Results 1 to 8 of 8
Thread: Tips for separating milk for a double-pour....
    Member yojabbajabba's Avatar
    Jul 2012
    64
    Question Tips for separating milk for a double-pour....
    Hi CoffeeSnobs!
    Well, if you are just as confused as I am with the title of this thread, let me elaborate...
    I would like some guidance in separating steamed into two jugs - the aim is to separate/decant the milk so I can pour two identical latte's/capp's from two separate jugs. Unfortunately, as I have been experimenting the freshly separated milk ALWAYS comes out a lot "lighter"/froth-ier/foam-ier than the second jug (which the milk is originally steamed in).
    Here's a flow diagram:
    STEAM 2x cups worth of milk => pouring 2/3 of steamed milk into smaller, empty milk jug => pouring 2/3 milk into first cup ( => leftover milk returned to original milk jug, and poured into second cup.
    I have been attempting to separate the milk as best as I can to ensure that the milk is "even" in both jugs - any advice would be greatly appreciated!
    Thank you in advance!
    Aaron
    Mar 2009
    11
    Hey Aaron,
    The following works for me:
    STEAM 2x cups worth of milk => pouring 1/3 of steamed milk into smaller, empty milk jug and set aside => pouring milk from original milk jug into first cup => milk from smaller jug poured back into original milk jug, and poured into second cup.
    Senior Member mwcalder05's Avatar
    Jan 2012
    Sunshine Coast
    437
    Quote Originally Posted by Costas View Post
    Hey Aaron,
    Mine is pretty much identical to this. Just a note that it helps with consistency of milk temp and microfoam to make sure your second jug is pretty toasty.
    Jul 2011
    116
    You might try going back and forth between the two jugs a few times to help even out the foam.
    Dec 2010
    Toowoomba QLD
    417
    I do the same as Costas, but as a note, when using an EM6910, the foam was never good enough to do this successfully. Now I've got a new machine with better steam, its ridiculously easy.
    Pete
    Jan 2012
    9
    I rarely have trouble pouring the two lattes from the one jug in four pours rather than two. Maybe I'm doing it "wrong" but my lattes generally come out fairly even (unless I screw up.)
    Member antiXa's Avatar
    Jun 2012
    Perth WA
    36
    Hey Aaron,
    What is it that makes the difference by separating a 1/3 into a smaller jug I have often pondered this. Is it because it retains the microfoam?. Thing is I have noticed this done a lot so there must be a logical reason.
    Jan 2012
    50
    Quote Originally Posted by antiXa View Post
    Micro foam always floats to the top, even seconds after steaming and if you start poring its what comes out first. So poring out 1/3 of the milk into a 2nd jug gets rid of the really dense foam leaving behind good latte milk. After poring your 1st latte from the original jug, you're left with very flat milk, so mixing in the really dense micro foam from the 2nd jug (make sure you tap and swirl) will leave you with excellent latte milk again.
    Works with any milk based drink. Using this method but altering how much of the micro foam you decant can be very useful. Can almost do milk for caps and flat whites together although I still hate doing that.
  1. Double Shot Pour Brugnetti Simona
    By Ranga in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th September 2010, 10:13 AM
  2. Double and single baskets + tamp / pour.
    By maxwazza in forum General Coffee Related...
    Last Post: 25th February 2010, 10:37 PM
  3. EM6910 Single Pour & Double Pour Cutoff Problem
    By Coffee2Di4 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd October 2008, 07:49 AM
  4. EM6910 single or double pour spout, difference?
    By martrix in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 5th November 2007, 08:46 PM
  5. Pour times for a double basket
    By tintub in forum General Coffee Related...
    Last Post: 15th December 2005, 11:23 AM
