
    So my heatgun (a Makita HG6500) just died in the middle of a roast: the LCD screen went blank and the heater coil went off so it looks like the control circuit has been fried.
    I've been slightly worried about the possibility of this since I started roasting: the air intake vents seem a little underwhelming and are easily clogged by flying chaff.
    I need candidates for a replacement: I also use the heatgun for heatshrink binding tape to compress CF composites so I need the variable temperature feature.
    I'm leaning towards the Dewalt 26414 but I'm wondering whether I should get a cheaper gun like the Ozito for the roaster: I avoid Ozito tools as they are always crap but if it's just going to clap out anyway, what's the damage?
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,798
    Bad luck Lyrebird.
    I've been using a Bosch 630 DCE as a Coretto heat source for 10 years, very controllable, 50 to 630C temp, 3 blower speeds its still going strong.
    I have a pedestal fan set up to blow chaff away from the air intakes and do brush the mesh regularly.
    Will replace it with same again when it does fail.
    https://www.bunnings.com.au/bosch-bl...t-gun_p0078009
    Jun 2018
    465
    OK, sounds like it will be worth a shot.
    BTW I brushed the vents before use but it never seemed enough. Obviously I was right.
    I might try to resurrect the guts of the Makita but institute an external controller to give me independent air flow and heat settings
    338
    338 is online now
    Mar 2017
    725
    Lyrebird, I also use the same on the advice of the forum. Two years so far and the last year been using it in a device of my own making where the nozzle is inside the heat chamber. So far, so good. Mine is the PHG 630 DCE in green - https://www.bosch-do-it.com/au/en/di...446-199922.jsp - oozing Romanian quality.
    16,668
    I'd steer clear of the DeWalt units...
    Tried a couple of them out a few years ago; the first failed to maintain an output temperature above 400C so returned it, the replacement unit they sent me fared no better so ended up going with a Makita 6020 which was their top unit back then. Hasn't failed me in many years of use and is easy to clean. The air intakes on these units should have removable filters that one can clean easily but as far as I know, the Metabo units are the only ones that provide for this.
    Lots of CSers here using the Bosch options with very, very few failures that I can recall...
    Senior Member magnafunk's Avatar
    May 2014
    East Kimberley
    542
    My Bosch went well for hundreds of roasts before it clapped out. Turned out to be a dry joint which I soldered up. It did another few dozen before going into storage. Would definitely recommend. I'm using a behmor at the moment but when I go back to corretto, I'll use the Bosch until it dies then I'll get another
    Lyrebird likes this.
    Nov 2013
    West Footscray, Melbourne
    207
    I'm also a fan of the Bosch 630 unit. Mines been going for 4 years in which time I've done about 700 roasts with it. The Ozito i had prior only lasted about 9 months and about 80 roasts.
    Jun 2018
    465
    Thanks all, I pulled the pin and bought the Bosch unit on my way into Melbourne this evening. Will try it out when I return.
    Dimal likes this.
    Jun 2009
    Moonta SA.
    6,798
    Quote Originally Posted by Lyrebird View Post
    Hope it meets your expectations Lyrebird, keep us informed.
    Apr 2018
    10
    With a chimney to direct chaff out the door you can avoid clogging up the air intakes in the heat gun.
    Jun 2018
    465
    Excellent advice, Mal. A velcro dot and a strip of breather cloth* later, we have this:
    The intention being to avoid a repeat of this:
    No wonder the poor thing died, it couldn't breathe.
    *Breather cloth is used in vacuum bagging composites to ensure you can get all the air out. It's basically non woven polyester batting.
    Dimal, SanderP, 338 and 1 others like this.
    16,668
    Behmor Coffee Roaster
    Worst case of "Chaff Aspiratus" I've ever seen...
