Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By 338
Thread: Evilbay spinny drums
    May 2011
    22
    Hi all
    Anyone tried using these?
    Electric Coffee Bean Roaster Home Machine Baking Roasting Dry + Tray
    A search will bring it up. Much as I'd like a real roaster from a sponsor, my cash won't stretch that far at the moment. A corretto would also be interesting, but I fear the mods to get the BM to spin are also beyond me.
    This basically looks like a drum with a small motor to rotate it. It needs a heat source added, so I though the heat gun might work with it.
    The alternative for my level of skill might be a bowl with a drill powered paddle.
    338
    338 is offline
    Mar 2017
    963
    Rod that looks like it needs a heat resistant box around it to keep adequate heat in and also away from the motor. I think it would be hard to get a satisfactory result without that.
    Some corretto just have the ability to knead for 20 minutes ( my first did), no mod required.
    robusto likes this.
    May 2011
    22
    Quote Originally Posted by 338 View Post
    Thanks. Had a look on gumtree and there's a small number of breadmakers at reasonable prices in Perth. I think I'll just have to keep an eye out.
    I wish I'd kept my old breadmaker - it died a few years ago after many years of service. The motor still ran, but the element had given up.
    Senior Member Beanz.'s Avatar
    Apr 2009
    245
    Quote Originally Posted by rodpinna73 View Post
    Thanks. Had a look on gumtree ............
    Have a look in your local Op Shops you should be able to pick up one in the $5 - $20 range
    May 2006
    99
    Behmor Coffee Roaster
    I noticed that under one of these listings, there was a roaster that looked like a powered hotpot/casserole cooker but it had 2 rotating metal arms. This looked more like a coretto with built-in heat generation but the only issue could be does it get hot enough? Output was listed as 800W but many were only 110V, the 220V versions were closer to $100 in price.
