Results 1 to 21 of 21
Thread: Has this been tried before?
    Jul 2008
    323
    Until I can afford/locate a suitable BM Ive been tryin to think up ways to build a temporary roaster.
    I dont have a heatgun yet..still tryin to find somewhere that sells decent ones
    My latest idea is to set a heat gun up like in the pic and then make a support for a SS colander so that it sits directly above the heat gun allowing me to manually stir the beans.
    Would the holes in the colander allow enough airflow through to roast the beans?
    Im really just thinkin out aloud here and wonderin if anyone else has tried a similar method to this..
    Apr 2008
    Brisbane
    5,115
    Re: Has this been tried before?
    Dont think so gronk
    More heat will be lost than actualy doing its job
    Keep the colander for cooling
    The BM enclosure is actually assisting the HG to have consistent heat distribution
    TG can probably explain it better
    Jul 2008
    323
    Quote Originally Posted by Koffee Kosmo link=1221447729/0#1 date=1221451176
    Dont think so gronk
    Yeah thats what I was afraid of. Had to ask anyway. Thanks :)
    Apr 2008
    Brisbane
    5,115
    Many people use a S/S bowl even a dog bowl is ok
    and hand stir the coffee beans with a whisk
    Does the same job and you get some exercise? ;)
    You tube has a video on it if you do a search
    10,496
    Dont think so gronk
    No I cant.
    You explained it very well.
    Gronk - I have an identical looking colander that is attached to the top of my cooling bucket.
    My current HG seems to have a lower airflow than my previous ones but even so youd be heating the metal more than the beans. It would be more like a pan roast than a HG/bowl roast and the heat supply would probably be inadequate.
    You can pick up a cheap SS bowl in most junk shops but I was lucky and got mine at K-Mart one day on special.
    I had an old stock pot I hadnt thrown out which was just the right size to sit the bowl in.
    Why?
    So that I had some insulation between me, and the SS bowl (plus handles).
    Prior to that, the bowl got hot enough to start melting the milk crate it was sitting on.
    Cheap SS bowl, wooden spoon, heatgun. Easy.
    Jul 2008
    Port Fairy
    2,993
    Hi Gronk,
    Safeway had some nice deep rubber bottomed Stainless bowlsfor $8 that work really well while you hunt down a BM the dog bowls were all $11-12. The rubber saves chasing the bowl around the table as well ;) I am only about 6 roasts down so far but it is working well.
    The strainer is what I started using for a cooler initially but it still took a while to get the temp down without any air going past the beans.
    May 2007
    725
    As others have replied before, the collander wouldnt suit roasting with the HG underneath. The holes are insufficient to let enough hot air in. In fact, I used to use pretty much the exact same collander for cooling with the fan underneath. It didnt do the job well even as a cooler. Ive since started using a different collander, a wire mesh type for colling and it does the job way better. Id imagine the same would apply to heating.
    You can get really cheap used breadmakers which Id prefer way ahead of a s/s bowl. The most difficult part of this process is creating a handsfree HG holder. Once youve got that sorted out, the rest is easy. That is, until you desire to have a lot more control and know what temps and heat rise rates etc... The accessories keep increasing (temp probe, CS software etc). And its all great fun!
    Jul 2008
    323
    Quote Originally Posted by Koffee Kosmo link=1221447729/0#3 date=1221452249
    Does the same job and you get some exercise? *;)
    Ive considered the dog bowl arrangement but I dont like the idea of holding both the HG and stirring stick at the same time. Maybe Ill just make a stand for the HG similar to what others use for their BM correttos.
    I have watched heaps of videos on youtoob and am amazed at the inventiveness of some people :D
    The only thing slowing down the whole process of setting up my own roaster properly is Im currently saving every spare penny to upgrade my grinder to a Macap or Mazzer, otherwise Id already be roasting in a BM :)
    Nov 2006
    1,077
    Gronk
    If you are into brewing beer and have a bottle capper, this makes a great stand, all you need is a clamp to clamp to the capper handle and a counter weight (claw hammer) and it all works a treat.
