Results 1 to 8 of 8
Thread: OMRON H3YN-2 Timer (power supply question)
    Jun 2008
    1,520
    Hey CS electricians / techs / smart people.
    looking at this timer is the below right?
    OMRON H3YN-2 Timer
    its the short range time model
    it needs a supply voltage of 24v ac to power it up
    but it can timer / switch at 240v circut?
    spec sheet .
    http://www.omron247.com/doc/pdfcatal.nsf/24E4F8D2A9925FD486256B8300528588/$FILE/D19H3YN0302.pdf
    many thanks
    Leeham
    Sep 2009
    28
    Re: OMRON H3YN-2 Timer (power supply question)
    Hi Maheel,
    You are correct, 24vAC to power the unit and it can switch up to 240vAC or 30vDC but you are limited to a current of 5Amps so nothing too big or the contacts will weld together.
    Jun 2008
    1,520
    Thanks RR
    but bugger now i need 24 volts...... I had a laugh
    lucky they were cheap.....
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 5F535A57575E320 link=1254193101/2#2 date=1254206074
    Thanks RR
    Some of teh laptop PS are around 24V... You could even get a simple and cheep plug pack, as the power to drive the unit is not great... Just check ya specs of teh Plug pack and the unit... Note: Allow some margin as the values are only indicators :-)
    Jun 2008
    1,520
    yeah i picked up my Toshiba laptop power pack right beside me.....
    19V hmmmmmmm
    thanks AM :)
    how about this?
    http://www.jaycar.com.au/productView.asp?ID=MM2009&CATID=19&form=CAT&SUBCAT ID=411
    jaycar CAT. NO. * * MM2009
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 333F363B3B325E0 link=1254193101/4#4 date=1254206643
    19V hmmmmmmm
    thanks AM :)
    how about this?
    NO *NO NO
    The secondary is all AC and then you have to make DC from it and then box it and etc etc etc *It is also working with 240AC and thus needs to be checked and tagged by a Licensed person..
    Let me check the actual DC Output on the Toshiba... Have a few here...
    19.8V DC ... I would give it a go... to see how the time works... But dont connect the timer / contact to any thing...
    Jun 2008
    1,520
    Yeah dont i need 24 AC for the timer?
    Is the jaycar one AC -> DC?
    i thought the jaycar was AC 240 -> AC 15-30
    i didnt want any DC ( i thought)
    dont worry a sparkie will build it for me, B-law is one (and he was a inspector for the QLD lecy saftey mob) so he is very safe.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 79757C717178140 link=1254193101/6#6 date=1254207839
    YA right it is a 24AC control.. Blindness is an affliction of teh old and cheep PC screens *;)
    I have some AC plug packs... Let me look and I will take care :-) Might be one at about 24AC....
    Your LUCKY DAY... How about rated @ 20 AC at 750ma and measures 24.4AC with no load...
    OK... Time to beg for Assistance / postage from Qld :-)
    Send me a PM... with ya details, but beg in PUBLIC 8-)
  1. Power supply change on Breville Barista Express BES860XL Machine with Grinder
    By Allison in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th October 2012, 01:51 PM
  2. Dumb question re: 3 phase power
    By redzone121 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 2nd October 2009, 07:35 AM
  3. re Faema Due, power settings question
    By telemaster in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th June 2009, 08:43 PM
  4. Mazzer super jolly automatic (timer?) question
    By Neekolas in forum Grinders
    Last Post: 12th May 2009, 07:45 PM
  5. Replies: 16
    Last Post: 26th July 2008, 03:53 PM
