View Poll Results: How long do you rest freshly roasted beans before moving to a container?
Voters
27. You may not vote on this poll
  • I move the beans to the container container immediately after roasting
    6 22.22%
  • I wait until the beans reach room temperature
    17 62.96%
  • I wait a several hours
    0 0%
  • I wait until the next day
    2 7.41%
  • Other (please specify)
    2 7.41%
Results 1 to 16 of 16
Like Tree17Likes
  • 4 Post By Dimal
  • 3 Post By LeroyC
  • 1 Post By Yelta
  • 3 Post By Yelta
  • 3 Post By LeroyC
  • 2 Post By Yelta
  • 1 Post By GrahamK
Thread: How long do you rest freshly roasted beans before moving to a container?
    Aug 2018
    Israel
    29
    I'm using Gene Cafe roaster since 2009 but have been quite inconsistent with how I handle resting and storage. I'm posting this thread to find our what others are doing. I'll probably create other similar polls about other aspects.
    Jul 2011
    Maddingley
    245
    I put mine in open one way valve bags until room temp or at least until the bag doesnít feel warm and then close the bag up. That works for me.
    If Iím in a hurry I prefer to shut the bags with warm beans rather than let the beans sit for hours.
    17,395
    Our bean cooler cools the beans down to ambient temperature within a minute and within another 4-5 minutes the beans are happily sealed inside foil lined, 1-way valve bags...
    They remain there for at least a week and up to two weeks before cracking the bags open again.
    Yelta, LeroyC, NJD and 1 others like this.
    Aug 2018
    Israel
    29
    I assume you're not using an air roaster? Because for air roasting I think this may be too slow. 3 days after roasting the coffee I roast with the Gene Cafe is not optimal, but it's certainly much better than 14 days after. I believe that with roasters that don't blow hot air the coffee ages more slowly, which would better fit your usage schedule.
    Dec 2011
    PRL
    2,722
    Quote Originally Posted by boren View Post
    It depends on the beans. Those from Yemen, for instance, and most robusta need a couple of weeks to hit their peak.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,353
    Thatís somewhat true, but not enough to be particularly useful. The only time itís really true is if youíre comparing exactly the same coffee roasted in comparable ways to the same end point on similar size, but different roasters. An SR500 v a Gene Cafe for example.
    Thereís no hard and fast rules about resting times, you just need to try to find what works for you with each coffee. The one thing I recommend is that you cool relatively fast after roasting, certainly within 10min and you then put into air tight storage thatís either opaque or able to be kept in the dark straight away. The old method of keeping coffee in open containers for 24hrs is a bad idea.
    Personally I usually wait at least three days for espresso roasts and 6-10 for lighter filter roasts. Iíll use coffee earlier if I need to, but never within 24hrs. Thereís a couple of tricks you can use if youíre espresso coffee is a bit fresh such as pre-grinding, but I wonít go into that here.
    Dimal, hawk87 and NJD like this.
    17,395
    What Leroy said... ^^^^
    Aug 2018
    Israel
    29
    I do notice once the beans reach about two weeks from roasting they don't produce what I would call good coffee, regardless of their origin. It might only be applicable to the Gene Cafe or to my personal preferences.
    The results of the poll seem to bear the same conclusion. I'll make sure to move the beans to the container as soon as they reach room temperature.
    I'm afraid there's not much I can do to accelerate cooling the beans beyond just raising the roaster hood and (maybe) directing a fan toward the roasting drum. I did this in the past but I'm not sure it benefited aging much so I stopped bothering. Maybe I should try it again and time how long it actually takes to cool the beans with and without the external fan.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,238
    I leave mine in the cooler until I'm able to comfortably able to touch them with no risk of burning my fingers, then place in one way valve bags immediately for at least a week.
    I will often, try them immediately after roasting, then a few days later to experience the change/improvement.
    Dimal likes this.
    Aug 2018
    Israel
    29
    @Yelta - Can you share what kind of roaster you're using? Do you find consistent improvements between, say, day 4 and day 7 after roasting?
    Jun 2009
    Moonta SA.
    7,238
    Evening Boren, I roast weekly with a Coretto setup, 750 grams green per batch.
    Improvement time varies enormously, all are a bit harsh immediately post roast, most are pretty good after a few days rest, its an incremental thing, kind of sneaks up on you, some continue to improve out to a month, it's really down to experience and personal preference.
    Dimal, hawk87 and boren like this.
    Dec 2019
    Vancouver
    4
    Once they're room temperature I move them to an unzipped Ziploc bag to de-gas on the counter for 24 hours, then into the airtight, opaque container from there. But by all means, let me know if I'm doing this wrong!
    Sep 2013
    2,353
    Quote Originally Posted by BeanPoet View Post
    I would avoid leaving them in the open like that. It really doesnít achieve anything except for accelerating their degradation a week down the track.
    Brewster, Dimal and Yelta like this.
    Jun 2009
    Moonta SA.
    7,238
    I suggest you put them into one way valve bags and expel as much air as possible, then seal the bag while they are still warm.
    Dimal and GrahamK like this.
    Senior Member GrahamK's Avatar
    Jun 2009
    Ormiston - Brisbane
    551
    I agree with this method, there is also a theory that allowing de-gassing within the one way valve bags drives out residual oxygen, thereby prolonging their shelf life?
    If you need to run them though a de-stoner first, then this is more difficult, but still bag them ASAP.
    GrahamK
    Dimal likes this.
    Feb 2018
    3
    Behmor Coffee Roaster
    I have a Gene Cafe also, and you can work around the preset cooling program. Normally, when you press the red button, it'll go into cooling mode which will turn off the element until it reaches 60 deg C, if you press the red button again, it'll run until 100 deg C.
    The work around, and the method I use, is:
    - when your roast has reached your preference, hold the red button down for "Emergency Stop": the chamber will rotate into the start/exit position.
    - remove beans and place into a sieve/colander and place over a fan [or have a search for other members cooling set ups]
    - put chamber back into Gene
    - start a dummy roasting program, and immediately press the red button to go into cooling mode, to cool down the chamber and roaster to 60 deg C.
    i hope that makes sense.
