Results 1 to 4 of 4
Thread: Ozito heatgun meltdown and Type K thermocouple
    May 2008
    437
    >:( ::) ;D
    I was doing a dry run with my Corretto-in-progress, testing my self-fibreglass-insulated thermocouple up to 260*C, when I noticed the heatgun melting down instead!!!!
    Blah.
    The thermocouple exposed tip was melting back, so Id better not take it over 230*C again, and the white and blue covering of the thermocouple was beginning to yellow under the fibreglass.
    EDIT update: everything seems fine when I keep it below 220*C, but I have to keep the HG nozzle out of the pan, which is a small one anyway so heat distribution is pretty easy. Out with a fan to keep the HG cool... ahhh, of course that works!
    Consistency in temps starts to show on my DMM.
    ev
    ev is offline
    Jan 2005
    156
    Re: Ozito heatgun meltdown and Type K thermocouple
    I think youll find that a dry run may also cause it to get too hot. Better off putting some beans in & doing the real thing. You dont want to overheat the pan & drive coupling if you can avoid it. Id also recommend a back-up HG just in case the ozito burns out like mine did. It didnt last very long at all.
    Evan.
    Mar 2008
    107
    Intellidepth, have posted a couple of things in your "Tips for first ever roast?" thread that addresses the heat issue.
    Could even look at half a lid, to shield the HG a bit from the heat coming back.
    Cheers..................Sean
    17,475
    Behmor Coffee Roaster
    Quote Originally Posted by scooter link=1214624638/0#2 date=1214825298
    Yep,
    Thats what I do Sean and it seems to work pretty well. Also seems to have the added benefit of creating a slightly more uniform and hotter roasting environment, which is good for roasting larger batches (in my case anyway ;)).....
  1. thermocouple type?
    By WSullivan in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th September 2014, 01:59 PM
  2. Fitting a bead type thermocouple (to a Silvia).
    By Toad in forum Brewing Equipment (non-machine specific)
    Last Post: 28th August 2012, 09:18 PM
  3. ozito temperature variable heatgun
    By gavin in forum Roasters
    Last Post: 5th August 2009, 09:42 PM
  4. thermometer with K type thermocouple
    By Gra in forum General Coffee Related...
    Last Post: 24th February 2009, 08:13 PM
