Results 1 to 36 of 36
Thread: newbie roasting question
    Feb 2007
    51
    hi coffeesnobs,
    Im sure this question has been asked 1000 times before, but i couldnt find a faq or any posts in my quick search.
    Im looking into getting into coffee roasting and i want to know what my options are?
    I know with anything the more you spend the better quality product youll get? Im looking to go the cheaper option, any ideas on what a passable machine will cost? What are the ranges of machines out there to use?
    I dont really need to roast too much at a time, as long as it can do 100grams im happy!
    Apr 2005
    168
    Re: newbie roasting question
    Your options are basically to use a heat gun or popcorn maker. For less than $30 youll be doing what most of the roasters here are doing. There are many posts about technique on this site.
    May 2007
    Perth, Western Australia
    3,167
    Buy a bread maker 2nd hand, heat gun from Bunnings read Coretto roast threads and you will enter the wonderful world of roasting your own beans.......................
    Feb 2007
    51
    what about the greater than 30$ options?
    May 2007
    3,167
    My Coretto cost me $40 for 2nd hand Breville bread machine, $46 for Ryobi heat gun, $10 for a cooling fan from Bunnings plus some clamps and aluminium fly wire to make a cooling basket. I use the fan for blowing chaff and keeping heat gun cool, then use it over the cooling basket to bring roasted beans back to room temp as quick as possible.
    All up it cost me about $100, and the results are great, nice even roasts.
    cheers
    Greenman
    Feb 2007
    51
    and what popcorn machines would people recommend?
    Senior Member GregJW's Avatar
    Sep 2007
    Armidale, NSW
    618
    Hi Nicholas.
    Check out the threads on poppers.
    Breville Crazy Popper is about the most widely used - $30-40 (although there are others).
    I got one a few weeks back plus a starter pack from Andy, then a multi meter from Andy (very handy - oops, poetry unintentional), and with various other bits and pieces (soup tin chimney, fan, colanders, timer, one-way valve bags from Coffee Parts), Im roasting.
    Had frustrations at first, but now getting good results. Biggest variable I found was air temp (really threw results out - over 20 degrees TOO quick, under 15 too slow). Did my best 100 gms this morning (17.2 degrees) - El Savador AA - very controlled, smooth, even roast. Smells GREAT already.
    Anyway, at minimal outlay,its a good way to get started. (Dreaming of a Gene Cafe one day.)
    Greg.
    Feb 2007
    51
    thanks gregjw
    So you are using a crazy popper as well as what other items?
    Im just working out what I need. I think im going to go the popcorn option
    Sep 2007
    Armidale, NSW
    618
    Hi Nicholas,
    Check out the Roasters section under Coffee Equipment - HEAPS of advice re setting up and using poppers. Thats where my start came from.
    It is surprisingly simple.
    Briefly, I use an unmodified Breville Crazy Popper ($34 Bing Lee) with an open-ended soup tin in the top for a chimney, an ordinary pedestal fan to blow the chaff away and keep the heat down a bit, a Digitech QM1538 multi meter to monitor the temperature (from Bean Bay), a small digital timer, metal and plastic colanders to tip the beans into and cool, and one-way-valve bags (Coffee Parts) to keep the roasted beans in.
    Oh, and green beans from Bean Bay - Im about half way through Starter Pack. Reckon it wont take long at all before Im saving money.
    Oh, and a growing intuition.
    First 2 or 3 or 4 roasts were rubbish (figuratively and literally), but results and enjoyment are improving.
    Anyway, check out the Coffee Equipment - Roasters section on this site.
    Good luck.
    Jan 2007
    106
    Gday Nicholas,
    There are the dedicated coffee roasting machines out there, in order of price starting with the I-roast 2 (around $400), then next is the Gene Cafe then the Hot Top.
    Of course these options are more expensive that the popcorn popper option but thought it was worth a mention in case you were after something "off the shelf".
    Hope this helps a little.
    Steve
    17,391
    Start here mate and work your way through the first few categories in the "stickies".... cant go wrong,
    Aug 2005
    1,530
    As far as poppers go, Some other good ones are the Kambrook popcorn factory, and the older Mistral popcorn poppers (identical to Chief brand).
