Results 1 to 22 of 22
Thread: Portable milk frothing device for travelling
    Apr 2010
    558
    I'm travelling over Christmas and while I'm happy to just drink espressos from my Rok, life just isn't worth it if my wife doesn't have a latte when she wakes up.
    So, any suggestions on the best tool to buy to froth up milk? I'll have access to power and a microwave.
    Jonathon
    May 2008
    Newcastle NSW Australia
    85
    Jonathon, my suggestion, most places have a plunger (or you can take your own make sure it does not have too much metal on it. Microwaves don't like metal!) Add your milk, warm just a little in the microwave. Then use the plunger to froth your milk, then place back in micro to reach required temp. Add to your coffee shot for your Latte. Done Easy! Works a treat! With just a little practice you will be able to make reasonable microfoam rather than bubbles. Remember less is more
    Cicarda
    Wega Mininova Classic Seeya_Latte's Avatar
    Aug 2009
    66
    Hi Jonathon
    I've used my bellman cx25 for milk for times away but it needs gas (a portable butane burner will do if no mains gas is around)
    It's got heaps of steam enough for two milk drinks easy
    Apr 2010
    558
    Thanks for the ideas. I took a look at the Aldi Expressi today, but negative reviews put me off. Having read a little more, I reckon I'll pick up one of the whizzer things that spins a coil.
    Senior Member Gavisconi007's Avatar
    Mar 2014
    596
    I use an Aerolatte (cheap on EBay) and find it to be very effective for trips away. Very small and portable and does a great job.
    Mar 2014
    596
    The Aerolatte is AKA "one of those whizzer things that spins a coil"...
    Aug 2013
    Rockingham W.A.
    1,389
    Frothing with a plunger and microwave
    Quote Originally Posted by Cicarda View Post
    Cicarda
    Hi Cicarda (and OP)
    Firstly, select a decent glass plunger. FWIW, I use a "metal caged" Bodum, without the "fine plastic filter disc" which does awful things to hot milk flavour (or hot coffee for that matter).
    Using only the all glass section of the plunger, I microwave the milk once up to just below boiling point: depending upon the milk that is somewhere between 67 and 73 Celsius. Using gloves(!), place it back in its metal cage and then give it a few pumps of the plunger: it is close to a true "firm microfoam" latte texture, but usually without the extra sweetness that a steam wand can deliver.
    If you heat it again after frothing, both the texture and the sweetness tends to go away (as far as my taste buds are concerned, anyway).
    It is still my preferred "camping frother" as "one of those whizzer things that spins a coil" is not even close to a proper latte texture IMO. They are only for frothy cappo's, not lattes.
    Have a safe trip.
    TampIt
    Dec 2011
    PRL
    2,633
    Sorry....I just can't help but think of Baldric's coffee making exploits on Blackadder Goes Forth.....
    Aug 2008
    Millthorpe NSW
    2,038
    Quote Originally Posted by Barry O'Speedwagon View Post
    "Make mine a milky one, will you" - Captain Darling
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,885
    When traveling/camping most things are a compromise.
    The Aerolatte or similar does a reasonable job.
    Apr 2010
    558
    I agree, I've just ordered an Aerolatte to give it a go, although I'll also be dusting off my plunger to try that method.
    Dec 2014
    6
    HI everyone
    Welcome to my world at the moment.
    My machine died so if i do not want to get in the car and drive off down the road heres what i do.
    Heat my milk in the pot, when boiled i use one of two methods, 1 use the frothy thing on the bar mix ( not to bad ), 2 put it back in the empty milk contaner and shake vigorously being careful not to build up too much pressure, use tea towel it get hot.
    Dec 2014
    42
    In the past I used an Aeroccino Plus before I got an espresso machine that could froth effectively. It's reliable and makes pretty d___ good fake foam.
    Jun 2012
    9
    My wife got an aerocinno and I think it does it pretty well???
    Apr 2015
    5
    Obviously Christmas has passed now so i'm sure you had something suitable, but for future reference check out this completely new idea of texturing milk, which should definitely be cheap. Haven't tried it yet myself but quite intrigued by it.
    All you need is warm milk and a coffee plunger!
    Check out the polish barista championship winner Agnieszka Rojewska's routine, who used the technique as part of her World barista routine in Seattle 2015.
    You can watch the technique specifically on this link 2015 WBC Round 1, Day 1 on Livestream
    she basically heats the milk and then uses the coffee plunger - plunging around 20 times to create what i assume is a microfoam consistency. Pretty out there, so fair play on pushing the boundaries
    Jun 2015
    8
    Aero latte not much better than a plunger imho. Never quite worked out how to come up with a decent espresso whilst travelling though. Airline weight restrictions mean that stove top stainless espresso pots aren't practical - any suggestions for best alternatives?
    Dec 2004
    Earth!
    15,663
    While not producing a true espresso the Aeropress is far and away the best brewer for traveling I've found. It's small, non-metallic, lightweight, and produces a fantastic cup.
    Java "Pressing on!" phile
    Toys! I must have new toys!!!
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,261
    I had the opportunity to trial a Minipresso recently. It lacks the flexibility of an Aeropress, but I was pleasantly surprised with the quality of coffee it put out. Once again it's not true espresso, but when traveling you have to compromise. And as with all brewing techniques the quality of the end product has a lot to do with the operator. It's smaller than an Aeropress, only a little bit more expensive, but quite a bit cheaper than a Handpresso. For the same price as a Handpresso on its own you can get a Minipresso and a decent hand grinder like a Porlex Mini.
    And unfortunately an Aerolatte is really the only option for frothing milk. It's not great, but if you must have milk it's better than nothing.
    Aug 2015
    1
    Quote Originally Posted by Seeya_Latte View Post
    Hi Jonathon
    I'm very keen to get a Bellman for Camping, but i want a model with the Guage (So hard to buy in Aust. without paying 300-400). but i have a simple burner Shot maker. but they're so worth it, can't wait to try the milk steamer. just to point out there is also a Milk Steamer version only (CX25s). It's about 135 and Available at. Bellman CX25S Stainless Steel Milk Steamer - Di Bartoli In Australia.
    Jun 2015
    Armidale
    10
    We have a metal press frother for camping. Works a dream but not quite as good as a powerful steam wand
    Jul 2012
    3
    Quote Originally Posted by ravster1 View Post
    Just tried this.....
    1st result: overdid the "plunging" and ended up with way too much foam, but the taste of the coffee........ :-0
    With refinement, this is going to be my camping coffee setup for milk-based coffees. Just need to sort out the espresso side of things.... ;-)
    Mark
    Aug 2008
    Millthorpe NSW
    2,038
    Used this technique before too. for the espresso component 18g coffee in a half filled aero press gives a pretty close representation of a flat white
    Cheers Matt
