Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Mb21
Thread: Heatsnob Graph/Behmor Newbie Help
    Dec 2014
    Perth
    3
    Hi,
    First time using heatsnobs temp logger.
    Here is the graph from the cleaning cycle. (whoops not allowed to upload jpg?)
    Not quite what I was expecting.
    1: the temp rises steadily to 150 them drops to 80c. Why?
    2: Temp remains constant till Behmor starts cooling cycle, upon which it actualy increases.Is this a normal?
    3: What does the blue line represent/
    Thanks.
    Oct 2016
    Central Coast NSW
    360
    Where is the temp probe located?
    what type of probe thermocouple or bead?
    what time does the temp drop and what batch size and profile are you using?
    my bet would be the fan turns on and draws some of the heat out. Happens around 40% of roast time if I remember correctly
    Andy likes this.
    Dec 2014
    Perth
    3
    Thank You for your response , after 2 more hours of searching old posts found same answer for temp drop , still do not know whawt blue line represents
    Mar 2004
    Internet
    16,675
    Blog Entries
    1
    Behmor Coffee Roaster
    Quote Originally Posted by crouch153 View Post
    Hi,
    Thanks.
    Get your forum post count over 5 and you can post images
    (keeps the spammers out, I'm sure you understand)
    Hard to guess what you are seeing without a picture but... The HeatSnob just reports what it sees!
    1: On a Behmor cleaning cycle the fan speed increases and will draw more cold air in than the start of the cycle (is my guess).
    2: Cooling cycle is the same, temp will increase initially because the fans draw more air though.
    3: Blue line at the bottom is the graph of degrees per minute.