    I mainly use the poppers for sample roasters, and my turbo oven roaster for bigger batches. A turbo oven is a great heat source, if you get a pot the right size and use a motor to agitate. Windscreen motors can be had for cheap (got mine for $20), and just require a PC power supply to power. Another option for motors is a sewing machine motor, but I have no experience fiddling with one. Normal rotisserie motors are just too slow.
    Nov 2006
    1,673
    It all depends.
    This is a good guide http://coffeesnobs.com.au/YaBB.pl?num=1174699442 that I wrote a while back. I was using a cascade popper from The Warehouse and it is a very good popper. Even though I now have a BM and heat gun, starting with the popper is a very good option to start with and you learn a lot using this method.
    I will still keep my popper for the times when I only want to roast a small quantity of beans so it hasnt been retired yet.
    Sep 2007
    Armidale, NSW
    618
    Hi again,
    While on poppers, was thrown out a bit by having a gusty wind under the pergola this morning.
    Appeared to add a wind chill factor (?) to the ambient temp.
    Dropped temps, slowed everything up and made it hard(er) to hear second crack.
    Has anyone else had this problem?
    Oh well, just something else to allow for in the inaccurate world of popper roasting.
    3,498
    Greg,
    The problem with popper roasting is they are very "environment" sensitive.....
    Ambient temperatures which are high speed the roast up too much, cool temperatures slow it down as do strong breezes which affect the airflow through the popper (and hence the amount of air through the heater and the temperature of the roast).....
    If you can get all those factors under control they produce a good result - but that isnt always easy / possible.
    Since moving to a Corretto style roaster - I havent looked back! You have far more control, the heatgun has more than enough capacity in the heating department to make up for environmental changes.... and the fan blowing over the top of the Corretto during roasting (generally) takes care of the wind and also blows away the chaff......
    After some experimenting with a popper, Id certainly recommend trying a Corretto... it really is so much easier and the results are always repeatable!
    Oct 2007
    10
    Thanks for the great tips and ideas. We have a popcorn popper sitting in the bottom of the pantry somewhere so I may drag it out this weekend and try my hand at roasting my own.
    17,391
    You will be amazed :o at the difference b.b....
    Oct 2007
    50
    Whats a corretto? I keep thinking its cornetto - the icecream
    10,496
    Its a Breadmaker with a heatgun for roasting the beans.
    Named after Coffee Snob "Corretto" who first brought the idea to our attention.
    Mar 2004
    Internet
    17,216
    A roasting method named after the local CS inventor of the method...
    http://coffeesnobs.com.au/YaBB.pl?action=viewprofile;username=Corretto
    Using an old bread maker and heat gun you can roast great coffee.
    Also try:
    http://www.google.com.au/search?hl=en&q=%2Bsite%3Acoffeesnobs.com.au+%2Bcor retto&meta=
    Mar 2004
    Internet
    17,216
    Snap Thundergod
    The only thing you missed was a nag to try the search engine on the site or google
    Senior Member Lizzie's Avatar
    Feb 2007
    Bridport, Tas
    1,151
    it is the name given to the method of roasting coffee beans using a heat-gun, and the agitating action of the paddle in the bottom of a breadmaker-bin on the "dough" cycle.
    the lady who so brilliantly conceived the idea had "Corretto" as her forum handle, and hence the name of the method was christened "Corretto, in honour of her ingenuity
    use the search engine to gather more info, it is a fantastic way of roasting 300gm or more in one hit, with excellent results!
    good luck, and enjoy!!
    L
    Edit: Snap!!
  23. #23
    3,498
    Corretto?
    A coffee roaster named in honour of one of our members (of the same name) who invented the idea....
    Take one unloved bread machine...... used to agitate the beans during roasting....
    Take one heatgun and aim nozzle at the beans being stirred inside the bread makers bowl..... and roast away......
