Results 1 to 38 of 38
Like Tree27Likes
  • 2 Post By Andy
  • 1 Post By robusto
  • 1 Post By WhatEverBeansNecessary
  • 2 Post By robusto
  • 2 Post By CafeLotta
  • 3 Post By Moulard
  • 4 Post By Dimal
  • 1 Post By robusto
  • 2 Post By leoniedukes
  • 2 Post By artman
  • 1 Post By Lyrebird
  • 2 Post By geoff
  • 2 Post By Barry O'Speedwagon
  • 1 Post By Barry O'Speedwagon
  • 1 Post By simonsk8r
Thread: Behmor cleaning and smoke problems
    Sep 2018
    38
    Recently bought an ex-demo/ refurb Behmor
    While the first 2 batches were fun to roast (200g and 150g), the 3,4,5 batch not so much, batch 3,4 were roasted in 100g size and both triggered the smoke alarm even though there weren't lots of chaff.
    Tried to roast again today, 180g of Brazil Yellow Bourbon Especial 200g> start, very smoky before FC (5 min remaining), have to stop as I am afraid of it will trigger the smoke alarm again, lots of chaff compare to previous roast and one chaff stuck between the light bulb and the glass, and it is warm-to-hot when I touch the glass panel when the light is on I am not sure if it everything is normal
    Anxious about roasting with it right now as I've seen some post about Behmor on fire, planned to roast out door but it's wooden floor outside...
    I use the brush and vacuum every time after roast, there are some "burning stain" on the fence that protect the element and on the right back corner.
    I wonder if these two cleaner can substitute Simple Green
    1. Dettol Antibacterial Disinfectant Wipes 180 Pack Benzalkonium Chloride 0.47% w/w (0.3% w/w at use by date)
    2. Organic Choice Multi-Purpose Cleaner Ingredients: Water, Coconut based non-ionic surfactants, Sugar/corn based alcohol, Citric acid, Organic Backhousia citriodora (lemon myrtle) essential oil, Organic Cymbopogon flexuosus (lemon grass) essential oil, Organic Aloe barbadensis (aloe vera) leaf juice, Fragrance.
    Thank you
    Mar 2004
    Internet
    17,222
    Personally, I would never roast inside with anything. I've always thought that home coffee roasting is best done on a verandah or in a shed so any chaff could just be spread on the garden and you don't have to worry about smoke alarms.
    As for cleaning, the manual recommends Simple Green and you can find it in Bunnings (for $6.50 a bottle, which will last for years). Simple Green was originally developed for commercial coffee roasters and it does a great job.
    Detol flavoured beans would be nasty and the second cleaner you mentioned might be okay but I expect "fragrance" wouldn't be too good.
    Whatever cleaner you use needs to non abrasive (ie: don't use Jiff like you might on a stainless kitchen sink)
    Others that use the Behmor more often than me might chime-in with their cleaning tips too.
    Dimal and Simplyhuman like this.
    Feb 2005
    3,056
    Been roasting in the kitchen with the Behmor for years without dramas. I put it on a thick wooden tray on top of the hotplates and any excess smoke is sucked up the range hood.
    The machine lives in the cupboard directly under the hotplates so it's convenient to lift in and out.
    Cafetto cleaner is good. Dissolve it in warm water and wipe it on with a sponge. Occasionally I soak the drum and chaff collecter in the sink with warm water and caffeto.
    There's no smoke alarm in the kitchen of course. But there is in the corridor behind it...and if I inadvertently leave the door to that area open the slarm will go off despite no visible smoke.
    Andy likes this.
    Sep 2018
    38
    Quote Originally Posted by Andy View Post
    Will buy the simple green, and roast it outdoor next time, should I open the glass door while roasting in case it will catch on fire because of the chaff?
    I wonder if roasting just into FC/ before SC will still possibly causing fire or just those passes SC will potentially cause fire?
    Will roast out door next time but will need to use extension cord, is extension power board or a 3 metre extension cord safe to use for the behmor?
