Results 1 to 3 of 3
Thread: Problems creating microfoam
    Jan 2011
    16
    I own gaggia coffe deluxe. I have problems creating microfoam, every time i try to steam milk everything is good but on the end i have milk bubbles on the top and when i put milk in the first coffee i get only milk foam on the top of the coffee...The second coffee is good and the foam is like it should be. What i am doing wrong? What should i try to eliminate that foam bubbles on the top of the milk?
    Mar 2004
    118
    Re: Problems creating microfoam
    Try banging the jug on the bench top gently this will pop most of the bigger bubbles.
    Try lowering the tip into the milk just before you turn the steam off.
    Not forgetting to blow the residue milk out of the wand once you done.
    Hope that helps.
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 40474541424F714C4C2E0 link=1294422928/0#0 date=1294422928
    Have a look at this thread of the KK method
    Also see the video by sluggo33 with his Gaggia
    http://coffeesnobs.com.au/YaBB.pl?num=1220959662/118#118
  1. Some tricks for creating great microfoam
    By Koffee_Kosmo in forum Milk Froth and Bubbles
    Last Post: 1st July 2019, 07:15 AM
  2. Problems creating good foam with Napolitana
    By jamesayers in forum Milk Froth and Bubbles
    Last Post: 13th November 2007, 05:42 AM
  3. observations in creating microfoam
    By coffeeNcake in forum Milk Froth and Bubbles
    Last Post: 5th June 2007, 12:21 PM
