Page 1 of 2 12 LastLast
Results 1 to 50 of 51
Like Tree5Likes
Thread: How much water does your steamer add to your milk?
    Nov 2010
    10
    I thought my steamer was putting out too much wet steam so did a test to check it. My machine is a basic Sunbeam EM2300 so it's probably to be expected, but still I was shocked at how much water it was adding:
    I put the milk pitcher on a scale and zeroed it, then added 100g milk. I then steamed the milk (yes I purged the steam wand) and weighed it again. The result: 137g!!
    That's more like dilution than stretching.
    It would be interesting to see what results other people are getting. Please post your machine and result here.
    I couldn't find this being discussed previously so feel free to post a link her if it has.
    Jul 2014
    105
    Interesting topic. You've piqued my curiosity.
    Oct 2011
    1,376
    Even dry steam is water. How long did you steam for?
    Have never thought about weighing my milk before and after. I might give it go...
    Jul 2014
    105
    360g -> 395g here
    (Saeco Via Venezia = small single boiler)
    Mar 2012
    Bathurst
    1,081
    Wega mini nova
    215gm > 241gm
    Full cream woolies brand milk
    ~15-18 seconds
    Not sure of temp, assume 3.5C > 65C (judging from my standard end point)
    1.15 bar boiler pressure (steaming commenced whilst heating up from about 0.9 bar)
    Senior Member artman's Avatar
    Jun 2006
    2,357
    Interesting. Would be worthwhile to note the % increase. Will try with my machine later and post results.
    Oct 2011
    1,376
    Would be more meaningful with some additional data - duration, temperature (milk before and after), boiler pressure or temperature, milk fat content...
    Jun 2006
    2,357
    Yes. And if everyone steams the same amount of milk, same end temp (start temp ex fridge should be comparable) it would be easier to compare the results.
    Oct 2011
    1,376
    I think that is less important, as it is easy to normalise for differences in milk quantity (given the other information).
    Oct 2007
    Perth
    89
    Browns Heart plus (Low fat milk +), box says 1.5g per 100ml total fat
    Using an Alex Leva, well warmed up.
    three hole steam tip.
    123 degrees setpoint
    1.15 bar
    well purged before starting.
    250g Milk, Cold from the Fridge ~3 degrees
    stretched for 38 seconds.
    Drinking temp (not scalded, but could be hotter), I don't have a thermometer.
    276.5 grams result, more than enough foam for 2 caps.
    Nov 2013
    West Footscray, Melbourne
    204
    Looks like the trend so far has been ~10% increase in mass, whereas DanielC had a 37% increase. I'll have to give this a go in the morning and see if I can add some significance to the trend.
    Member ASchecter's Avatar
    Jan 2013
    USA
    98
    I steam small quantities of milk (100-120g). I've weighed the output several times over the years and always seem to get about a 15% increase in mass.
    Of course this depends on the starting and final milk temperatures (I shoot for about 68C final).
    Nov 2013
    204
    Well I gave this a try this morning, and the results were surprising!
    Rancilio Silvia v2
    200g A2 full cream milk
    3.5C to ~65C
    30 seconds steam time
    End mass = 336g
    So a 68% increase! Not great I think. I'll repeat this with half the milk and see if there is a difference.
    Mar 2012
    1,275
    One more for the data bank..
    85 gms ( piccolo) , A2 lite milk, 4-65 deg in 5 secs
    10gms , (12% ) weight gain using purged dry steam
    1.1 bar pressure , Isomac Millenium .
    May 2008
    3,995
    I would imagine the extra mass would be mainly air introduced when texturing. An inflated balloon weighs more than a non-inflated one. Some machines provide better efficiency and dryer steam than others so would add less water during the texturing process. I would imagine that thickly textured milk used for, say, a cappuccino, weighs more than that for a flat white.
    I'm not sure what relevance mass has with milk texturing. Isn't it the volume of textured milk that is important, not the mass?