    See: http://coffeesnobs.com.au/YaBB.pl?num=1154442377/0
  24. #24
    Sep 2007
    Armidale, NSW
    618
    Seem to have lost a post I made back there - oh well. Also having trouble attaching a jpg photo (probably linked problems?). Any suggestions?
    Anyway,
    I had a think about setting up a Corretto before just getting a popper. Its still definitely on the cards down the track, when the time is right (one step at a time for loved ones trying to comprehend this descent into espresso insanity).
    I have marvelled at Correttos ingenuity - brilliant!
    Doing alright in this world at present, getting better (some very good) results with the popper (climatic irregularities and all). Have a pretty picture of yesterdays El Salvador AA roast if I can work out how. Gotta be easy (slow learner at the wheel).
    Nup, not there. Help!
  25. #25
    Oct 2007
    50
    can the bread machine still be used for making bread after being used for roasting beans?
  26. #26
    3,498
    Quote Originally Posted by amberosw link=1192605296/15#24 date=1192700459
    Well if it is the correct type (one which agitates the dough / beans for about 20 minutes....) no problem....
    If it needs to be modded to agitate for that long without pausing .... it might be a problem (depending how the mod was done)...
    But who wants to bake bread in a coffee roaster.... after all thats what it does best ::) ::) ;)
  27. #27
    Feb 2007
    Bridport, Tas
    1,151
    if you an find a unit with a 25 min dough cycle, you can easily use it for baking bread, as it does not have to be modded.
    but, make sure the "pulley", the bit under the bin which moves the paddle, is made from steel, not from plastic.
    roasting coffee happens at much higher temps and the plastic wont handle it, as i found out :(
    i bought a second bread bin from a small appliance repair guy, specifically for roasting.
    that way i had bread-tasting bread and coffee-tasting coffee ;)
    L
  28. #28
    Aug 2007
    846
    Quote Originally Posted by amberosw link=1192605296/15#17 date=1192694570
    & apart from the ingenuity of Corretto who chose to venture out of da box, & revolutionise home roasting, the name refers to a correction of espresso with a bit-a-booze.
    Maybe that helped with identifying a BM as a great vessel to roast!
  29. #29
    Feb 2007
    Bridport, Tas
    1,151
    no need for the booze Grinder, women can think when they are sober... ;)
    L
  30. #30
    Aug 2005
    1,530
    Booze just makes the roast look better.
  31. #31
    Mar 2004
    Internet
    17,216
    (cheeky rabbit) ;)
    As it happens the very same CS Corretto is also a home brewer so maybe the lines did cross somewhere?
  32. #32
    Aug 2007
    846
    Quote Originally Posted by nunu link=1192605296/15#29 date=1192714977
    And the women? ;D
    Running back to my corner now ;)
  33. #33
    Feb 2007
    Bridport, Tas
    1,151
    Quote Originally Posted by Andy Freeman link=1192605296/30#30 date=1192716228
    (cheeky rabbit) *;)
    shut up, Rabbit...
    L *
    (says she, who takes homebrewing a tad further... into the clear cool spirit of the Russians, the essence of Londons Dry, the smooth lifeblood of Tennesee...)
  34. #34
    Oct 2007
    10
    buy green bean ?
    where can i buy good green beans in sydney for home roasting ?
  35. #35
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Welcome chrisleroi!
    Every month, 100s and 100s of kilos of green beans can be purchased right here on a poll (see left of screen buy green) and shipped all around AU. Take a look and see what you missed out on this month!
    You will also see a starter pack available - premium beans at great prices, shipped to your door in days.
    Enjoy!
  36. #36
    10,496
    Behmor Coffee Roaster
    Welcome.
    Do you have something yet with which to roast them?
  1. Home Roasting Question - Newbie
    By Quantum40 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 14th May 2010, 01:49 AM
  2. Newbie roasting blends question
    By NewToEspresso in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 10th July 2007, 01:55 PM
  3. newbie question - need help
    By silverpearl in forum Brewing Equipment (non-machine specific)
    Last Post: 25th October 2006, 04:57 PM
  4. Another newbie question
    By csutak40 in forum General Coffee Related...
    Last Post: 25th November 2005, 03:01 PM
