Results 1 to 9 of 9
Thread: Cant Get Enough Air Induced In Bottom Portion Of Milk and also Foam Dissipate Issue
    Feb 2012
    19
    First, I would like to clear say that I am able to make microfoam that looks beautiful. Im having a couple of horrible problems with my milk frothing.
    1) microfoam consistency through the milk- The bottom of the pitcher doesnt have equal amount of air. The top half is good and fluffy, the bottom portion is less.
    2) If I make a cap or latte to go, after 5 minutes the frothed foam turns to liquid without drinking it.
    I am using 4-6 oz of whole non fat milk.
    I know I am frothing correctly because I start out with the 12oz pitcher and 1/4 full of milk. I stretch the milk until it rises about 1/4 high with microfoam. Then I* roll the milk until it hits 165 F degrees. When I am done the pitcher is 3/4 full of milk(as opposed to 1/4 full when I started). The microfoam is beautiful and by all variables I am doing this correctly.
    I am using a Silvia. Is the lack of steam pressure the cause of the lack of air induced in the bottom of the milk pitcher? There is some/little induced air in the bottom portion of the milk, but no where near or equal to the upper portion.
    Is the Silvia steam being on the wet side causing the forth milk to turn to liquid if I dont drink the cap/latte in 5 minutes?
    Senior Member specialpants's Avatar
    Dec 2010
    310
    Re: Cant Get Enough Air Induced In Bottom Portion Of Milk and also Foam Dissipate Issue
    Quote Originally Posted by 757C707F262626110 link=1330994874/0#0 date=1330994874
    What do you mean by this? Is this just another way of saying skim milk?
    If it is, then thats your problem. Swirling the milk jug to helps incorporate the microfoam with the rest of the milk but it will separate pretty quickly as soon as you stop. Its just the nature of the milk. Try normal milk and see how you go (ie full cream milk).
    As for froth turning into milk... Im not too sure on that one.
    Feb 2012
    19
    Hi,
    I am using non-fat milk.
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    I dont think dman777 is in Australia and so may not know the term skim milk.
    As specialpants said try using whole milk. non-fat milk is harder to texture and will collapse faster than whole milk. non-fat milk also has a tendancy to coagulate or curdle when steaming.
    Feb 2012
    19
    sorry, im an idiot :) im using whole milk that has all the fat.
    Dec 2011
    PRL
    2,655
    What is your reference point here? Im not sure Ive ever seen/tasted a latte where the the bottom of the cup is exactly as airy as the top (I suspect I might be about to be corrected by the more the knowledgeable). Surely the physics of the situation makes this quite unlikely. (go easy guys I generally use low-fat milk at home). I have drunk lattes from a cafe where theyve prepared a large jug of milk and thrown most of the top layer into my single cup....which is as close as I can recall to an even distribution of microfoam...but I dont like it.
    BOSW
    Dec 2010
    310
    Quote Originally Posted by 7D7B67797C637F7E100 link=1330994874/5#5 date=1331018164
    Me too... all that foam always settle on the top regardless of how smooth or creamy it is.
    DMAN - theres probably nothing to worry about
    Feb 2012
    19
    I had a laugh....well, im comparing it to the coffee shop cappucinno. The milk on the bottom is drier and less liquid like than what I can produce at home.
    However, after studying the people at the coffee shop and this video I tried another way of doing it that seems to work better as far as foam consistency goes....stretching and folding at the same time.
    I take a 20 oz pitcher and I have the steam wand at about a 20 degree angle, rather than 3 degrees. I then stretch the milk and at the same time roll it. The foam produced it quite a bit more with lesser temperature escalating, so the end result is I am able to harvest alot of foam. However, when the foam is near the top of the frothing pitcher and I am only at 120 degrees, the Silvia seems to barely have enough steam power to keep the milk rolling. That is a real bummer.*
    I then let the milk set for about 2 minutes and it seems to stiffen. It probably goes down about an inch. After the milk has thickened, I aggressive swirl it around in the pitcher by hand until it looks very smooth and blended with the milk underneath. When I pour it...I seem to have a much better consistency with the milk looking puffy as it pours from the sprout.
    Still not as good as the coffee shop foam...But better than the 2 step stretch and fold process I was doing before.
    Jun 2009
    100
    Im no expert but I find there is plenty of steam with my Silvia.
    Also as for leaving the milk stand for 2 minutes, I thought that would allow the foam to separate from the milk?
  1. Milk frother issue
    By whattom in forum Milk Froth and Bubbles
    Last Post: 26th April 2013, 10:42 AM
  2. 2 machines different milk foam.
    By brett0004 in forum Milk Froth and Bubbles
    Last Post: 25th February 2011, 12:15 AM
  3. What Milk creates the best froth/foam?
    By thegoodies in forum Milk Froth and Bubbles
    Last Post: 9th July 2008, 12:43 PM