    Jul 2014
    105
    Quote Originally Posted by flynnaus View Post
    Good imagination :-). A quick google suggests a litre of air weighs around 1.3g
    That's more to the point (I think the OP was using a thermobloc). And the duration of the process.
    May 2008
    3,995
    Quote Originally Posted by kbilleter View Post
    Fair enough. I should have researched the science a bit more.
    I stand by my assertion that volume rather than mass is the main consideration. So you end up with a 10-15% increase in mass (or more). So what?
    Jul 2014
    105
    I agree, if it pours well and tastes good... I guess it could be worth looking at if you feel your coffee should be creamier - or just start with richer milk :-)
    Nov 2010
    10
    No.
    Yes. And also it is a single boiler machine. I expect double boilers would be better.
    I did some searching on this topic but didn't find too much about it other than this article How to Froth Milk with the Finest
    Prepare Your Steam
    With this step, you want to ensure that your espresso machine will dispense not only ample steam to froth your milk, but also the right kind of steam. You mean steam isn't steam? Yes and no; there is dry steam and wet steam. Wet steam adds unwanted water to your milk, making it harder to froth and less sweet. To get the dry steam, you need to bleed out the water from the pipe that runs between the boiler and the valve that controls the flow of steam. When you turn on your espresso machine's steam mode (for machines that do not have always-on steam), wait about 5 seconds and then open the steam valve briefly into an empty container until water turns to steam. Wait about 20 seconds, and do it again. You now have dry steam. To keep the steam coming throughout the process, you need to begin frothing your milk before the heat turns off. If your machine is a heat exchanger or other kind with always available steam, this will not be a concern for you.
    Anyway, it's shown me I need to be a lot more careful with my steam heating, priming and purging.
    10%-15% seems like the average watering-down from the results people have posted here so it seems like that is the best that can be expected.
    Oct 2011
    1,376
    Depends on the question you are asking.
    If you know the mass of the milk, and the before and after temperature, you can calculate (approximately) how much heat was transferred to the milk. If you know the mass and temperature (or pressure) of the steam (i.e. water) which is added, you can estimate how wet the steam was. It will be a coarse estimate.
    In my opinion, volume is a lot less useful than mass in most of these types of calculations.
    Edit: That, and the density of the milk changes as you stretch it.
    Update:
    My quick and dirty back of the envelope (really, Google spreadsheet on my phone) indicates that just condensing 10g of saturated steam at 1bara will release enough heat to raise the temperature of 100g of milk from 5C to 65C. If you consider the other factors, you would actually need less.
    May 2008
    3,995
    Aren't the important considerations:
    texture - is the milk of the right consistency for (to your preference)
    volume - is there enough to make the number of milk-based coffees you need?
    temperature - is the milk hot enough (to your preferences - use a thermometer or by feel)
    Sorry, I don't get it. I don't know how the the knowledge that my milk's mass has increased by 10-15% because water has been added will help in making my coffee. It would be more important to know that if I start with a certain quantity of milk, I will end up with a certain increased quantity after stretching which usually ends being enough, not enough or too much. You usually work this out by trial and error as it depends on the quality of the machine and the skill of the user.
    Who would be getting out a calculator and applying some sort of equation?
    Oct 2011
    1,376
    I thought the question was "how wet is my steam"...
    Quote Originally Posted by DanielC View Post
    I thought my steamer was putting out too much wet steam so did a test to check it. My machine is a basic Sunbeam EM2300 so it's probably to be expected, but still I was shocked at how much water it was adding...
  23. #23
    Dec 2009
    SYD
    525
    That wouldn't be significant. Here's what I think is happening:
    Steam is simply water in a gas form - above 100C. As soon as it drops below 100C it reverts back to liquid water.
    The steam in your boiler is running at around 125C.
    Pretty much the instant the steam hits the cold milk in the jug, it starts condensing back to water. This added water increases the overall mass of the jug contents.
