Results 1 to 5 of 5
Like Tree5Likes
  • 1 Post By roosterben
  • 1 Post By Javaphile
  • 1 Post By barlo
  • 2 Post By ChrisHilder
Thread: Home roasters
    Feb 2020
    1
    Question Home roasters
    I want to learn to roast coffee (if I can master roasting then maybe I could start a small business). Can anyone recommend a good home roaster to learn on, preferably one I could source second hand? And who runs the best roasting courses? I'm in country NSW so Sydney, Melbourne or Canberra are in my range.
    Thanks for reading!
    Oct 2015
    248
    Welcome to CoffeeSnobs!
    Depending on your budget there are a few options for home roasters;
    1. Behmor 1600 Plus - Retails around $500 but currently out of production waiting on certification for the new model. Roast up to 400 gram of green beans. Best option here is second hand (once your post count is up you could post a wanted to buy ad on here) or wait for the new model. Behmor is about the size and shape of a microwave and uses electric heaters/fans and a wire bean drum.
    2. Gene Cafe - Retails at about $850 can be found from a number of CoffeeSnobs sponsors. You could use the quote form on the website. Roasts up to about 300 grams. Gene Cafe uses an electric element which blows hot air over the beans in a plastic drum.
    3. Hottop - These have different models and start at about $1,800. Hottop is getting towards a commercial roaster in design and has a metal drum and electric heating.
    4. KaffeLogic Nano - This is a small batch (about 200 grams) fluid bed (beans are roasted in hot air stream) roaster which retails for $1700.
    5. DIY - You can have a look on here for Popcorn roaster, Coretto roaster or Breadmaker roaster and depending on how handy you are you could build a DIY roaster for much less than the above.
    Various of the above can be connected to PC via USB to log heat probe temperatures to save/view roast profiles.
    In terms of roasting courses can't help you there as I don't know of but when you select a machine there are heaps on threads on here.
    Dimal likes this.
    Dec 2004
    Earth!
    16,170
    Quote Originally Posted by roosterben View Post
    The Gene Cafe is also available right here on CoffeeSnobs
    Java "Roast 'em up!" phile
    Dimal likes this.
    Toys! I must have new toys!!!
    Sep 2013
    48
    Welcome Naam. I recommend a Corretto (breadmaker+heatgun) roaster to learn on due to the low intial setup cost. You can get the hang of manipulating temps and observing how it affects the roast as well as see, hear and smell different phases such as drying, cracking etc all for under $100.
    However, if you seriously plan to start roasting as a small business you may want to get a roaster that has more similarities/crossover with the style of roaster you will end up using in that setting.
    Dimal likes this.
    Feb 2020
    1
    Behmor Coffee Roaster
    The Kaffelogic is a full profiling roaster, making it an excellent choice for learning on. Price is under $1600.
    Dimal and Caffeinator like this.