    Quote Originally Posted by robusto View Post
    I roast in the kitchen as well, the first batch didn't set off the alarm even when it was 200g Peru roasted with all doors/ windows closed, plus didn't turn on the range hood. But with 100g the alarm goes off before FC even all doors opened/ range hood turned on......
    Have you ever saw flames in the behmor while roasting? I suspect I saw it but not sure about it..
    Feb 2005
    3,056
    You should NOT open the glass door during roasting. That's what the instructions say and with good reason.
    While I don't believe there's a fire risk if the machine is clean and operating properly, the risk of chaff catching fire does increase with an open door. Not to mention the mess as chaff is blown out all over the place instead of being contained in the machine.
    Sep 2012
    Hobart TAS
    317
    You should avoid using an extension cord (as emphasised in the instructions) as voltage drop can play havoc with the effectiveness of the roaster. If you cannot avoid using an extension cord, it would be best to get an extension cord made up to the minimum length required and using the heaviest gauge cable that you can find. 15 amp cable as used for caravan extension cords would be a good starting point.
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    498
    Don't forget to do the odd burn off - ie a short roast with no beans to burn off any unwanted build up on the elements (you will be able to find the steps in the manual).
    Simplyhuman likes this.
    Feb 2005
    3,056
    Some appliances come with a warning not to use extension cords, but the warning is more apt as a legal disclaimer. The advice is more valid in countries with unstable electricity supply voltages.
    In the USA voltage supply is a nominal 120, so voltage drop can be an issue.
    The lower the voltage, the higher the potential drop.
    Here in Australia nominal voltage is 230 and drop is not an issue in domestic situations with small extension cords.
    In fact, because of the boom in rooftop solar, votages can and do spike much higher, around 250+ volts at my place.
    For example, at peak solar panel output at 1.33 pm yesterday, where I live the grid voltage also peaked, at 253 volts. That's way above the nominal supply.
    Andy and shauno like this.
    Jun 2012
    Melbourne, Vic, Aust.
    1,268
    I also roast under the rangehood. Closing all doors and windows seems to help draw most of the smokey or "coffee roasting scented air" out. Even though I hover over the roaster, I still keep a fire blanket near by just in case.
    Ditto about never opening the door if you notice any chaff smoldering or it may catch alight once the fresh air hits it.
    Beans that produce lots of chaff are more susceptible to catching alight. Doing 400g roasts with these can be tricky. Before opening the door at any time, switch off the internal light and check that there is no sign of the chaff edges smoldering.
    Dimal and robusto like this.
    Sep 2018
    38
    Will be roasting outdoor next time, so mess is not going to be a problem, just thought I should open the glass door if certain bean is too chaffy?
    Quote Originally Posted by Otago View Post
    Went to Bunnings today and only found 10 amp even when stated for heavy duty (was in rush, though I saw 15 amp cable on their online store), bought the 10amp 3M cable, is it ok?
    Quote Originally Posted by WhatEverBeansNecessary View Post
    Is it normal to have chaff that are smaller in size that stuck in between where the metals are connected?
    Quote Originally Posted by CafeLotta View Post
    I too bought the fire blanket today, just in case, is 1M x 1M large enough?
    I was actually doing 100-200g, but still kinda worry certain types of bean produce too many chaff that may cause flame or even fire....
    Have you roasted the Brazil yellow bourbon especial, do you think it is too chaffy for the Behmor?
    Is there any bean bay's bean that you guys think they are too chaffy and might not be a good idea to roast them in the Behmor?
    For those that roast in door, do you turn off the fire alarm when roasting?
    Jun 2012
    1,268
    Quote Originally Posted by jasmineeeee View Post
    There seems to be the odd bit of chaff that can get into the small gaps between the sides and floor of the Behmor. I normally vacuum the inside after each roast and use a brush to dislodge as much of the trapped chaff as possible into the vacuum nozzle.
    As long as it fully covers the roaster it should help if the worst happens.
    Starting with smaller batches as you are will give an insight into how the bean roasts and how much chaff is produced.
    I have roasted 400g batches of the Brazil yellow bourbon especial and it seems to produce a fair bit of chaff. Never had a fire but when chaff collects at the front of the chaff tray, it can start to smolder. I've not had to stop a roast but you do need to turn off the internal light and check for any sign of the chaff edges smoldering before you open the door after cooling finishes.