    Regardless, this is quite a fascinating thread!
  24. #24
    Oct 2012
    181
    I always wondered how much water was being added to the textured milk!...
    Clearly DanielC's larger mass increase is because of the cooler (or 'wetter') steam. The significance I see is that milk textured with dryer steam will be richer. It doesn't necessarily make it easier/better... as I recall some people like to add a dash of water to the milk before texturing.
  25. #25
    Nov 2010
    10
    Quote Originally Posted by herzog View Post
    Yes, but when water turns to steam it expands by about 1600 times (https://van.physics.illinois.edu/qa/listing.php?id=1734).
    So if you had a birthday balloon filled with steam and squeezed the steam into your milk it would only add 1 to 2ml of water.
    I noticed though that there was a spitting of water spray coming out of my steam want because it does not heat the water enough or it is condensing in the pipe.
    Steam is a clear gas so you should see very little of anything at the point that it comes out of the steam wand. By purging some wet steam, re-priming (by switching on the water pump for a few seconds), letting it reheat and then purging again the steam is almost clear and I can get much better results frothing the milk.
  26. #26
    Dec 2009
    SYD
    525
    There's a lot more steam involved than a party balloon I suspect - a balloon is a little bigger than a 2 litre milk bottle, say 3 litres.
    Given that others are reporting about a 10% increase in the milk weight, that's around 10 mL of water being added when steaming 100mls.
    Using your formula that's 16Litres of steam in gas form. So if you're steaming for 30 seconds, that's about half a litre of steam coming out of the jets every second.
    Another interesting experiment would be to pour 100 mL of iced water into a nice big clear glass. (like a whisky glass). Mark the level of the water with a whiteboard marker, then steam it.
    After steaming it, leave it to settle and see what level the liquid is at in the glass compared to the initial mark.
    Coffee snobs meets Mythbusters!
  27. #27
    Oct 2012
    181
    Don't mean to flog a dead horse, but because we're getting all sciency... The air in an inflated balloon should have the same boyancy as the air around it. The only increase in apparent mass would be from 1) very minor compression of the air; 2) the CO2 in your breath; and most likely 3) the water in your breath. While 1 litre of air might have a mass of 1.2 g, a litre of helium still weighs ~200 mg yet it makes a balloon float.
    DanielC likes this.
  28. #28
    Oct 2011
    1,376
    Thought I'd do a similar experiment today:
    mi = 272g (of milk)
    mf = 289g (milk + water)
    dm = 17g (added steam)
    Ti = 9.5C
    Tf = 43.5C
    dT = 34C
    That's 6.25g / 100g of milk for 34C temperature rise.
    Prorated to the 60C temperature rise I used yesterday:
    6.25g (60C/34C) = 11g per 100g milk for 60C
    Not far off my 10g estimate.
    To give something easily scalable, thats 0.0018g of steam per gram of milk per C - for my machine (Bezzera BZ99).
    In reality it may not scale so linearly (for example, some of the energy is used to heat the jug, and your hand), but its a reasonable approximation.
    burr and Col3 like this.
  29. #29
    Jun 2006
    2,357
    Ok this morning I poured the milk, weighed it, steamed it .... Then poured it into the cup!! D'oh!
    Just did another one.
    Alex Duetto II
    1.4 bar boiler pressure
    Start temp fridge
    Start mass 191.4
    End temp 65
    End mass 215.3
    12.5% increase in mass
    Oct 2011
    1,376
    So between 0.0020g & 0.00225g / g milk / C (assuming your milk was initially 1C - 9.5C).
  31. #31
    Mar 2012
    Bathurst
    1,081
    Breville BES900
    Woolworths lite milk
    Start temp: Around 3C
    Start weight: 200gm
    End temp: Don't know, around 65C perhaps?
