Results 1 to 6 of 6
Thread: Bezzera Zo2 - Milk frothing problems
    Sep 2006
    22
    I have purchased a recon zo2 - draws a nice shot but I cant seem to get the frothing right - heats the milk fast but lots of silky foam - no way known
    Seems to have a multiholed steam head - Im used to a single - could this be a problem or is it simply operator error
    Apr 2008
    Brisbane
    5,115
    Re: Bezzera Zo2 - Milk frothing problems
    Turn steam on full
    Also see this link and follow instructions on post #1
    http://coffeesnobs.com.au/YaBB.pl?num=1220959662
    Post results if it works for you
    Sep 2006
    22
    followed the thread and have used about 3 l of milk with no real success - the milk always heats too fast to get significant amounts of foam - i.e. the foam is ok but theres not enough for one cappuccino
    May 2008
    4,183
    As per KKs instructions in the link, start with the tip just immersed in the milk, not buried in it, so the stretching starts straight away. Listen to ch-ch-ch sound and make sure you can see the milk expand - but not too much - 20% increase is plenty then dip the tip in deeper to stop the stretching but only a little deeper until the milk is heated.
    Try adding a tiny drop of ordinary detergent to water and practice stretching that so you arent wasteing milk (but dont make lattes with it *:D )
    It took me quite a while to get the right technique but I had the opposite problem of over-stretching. Get someone to demonstrate on your machine if possible.
    Sep 2006
    22
    thanks will persist with detergent - my wife can hardly drink another coffee and the kids are sick of warm milo
    might be easier for a slow learner to go back to a single hole nozzle as in my old rancilio
    Jan 2009
    83
    guessing but your old machine having only 1 hole in the steam tip was a domestic machine. you now have a semi commercial machine which will have more pressure. notice how you can control steam pressure. slight turn of handle =low pressure vs complete turn =full pressure. if you are using a small jug (e.g 400ml) and open the steam valve on full blast then I can imagine little time to stretch (froth) milk before temp is high.
    I suggest buying a bigger jug, half filling it only a practice with steam pressure control, balancing stretching and temp over time.
    get cold milk spinning, then stretch with tip, then heat.
    hope this helps
  1. best milk for frothing
    By adjiland in forum Milk Froth and Bubbles
    Last Post: 29th April 2013, 01:42 PM
  2. Bezzera frothing...help!
    By Dave_D in forum Milk Froth and Bubbles
    Last Post: 3rd May 2008, 06:11 AM
  3. Frothing with a Bezzera BZ99S
    By vast524 in forum Milk Froth and Bubbles
    Last Post: 27th April 2008, 10:51 PM