    If you're not confident then stick with 200g batches of this bean. BeanBay descriptions usually indicate if a bean produces lots of chaff when roasted.
    Behmor states this as safe roasting practices - http://www.behmor.com/docs/important...-practices.pdf
    https://behmor.com/support/updates_manuals/
    Mar 2018
    8
    A fire needs three things. Heat, Fuel and Oxygen.
    So long as the door remains closed, you starve it of Oxygen, and therefore the worst you should get is a smoulder.
    Once you open the door you complete the triangle and can get a fire.
    A fire-mat works by starving a fire of Oxygen.
    Andy, CafeLotta and jasmineeeee like this.
    17,403
    G'day "jasmineeeee"...
    My experience with using a Behmor over a reasonable length of time, never realised the danger of any kind of fire starting up, so long as the the User Safety Instructions are followed.
    This was the case with batches approaching 400g time after time, using beans from all over the world and including a range of dry processed beans from East Africa which are notorious for generating copious volumes of chaff.
    As "CafeLotta" pointed out above, keeping a vacuum cleaner handy to remove all visible chaff from the interior of the Behmor, between roasts, goes a long way to preventing any kind of build-up of chaff that may present a fire risk. In fact, I kept an older 'spare' vacuum cleaner handy just for that purpose. The interior can be kept in 'as new' condition too, if you follow the basic cleaning regime outlined in the User Manual using Simple Green organic cleaner which can be obtained from Bunnings in most places.
    In short, don't be frightened when using your Behmor, rather, just follow the simple instructions in the manual and advice from experienced users here on CS and enjoy the wonderful results at the end.
    All the best,
    Andy, Javaphile, simonsk8r and 1 others like this.
    Feb 2005
    3,056
    Jasmaneeee, 10 amps is the domestic standard. 15 amp plugs need a special circuit wired by an electrician back to the fuse/breaker box and definitely overkill for the Behmor which pulls about 6 amps. Put into context...a portable fan heater which may be run all day in winter pulls 10 amps.
    Dimal likes this.
    Aug 2014
    Geelong Region
    25
    Hey Jas.
    Good on you for being proactive and cautious with your new toy. How are you going with it?
    I've had my 1600+ for about 5 month's now, I roast in my garage and use a fan with the door open to cool it quicker. Just personal preference.
    Jan 2011
    13
    My first roast with the Behmor the roast caught fire, but the shutdown function meant it was just a lot of smoke and scorch marks, nothing major. The machine still works fine. It is important to keep an eye on the machine, but I don’t see it as a huge fire risk - smoke control is a bigger issue for me, as it can set off the smoke detectors.
    In regards to the fire blanket, it is great to have this - I think every kitchen should have one. It is a good idea to take it out and put it over the roaster so you are familiar with it if you do have a fire. Hold it so that the corners cover your hands (it is natural to grab it with our fingers over the top, which can expose them to the fire when you cover it). If you do have a fire, leave the blanket in place until everything cools down - if you lift it up to check on it, the added air can restart the fire.
    Also, if you do have a fire (roaster related or otherwise!) it is a good idea to get the Fire Brigade out to check it even if you think the fire is under control or out (particularly if it is under a rangehood, as fire can spread up the rangehood into the roof). They will also be able to do any required paperwork for insurance, which may pay for repainting of smoke damaged rooms as well as more obvious damage.
    Senior Member artman's Avatar
    Jun 2006
    2,457
    If you are getting lots of smoke, perhaps your afterburner element has broken. It is just a thin wire that can fracture if you slam the door or if the roaster got some knocks by the parcel throwers, I mean gentle handlers. Easy to check and cheap and easy to replace.
    I just vacumn all chaff from inside and the chaff tray after each roast (bought a new dyson long reach brush i keep with my beans box and only use on the roaster so it remains new/clean) and do the wipe with simple green. I did use some essential oil thieves cleaner on stubborn bits and with a non scratch scourer which was very effective at removing the really old "stains" (i got my roaster used).
