Results 1 to 7 of 7
Thread: Steaming milk with small jug
    Ali
    Ali is offline
    Apr 2008
    91
    I have 1 milk coffee a day. I recently bought a small jug (approx 400ml) as my 600ml was just a bit too big. Im having a lot of trouble steaming the milk - its like the steam presssure is way to strong. I have a 6910. Does anyone have any hints on using a smaller jug - should I not turn the steam pressure to max?
    Apr 2008
    Brisbane
    5,115
    Re: Steaming milk with small jug
    Hi Ali
    Try this CS link
    Give this method a go as others have reported good results even with smaller mahines
    http://coffeesnobs.com.au/YaBB.pl?num=1220959662
    Ali
    Ali is offline
    Apr 2008
    91
    Thanks KK. Ill give it a try today.
    Gra
    Gra is offline
    Jun 2008
    Gold Coast
    610
    Hi Ali
    I have a 6910 and I use different jug which are 1 litre 600ml- 500ml bell shape-and 300ml for a single flat white.
    The main thing to learn is the amount of stretching to the amount of milk you are heating, with a bit of practise you will get there, I use full steam for all "jugs"and start with the jug level then slight tilt to form whirlpool..
    cheers Gra..
    Sep 2008
    23
    Thanks for the link.
    I have always had trouble with consistently getting good foam, but (touch wood!) this technique seems to have solved the problem :)
    Ali
    Ali is offline
    Apr 2008
    91
    Thanks guys. I think the problem is that the thermometer I use is too long for the jug with the clip to hold it to the side and I may be heating the milk too much???
    May 2007
    724
    The clip should be adjustable, shouldnt it? Also, depending on the thermometer you use, they usually lag a little and the actual temp may be quite a bit higher than what its showing and if you stop steaming and let the thermometer sit in, you might find the temp creeping up still for up to 5 seconds after youve stopped steaming. Using the silvia to steam, when I use the smaller jug, I dont have the steam at full blast. havent used a 6910 but Id imagine it would be similar if it has quite a bit of grunt to do a 600ml jug easily.
    Ive been using the 300ml incasa jug so much that Ive forgotten how to get latte art microfoam on the 600ml jug and its killing me.
  1. Does steaming milk negatively affect the nutritional value of milk?
    By Dragunov21 in forum Milk Froth and Bubbles
    Last Post: 27th October 2013, 07:40 PM
  2. Bar pressure when steaming milk
    By FineGrind in forum Milk Froth and Bubbles
    Last Post: 10th June 2013, 05:03 PM
  3. Small Milk Jugs
    By richard_s in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd November 2011, 09:29 PM
  4. Milk for 1 or 2 small coffees
    By martini in forum Milk Froth and Bubbles
    Last Post: 5th January 2011, 01:25 PM
  5. Silvia - steaming milk
    By BamBam in forum Milk Froth and Bubbles
    Last Post: 17th November 2008, 09:56 AM