    End weight: 224gm
    12% increase
  32. #32
    Jan 2014
    Discovery Bay, HK
    267
    I have been targeting a 10% but usually end up with 11% or 12% added weight. In my case, the duration of the process is the key to getting less water added to my microfoam. Longer purge and faster steaming time. No longer chilling the Espro Toroid 12oz. pitcher probably helped too.
  33. #33
    Oct 2011
    1,376
    Quote Originally Posted by JojoS View Post
    Well, the amount of steam injected into the milk is directly proportional to the duration; so not that surprisingly really
  34. #34
    Jan 2014
    Discovery Bay, HK
    267
    Not surprising at all I know and machines with a much bigger steam boiler will have the definite advantage.
  35. #35
    Nov 2010
    10
    Since I posted this thread I've replaced my machine and my results are far more in line with others here:
    Machine: Sunbeam EM7000 double boiler.
    Cold milk weight: 85g.
    Steamed milk weight: 95g.
    Increase: 12%
    Much better
    JojoS likes this.
  36. #36
    Mar 2012
    Bathurst
    1,081
    Increase: 12%
    Much better
    It would be interesting to see the changes if you adjust the steam thermoblock temperature and/or steam pump rate.
  37. #37
    Oct 2011
    1,376
    I would suspect (although it depends on how stable the thermoblock temperature is):
    - Increase temperature
    > dryer / hotter steam
    > shorter steaming time (i.e. milk heats faster)
    > less water added (per C rise in temp)
    - Increase pump rate
    > wetter / cooler steam
    > steaming time may be shorter or stay the same (don't think it would increase, but needs more thought)
    > more water added (per C rise in temp).
  38. #38
    Jul 2018
    fairly static
    197
    Milk and water
    When I make coffee for the two of us I weigh the milk mainly to minimise wastage, knowing the right amount for our standard morning drinks. Doing this with an ECM Mechanika for the first time, I found on filling the cups that I had lesser volume in mine, yet the milk foam was excellent, nothing unusual.
    I recall that the Silvia was adding at least 10% water to the milk, probably more, even though I cleared the steam wand before starting and let it reheat half way through. This was something I noticed more or less by accident, after putting the jug back on the scales which were not yet off.
    I am presuming the ECM has a higher steam temperature so is not generating as much water content while foaming the milk. I shall have to weigh it before and after next time to get a measure. Has anyone else checked this on their machine?
    I have not seen water content discussed in other reading, hence mentioning it now.
  39. #39
    Nov 2015
    31
    I noticed the same when I moved from Isomac Zaffiro to ECM Technika. I wasn't weighing but noticed a definite change in volume of steamed milk. The steam from the ECM seems much drier than what was produced from the Zaffiro.
  40. #40
    Sep 2009
    294
    Beensean your on the right path towards excellent specialty espresso!
    weighing your beverage components is an easy way to help you decipher the
    different tastes your taste buds are experiencing!
    I.e. 10g dose > 25g shot out> blended with 150g milk = what my other half luvs
    however yours may be more a 20g dose>37g shot out with 210g milk etc.
    You get the drift ?
    RE your question ...Its not errant water upweighing your stretched milk ...
    its the added air = greater volume by mass
    I found on average a constant +10% give or take.
    More info please? I am yet to fully work it out...Maybe more scientific minds here
    can kick the milk pitcher ... further !!
  41. #41
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,636
    Quote Originally Posted by EspressoAdventurer View Post
    Morning EA, can you tell us a little more your added air theory?
  42. #42
    Sep 2009
    294
    And Good Morning to you Yelta.
    I'd luv to if I had a high level scientific mind....where's Dr. Karl when you need him !!
    Simply my drive to produce better coffee led me to - all the things here we know already.
    Consistently good espresso needs a consistent input from the Barista.
    Anyway one of my locals who makes a cracking good shot used 10oz cups
    I used 8 at home.
    So chasing their flavour as a basic guide led me to comparing not only Inputs at the Machine side
    but also what goes in the cup.