    Senior Member Divey's Avatar
    Oct 2011
    132
    How do you check to see if the afterburner wire is not broken?
    Jun 2006
    2,457
    Start a roast then press cool after a few seconds. Turn off all light and you should see the afterburner glowing red (and feel heat if you put your hand near it). The afterburner is in the protruding square bump on the ceiling of the roast chamber with the holes on it.
    Sep 2018
    38
    All the best,
    Finally roast again and clean with simple green + dry burn the Behmor today.
    Everything works fine I guess, tho the smoke was still a bit scary.
    Quote Originally Posted by Simplyhuman View Post
    Hey Jas.
    I roast outdoor but keep the door close during the cycle including cooling, just in case flames that may lead to fire.
    There was bit of flame and lots of smoke while roasting the Yemen and couples of them jump out of the drum and get burnt, the batch itself comes out slightly darker than expected but still looks fine.
    There was the glowing red light you mentioned but I am not sure if it means the after burner is working, there was lots of smoke for the Yemen, but it was not that much for the Colombia (heavy smoke appears when I hit cooling but not during roasting, not sure if it's normal?)
    Quote Originally Posted by leoniedukes View Post
    My first roast with the Behmor the roast caught fire, but the shutdown function meant it was just a lot of smoke and scorch marks, nothing major. The machine still works fine. It is important to keep an eye on the machine, but I donít see it as a huge fire risk - smoke control is a bigger issue for me, as it can set off the smoke detectors.
    I now roast out door and have the fire blanket on the side, is 1m x 1m enough?
    So...10 amps is enough? I am kind of worry that the 10 amps extension cord will affect the smoke suppression of the Behmor, don't know if it is related or not
    Sep 2018
    38
    I find that more than half of the chaff are at the back, I am now roasting 100g each batch, if roasting for 150g should I use the 200g setting or the 100g setting?
    Apr 2017
    Adelaide
    498
    The answer to that question is... It depends.
    The difference between the 100, 200, 400g settings is the heat output/time (as the elements can only put out a maximum amount of energy per time). More beans = more heat energy needed to reach the same temps. I wouldn't get hung up on doing exactly 100g bean weight for a 100g setting. Let the the flavour in the cup be the no 1 guide. Try both and see what you like. You might find that 150g is a tiny bit less heat output and the flavour is more subtle and delicate. Or you might find it is a bit underdeveloped and grassy.
    Lots of info on the Behmor is targeted at the North American market where the outlets are usually 110V I think, so the length of the extension cord you will find some differences. In general in Australia the difference will be negligible.
    The Yemen I have found to be quite chaff-y which does pose more of a fire risk, although I have never seen any flames in my roasting ever. The smoke is significantly more from the Yemen than other beans including other natural processed ones. Just another thing to be mindful of. Personally I never leave the roaster unattended for more than around 30 seconds at a time and never leave it unattended as it gets close to first crack until cooling begins.
  23. #23
    Jun 2018
    625
    As other have opined, this shouldn't be a factor.
    I measured a typical cheap extension cord, out and back resistance was 0.2 ohms* for a 3 metre length so it will drop about 1 volt at 6 Amps (or 2V at 10A). Given that the Australian standard is now 230V +10% -6% (eg 216V to 253V) and in my experience actual voltage at the power point is rarely at the bottom end, the extension cord will be fine.
    * As measured with a Fluke 73 DMM: caveat, this resistance is so low that the device is at its limit for accuracy. Any cord with the appropriate approvals will be similar.
    robusto likes this.
  24. #24
    Jun 2007
    43
    Re your concerns with chaff and bean bay beans, Jasmineeeee -
    I have roasted with dozens of different beans bought from bean bay and none has been too chaffy for the Behmor to handle. Some have been chaff monsters and some produce almost no chaff, but the fact of the matter is that CHAFF HAPPENS! The next fact is that the Behmor chaff tray will only catch around 50% and you need to clean out the rest after each roast. I use a brush but vacuum or whatever, make sure that it's properly clean.
