Results 1 to 6 of 6
Thread: Roasting MTC Bin549
    Jul 2007
    527
    Roasting MTC Bin549
    Im not sure have i done the right thing to this bean. CAn anyone give me some comment? THe coffees taste alright.
    My roasting profile for my last few times are:
    It takes ~7mins30secs to the FC. The FC finished at 2-3mins after. The SC come ~6mins after the FC finished. I normally stop my roast at the beginning of SC.
    Does it look right? Everyone please give comment.
    Tony
    Jul 2007
    527
    Re: Roasting MTC Bin549
    Here is the pic of my roast. Does it go too dark? I reckon it is between CS10 and CS11
    Jul 2007
    539
    The time to FC sounds too fast to me.
    This bean appears to have a very high moisture content. Ive only done 2 roasts of this so far, but my best one was when I dried the beans out on a baking tray in the sun for 2 days before roasting. The beans lost about 10% of their weight by doing this, and the beans colour became lighter - closer to the colour of most of my other beans. Then I used the profile below:
    6:00 to 150C drying stage - beans should be an even yellow colour before progressing further,
    10:15 start of FC
    15:15 end - CS 9.5 with a slight oil sheen on the beans
    The result was very impressive from this roast, so Ill have to try to recreate it again sometime.
    Jul 2007
    527
    Bill: Thx for your advice.
    But my problem is Im using IMex for roasting. I cant really control the temperature. SO how can i slow down the roast? Also, how can u tell my bean have a high moisture content? I really want to know about this cos my roast doesnt smell right at all. Dont know whether it is due to the moisture contect. But they do taste well. Maybe i should consider using "coretto" for roasting;).
    Tony.
    Jul 2007
    539
    Well I assume it has a high moisture content due to the beans being a very dark green colour - much darker than any of my other beans. Also the MTC Bin 35 has been described on here as having a high moisture content, and this bean is a similar dark colour to the Bin 549.
    Im not familiar with the Imex, so cant help you there. Can you increase the airflow through it somehow? Or roast at a cooler time of day?
    Jul 2007
    Werribee, Victoria, Australia
    737
    Behmor Coffee Roaster
    Hi Sugilun, I have done 1 fantastic roast with this bean and it does take a long time to achieve 1CR I think it took me nearly 11min in my pot roaster, then I finished it at the very first signs of 2CR .
    One thing I *noticed is that they finish darker, than other beans I have done at this roast level.Probably because they started much darker.
    I cant help with the IMEX but maybe a pedestal fan to blow away some heat might help to stretch your roast times.I am yet to try a roast in my new corretto once I have got the hang of it I will try to do one.
  1. Pros & Cons - Air Roasting versus Drum Roasting
    By Dolcimelo in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 9th January 2013, 10:37 PM
  2. home roasting into commercial roasting
    By drink1121 in forum Roasters
    Last Post: 28th September 2012, 11:36 PM
  3. Cast Iron Pot roasting…gas fire roasting
    By colombiasmoothbean in forum Roasters
    Last Post: 17th May 2012, 05:17 PM
  4. New to Roasting
    By scollops in forum Roasters
    Last Post: 11th May 2010, 06:10 PM
