Results 1 to 5 of 5
Thread: Chaff in my filter
    Feb 2008
    121
    Chaff in my filter
    Hi All,
    I roast with a modified popcorn machine and am doing pretty well - have managed to extend my roast times from 5 minutes to over 9 minutes with some pretty good results.
    My problem now is how to get rid of all the chaff that seems to stick to the roasted beans after I use my dripolator there seems to be chaff residue left in the filter.
    During cooling I toss the beans back and forth and swirl them around the 2 collanders that I have and then blow the chaff away but there is obviously some chaff still there - any ideas?
    Nov 2006
    1,077
    Re: Chaff in my filter
    Hi Springbok
    Can you post a pic of what the roasted beans look like with the chaff on?
    i used to roast via the popper and never suffered from this but it sounds like the level of roast perhaps, i have done roasts in the past that when ground you see noticable flecks of light brown that match the chaff colour.
    I put this down to not roasting through to SC and its the tiny part of the chaff that is still attached to the bean perhaps at the stage that the roast is stopped.
    Since using the corretto and taking my roasts to just before or just into SC, i dont have this problem anymore.
    Mal
    10,496
    I always seemed to have a lot of chaff left in the split of the beans from my popper roasts.
    It didnt bother me though I did supect it affected the grind setting because I figured Id need a finer grind to allow for the chaff in the mix.
    As bolb said, I notice it less now using a corretto.
    Is it bothering you?
    Taste?
    Feb 2008
    121
    Thanks guys,
    I think you must be right - it seems to be the light bits in the split of the beans - it doesnt bother me that much and I prefer the lighter roasts - but it is noticeable and I wondered if there was an easy fix- I also give coffee away as presents and someone asked me about it - talk about looking a gift horse in the mouth...
    Aug 2007
    846
    Behmor Coffee Roaster
    Springbok, the chaff in the centre could also be an indicator of an uneven roast. Ive never used a popper, but are you monitoring the temperature ramps? If youre getting to FC too quick, with quick temp rises, the beans may be roasting quicker on the outside & not evenly penetrating to the core.
    Heres a suggestion - next roast, grab a couple of beans, split them open, put them under a light, & see whether theres eveness in tone.
    Some SOs, however, seem to hold a slim tissue of chaff in the middle regardless of roast profile/length of roast. Especially PNG beans in my experience - Ive done quite a few roasts, with differing temp ramps/some extended roasts just on SC, but all seem to retain that little sliver of chaff.
    Anyhoo, my quick thoughts.
    And as TG mentioned, if the taste isnt bothering you I wouldnt be overly concerned. :D
    Tony
  1. Gene chaff filter maintenance
    By muppet_man67 in forum Roasters
    Last Post: 24th November 2012, 10:18 AM
  2. GeneCafe - Too Much Chaff?
    By Coffee2Di4 in forum Roasters
    Last Post: 21st July 2010, 05:33 PM
  3. Chaff Removal
    By Coffee_Kid in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 7th January 2008, 10:28 AM
  4. Chaff
    By Ox in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 31st October 2006, 01:59 PM
  5. Getting rid of the chaff
    By ajhclarke in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 27th April 2006, 09:40 PM