    Mal
    Jul 2008
    323
    Quote Originally Posted by bolb link=1221447729/0#8 date=1221476328
    Gronk
    Mal
    Ive got a small "portable" drill press (similar to the pic) which will be perfect for the job....once I unbolt it from its moorings and make it "portable" again :D
    Jul 2008
    323
    Well Im under way!!
    Picked up a brand new Ryobi variable temp heat gun last night at bunnings.
    It has the usual 2 fan speeds, but also has a dial and LED indicators on the back that allows constantly variable heat settings between 50 - 650 degrees C
    Just ordered a greanbean starter pack. *
    All I need now is a bowl and a colander
    Aug 2007
    846
    Quote Originally Posted by gronk62 link=1221447729/0#10 date=1221615230
    ... All I need now is a bowl and a colander
    ... and a fan matey, aimed at the beans & heat-gun while roasting - prevents too quick a rise in temp in the beans, keeps your heat-gun under less strain, & blows the chaff away.
    Try and source a hands-free one, if you can ;D
    Jul 2008
    323
    Quote Originally Posted by GrindOnDemand link=1221447729/0#11 date=1221623781
    Ill "borrow" a fan from one of my daughters rooms till summer ;)
    Nov 2006
    1,077
    Good luck with it all Gronk.
    I have never roasted via manual stirring before so i wish you well.
    I am sure the results will be a real eye opener. ;D
    Mal
    Jul 2008
    323
    Quote Originally Posted by bolb link=1221447729/0#13 date=1221652995
    I am sure the results will be a real eye opener. *;D
    Mal
    ;D Thanks Mal.
    Looks like Ill be havin a crack at roastin before I got to watch you give me a demo run.
    Ill just fumble my way through it, no doubt stuffing the first batch or 2 at least. :)
    Jul 2008
    Port Fairy
    2,993
    Hey Gronk,
    you want to check out a member "swig" saw a posting from him last night lives in Warragul seems he home roasts too.
    If you roast it a bit light they go well in a plunger if you get them to dark get the fire blanket ;)
    Jul 2008
    323
    Quote Originally Posted by beanflying link=1221447729/0#15 date=1221734933
    Eeeww! Ive got a plunger that I havent used for several years...along with various other coffee makin contraptions.
    They all live in the back of a cupboard in a dark and forgotten corner of a shed now ;D
    Im gunna build a bean cooler similar to the one Thundergod thunk up, which theoretically should suck the heat outa them before they go nuclear...I hope :D
    Mar 2007
    123
    It may have been alluded to before, but you can put the collander INSIDE a stainless steel bowl, then heat from the top, stirring. *The SS bowl will better hold the heat under the collander. *When youre done, pull out the collander and place it on your cooling fan.
    CHAD
    Mar 2008
    466
    Quote Originally Posted by gronk62 link=1221447729/0#16 date=1221735808
    They all live in the back of a cupboard in a dark and forgotten corner of a shed now *;D
    Whats wrong with plungers? *;D
    Just because espresso is [sarcasm] "King" [/sarcasm] it doesnt mean you cant enjoy coffee in all its forms (plunger, drip, syphon, espresso etc.)
    edit: Off topic I know
    Jul 2008
    Port Fairy
    2,993
    Not entirely off topic.
    I did a deliberate roast last week with Plunger in mind. PNG Wahgi to a lighter roast than espresso. Tastes fairly good in a Plunger (in my modest opinion ;) ) but I tried it in an Espresso and it was average. Roasting tomorrow same bean into 2nd crack for espresso.
    Tried a few of the CS Espresso brews in plunger and they were average but in a Vac Pot were great.
    Lots more playing needed with all coffee toys, but the Plunger is now last on my list :)
    Jul 2008
    323
    Behmor Coffee Roaster
    Quote Originally Posted by beanflying link=1221447729/0#19 date=1221822171
    The PNG wahgi was my favourite by a long shot out of the brown bean sample pack I tried over the last few weeks.
    Im hopin to get some as green beans in the future.
    Currently waitin for my green bean sampler to arrive (monday hopefully) but dunno if it contains any wahgi yet. Fingers crossed :)
