Results 1 to 14 of 14
Thread: speeding up the cooling
    Feb 2005
    3,098
    Weve talked about slowing down the roast, but what about speeding up the cooling.
    Gadgets are great, and I personally love them. Ive seen many inventive ways to cool beans quickly. But simplicity works well, too.
    I pour the hot beans into a steel colander. Steel, because it conducts heat away from beans, and doesnt melt! A non-perforated saucepan would probably work just as well.
    I then lift the colander about 30 cm and decant the beans into another similar colander, (sitting on the table, chair or whatever), while an ordinary small 150mm personal fan blows at them as they fall.
    The process is repeated quickly a few times for a minute or so, by which time the beans are cool to touch.
    Certainly any cracking is stopped dead, instantly.
    As the beans fall, they are naturally air cooled. They also lose heat to the metal colanders.
    The fan further cools them and-- best of all -- blows away whatever chaff the perforated barbecue drum roaster hasnt burned off already.
    Any stubborn chaff clinging to the beans is removed by either tossing them within the colander or swirling them around a little.
    It works well.
    Dec 2004
    Earth!
    16,346
    Re: speeding up the cooling
    If you want to stop the roast virtually instantly try quenching your beans with a fine mist of water. You want to use just enough spray to drop the beans temp but not so much that water remains on the beans.
    Java "Ugh, Ive had enough of water!" phile
    May 2005
    Perth
    1,389
    Java:
    I am surprised to hear you commenting favourably on water. I would have thought that even passing water would have been difficult for several weeks.
    Grant
    Dec 2004
    Earth!
    16,346
    Yeah well, ya gotta do what ya gotta do. :-/
    Java "Water is NOT my friend" phile
    Feb 2005
    3,098
    Javaphile, The only water Id like coming near my roasted beans is very hot --93 degrees *C.
    Ro "some like it hot" busto
    Dec 2004
    Earth!
    16,346
    Robusto,
    Properly done (a fine enough mist in the proper quantity) no water is absorbed by the beans as it is all instantly turned to steam.
    You dont use the water to cool the beans with completely, just to get them below roasting temperature.
    Java "Water can kiss my you-know-what!" phile
    Mar 2004
    200
    I usually quench the beans with a fine mister before using the same technique as Robusto, pouring from one container to another, even then if I can mange it Ill attempt to spray them as they fall between containers for the first couple of drops.
    Depends on the batch size but anything over 300grammes or so I find the air cooling takes too long without a water quench to begin the process. I had a pretty efficient bucket vacuum combo setup as others have documented elsewhere which I use at home base but away from home the colanders and water bottle do the trick.
    Some commercial roasters use a combination of water quenches and air drops as well
    Feb 2005
    441
    Im intrigued by the water cooling thing - never tried it, cos i dont have a good spray bottle, but im still intrigued.
    My method is to dump the beans onto a pizza tray that sits on the window sill with a big fan blowing air across the top - As soon as Ive dumped the beans, I spread them out on the tray. Ive found that this cools the beans in about 5 seconds. Theyre completely cold to the touch after about 30 seconds, even less on these cold winter nights!
    Nov 2004
    Augustine Heights QLD
    302
    I used to use a vacuum and hose set up, but it all got too complicated. Now I just use the motor section of the barrel vacuum.
    I have a large plastic bowl with some fine mesh wired in place about half way down the bowl. Ive cut a hole in the bottom of the bowl the same size as the vacuum inlet hole on the motor. I have it plugged in and standing by ready. As soon as the beans are ready, turn on the vacuum and tip the beans in. 20 seconds max. 8)
    Boris
    Jun 2004
    138
    As the quantity that I roast are generally 500g at the most, the fan works well for me. Cools them down in 30 seconds. Also gets rid of any remaining chaff that are hanging around
    Jul 2005
    128
    I was wondering if anyone has modified a popper so that one can turn off the heating element and just let the popper continue to blow cool(ing) air through the roasted beans?
    Or would there be too much heat still in the popper?
    If so, one could pour the beans out into a colander to quench them whilst simultaneously turning off the poppers heating elelment. Wait a few seconds then pour the beans back into the popper.
    Ron
    Dec 2004
    Earth!
    16,346
    One of the standard mods out there for poppers is to split the heating and fan into 2 different circuits. Which would allow you to turn off the heat but leave the fan going.
    The problem with this is the beans continue to roast while the heating coil cools down as you mentioned. By the time the heating coil has cooled down completely the beans would already have been fully cooled using a seperate cooling set-up.
    Java "Mods are fun!" phile
    17,584
    Quote Originally Posted by Javaphile link=1120187721/0#11 date=1122357816
    You bet, but there is a much better reason for splitting the circuits up like that, eh Java ;) ,
    Dec 2004
    Earth!
    16,346
    Behmor Coffee Roaster
    Quote Originally Posted by Mal link=1120187721/0#12 date=1122385009
    Indeed Mal, indeed! ;D
    Java "Gotta love a good Mod" phile
  1. Hottop cooling
    By gregpullman in forum Roasters
    Last Post: 21st October 2009, 12:01 AM
  2. Speeding up the time between Roast to Ready??
    By tasadam in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 16th August 2009, 09:18 AM
  3. Cooling Beans
    By dxj in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 20th July 2009, 08:28 PM
  4. Help with cooling popper
    By Mart71 in forum Roasters
    Last Post: 30th April 2008, 10:55 PM
  5. Cooling flush
    By jimmyb in forum Brewing Equipment (non-machine specific)
    Last Post: 31st May 2007, 01:33 PM
