Results 1 to 8 of 8
Thread: Want to start home roasting: equipment advice
    Mar 2008
    120
    Hi, guys!
    I will be moving into a bigger place with bigger kitchen soon. I decided that since I will have some space on the bench, I will start roasting at home. I am very excited about it. However, I dont know where to start. What do you recommend. I wouldnt want to splash big bucks on the roaster, unless I absolutely have to. However, when I start, I would want to focus more on the roasting and beans than on messing with equipment. Also I wouldnt want a temp solution which I will have to change in a year or so.
    What options (in terms of equipment) do we have, what would you recommend?
    Also, I have very little knowledge of the roasting process. Any links, reading how-tos that you can recommend for the beginner? I have been to home-barista.com and some other sites. I couldnt find one simple and comprehensive guide for a dummy.
    Ed
    Senior Groupie LindaD's Avatar
    Bacchus Marsh, Victoria, Australia
    450
    Re: Want to start home roasting: equipment advice
    Welcome Ed!
    All depends on your budget. Alot here started off with a popcorn popper and advanced to more serious roasting equipment.
    http://coffeesnobs.com.au/YaBB.pl?num=1219897283
    Try this link above ^^^, and a search in this forum will turn up some answers for you.
    Good Luck!
    -Linda
    10,496
    A guide to Popper Roasting http://coffeesnobs.com.au/YaBB.pl?num=1174699442
    All about the Corretto http://coffeesnobs.com.au/YaBB.pl?num=1154442377
    Jan 2007
    541
    Ed
    There are lots of options [homespun and retail] available, many are not suited to indoor roasting due to the chaff created by the beans.
    Can you confirm you intend to roast indoors [it will narrow down the field of available options]?
    Mar 2008
    120
    I would prefer to roast indoors and thats what I was planning on doing. However, if I must roast outdoors, I probably would be able to do this too.
    However, I would love to roast indoors regularly. I would also want to avoid messing with hardware myself if thats possible ;-)
    May 2007
    302
    In that case you are probably going to have to look over on the left
    to some site sponsors who sell the non DIY roasting stuff (iroast, gene etc)
    Good luck with it - I am going to be trying the roasting thing too over the chrissy break.
    Jul 2007
    2,288
    I roast indoors with a Gene Cafe and am pleased with the results. It does need to sit under a working extractor fan or it sets off the smoke alarms.
    I can set up, roast, and tidy away in half an hour.
    Nov 2007
    BRISBANE
    201
    Behmor Coffee Roaster
    Be worth reading site sponsor Greg Pullmans review of Hottop and Gene Cafe roasters on his Pullman Tampers website if you havent already seen it.
  1. Home brewing equipment - advice needed - height restriction for equipment.
    By wannabasnob in forum Brewing Equipment (non-machine specific)
    Last Post: 18th July 2014, 01:30 PM
  2. Home roasting advice please !!
    By karl_2020 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 21st November 2012, 08:35 PM
  3. I want to start home roasting
    By kanda712 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 12th June 2011, 10:53 AM
  4. Home Roasting Equipment
    By Paul in forum Roasters
    Last Post: 29th July 2005, 04:05 PM