    Simply as said above if I used a different recipe as a flat white I started considering how much milk was required to be blended
    in a 20g dose to achieve the taste I had on my palate memory.
    Anyway whilst measuring the final cup I found a variance in the numbers.
    Long story short every time I way the milk pitcher (tared for milk qty ) pre and post stretching I
    see an increase of approx. 10% ...flat white stretch.
    I put it down to the same weight variance experienced at the roasting stage where the beans will weigh post roast
    between 12-16% less.
    Anyway over to you Yelta and the combined intellect of CS'ers ...
  43. #43
    Senior Member noonar's Avatar
    Aug 2013
    MortalCoil
    423
  44. #44
    Jul 2018
    fairly static
    197
    Quote Originally Posted by noonar View Post
    Thank you, I missed that one on a quick search before posting this thread. Is it possible or worthwhile to merge comments here into that thread?
    @espressoadventurer: It is not the air, as confirmed in the other thread when it is mentioned that air weighs 1.3g/litre. Also, I suggest that uncompressed air is "weightless" on a set of scales, whether mixed into something else or not. Imagine weighing a jar twice, with its airtight lid on and off. Then smash and grind the jar into glass powder (eliminating air) and weigh it again. It (with lid) should be the same each time. Air at atmospheric pressure is neutral to measured weight at a given altitude. I think.
  45. #45
    Jun 2018
    403
    Quote Originally Posted by beensean View Post
    Yes.
    The scales measure the mass of the object minus the mass of the displaced air*. If the entrapped air has the same density as the displaced air it will cancel.
    FWIW the above means that the entrapped air in a milkydrink will slightly reduce the weight as measured by the scales as it is is both warm and saturated with moisture, both of which will serve to reduce its density WRT the air it displaced**.
    *For our purposes the air density correction is assumed to be too small to matter but there are situations where it is important: weighing a pycnometer for instance.
    ** Yes, moist air is lighter than dry air. Counterintuitive but provable.
  46. #46
    Dec 2011
    PRL
    2,551
    I'm guessing that the Doppler Effect could make the milk appear to change colour (and sound different) if we approached the pitcher at sufficient velocity.
    Yelta likes this.
  47. #47
    Jun 2018
    403
    I don't know that it would: milk is actually yellow, it appears white for the same reason that the sky appears blue (Rayleigh scattering).
    Rayleigh scattering increases strongly with frequency so I don't see how doppler shift would affect the perceived colour much: if we are approaching the milk that will shift the yellow base colour towards green but then the Rayleigh scattering will shift upwards as well, I think the two effects would partially cancel.
    (Insert smiley thing here)
  48. #48
    Sep 2009
    294
    Just a note to thank Beensean
    Re: Post 'Milk & Water" for raising the subject (once more)
    And more so to regular contributors here -
    Yelta & Noonar for highlighting the reality of what is going on with the re-weighting of milk post stretching,
    by linking the prev post of 2015. Which I missed somehow, or don't recall.
    Maybe that was around the time I had a serious get off on my Enduro Bike up around the Border Ranges NP and headbutted a tree!
    But seriously tho great discussion & good info that clears up my misguided thoughts !!
    Good stuff and just why so many of us that make this site the marvellous thing it is....
    And we dips our lid to you Andy !
  49. #49
    Dec 2011
    PRL
    2,551
    Quote Originally Posted by Lyrebird View Post
    Yeh, well if my velocity relative to the milk pitcher is approaching the speed of light (regardless of which object is providing the absolute velocity) I'm probably not going to be able to confirm the results of this test ex post
  50. #50
    Jun 2018
    403
    You may rest assured that at no stage did I believe that your post was a serious analysis of a real world situation.
    My reply, however, is to be taken absolutely at face value and I would be highly offended if you were to roll your eyes and say to yourself "what the eff is this guy talking about".
Tags for this Thread