    The other comment I would make is that everything happens pretty quickly with 100/150g roasts. When you move up to larger size roasts there is more time to hear and see what is going on.
  25. #25
    Dec 2011
    PRL
    2,723
    You don't tell us exactly how you are presently using the roaster (i.e. just using a preset profile, or manually interrupting such a profile etc). I'd use the 200g setting, drop the power to 25% once you are sure that first crack has occurred and hit cool at the desired point. I'm guessing that the time interval b/w first and second crack might be 1min 45 for 150g....possibly
    a bit longer if you do drop power to 25%? You'll find out soon enough. Or, of course, roast 200g and then you can use the 'Rosetta Stone' feature if you like.
  26. #26
    Feb 2005
    3,056
    In my experience the more practical rosetta stone is being vigilant, standing over the machine, not being distracted, and listening for first crack.
    You can't leave settings on autopilot to reach second crak--if that's what you want-- on cue and begin cool down at the appropriate time.
    Best to just keep hitting the C button so it won't cool down prematurely, and determine yourself when to hit cool.
    I used to use the 400g P1/P2 setting on auto and found I had to keep adding many minutes.
    Now I tend to go manual.
    As for chaff....indeed Behmor takes in in its stride catching 99% of it in the tray. The beans emerge pretty much chaff free.
  27. #27
    Sep 2018
    38
    Quote Originally Posted by Barry O'Speedwagon View Post
    I use the preset profile, 100 > P1 > Start, then press Cool after 30-45 sec when I start to hear FC
  28. #28
    Sep 2018
    38
    I normally hit cool 30-45 sec after hearing FC, for the chaff about 50% of them in the tray and 50% at the back, cleaning was easy but I am concern those at the back will turn into flames...
  29. #29
    Sep 2018
    38
    Do you find that some of the chaff and the bean that fall out of the drum were burnt when you finish roasting the Yemen?
    I was with the roaster the whole time including cooling and I find that there was more smoke once I hit cool?
  30. #30
    Sep 2018
    38
    Quote Originally Posted by geoff View Post
    I find that with the Yemen, the chaff ad the bean that fall out from the drum were burnt after finish roasting. And I wonder if roasting larger batch will make this burnt them more severely.
  31. #31
    Dec 2011
    PRL
    2,723
    I roast Yemen every second week in the Behmor, in 400g batches. I have never, ever had a fire problem (famous last words I know). I don't do anything special, just vacuum the roaster (and chaff tray) out between roasts. To limit the number of beans that fall out of the roaster, when you first load the roaster, just hit 'Cool' and let the basket rotate for 30 seconds or so. The hit 'Off', pull out the chaff tray and get rid of any tiny beans that escaped. Put chaff tray back in and start your roast as normal.
    Dimal and jasmineeeee like this.
  32. #32
    Sep 2018
    38
    Do you see flames when you finish roasting and hit cooling? I saw flames every time when I roast, even with different beans...
  33. #33
    Sep 2018
    38
    Is there something wrong with my behmor's after burner if there is no red light when I hit cooling? How can I fix it?
  34. #34
    Dec 2011
    PRL
    2,723
    What do you mean by 'flames'? Do you mean flames like on a lit candle, or simply visible glowing chaff? I've never seen anything that approaches flames.
    robusto likes this.
  35. #35
    Oct 2009
    Geelong
    1,168
    Dunno about flames.. but... I see fiiiiire.....
  36. #36
    Sep 2018
    38
    Numbers of glowing chaff, is it normal to have it every time I roast no matter it is heavy chaffy bean or bean with less chaff?
  37. #37
    Sep 2018
    38
    Quote Originally Posted by simonsk8r View Post
    Happened many times and last for how long?
  38. #38
    Oct 2009
    Geelong
    1,168
    Behmor Coffee Roaster
    Hehe ah was sort of joking.. song lyrics XD. But it does happen to me on the odd occasion, something (an odd bean that got through and is sitting on the bottom, or chaff) might have a tiny fire, usually just goes out on its own. It's pretty rare.
    Does it happen to a bean/the chaff that escaped the drum or is the fire actually inside the drum?
    Dimal likes this.
